Old 25-01-2024, 12:19 PM   #31
Gus69
Default Re: Brought a new car, Fairlane, beeping noise is constant
Hello I have ford fairlane 97 bf it's got thus weird nosie on strat of the engine sometimes goes for long time and sometimes short time I just like to now those any news we're already speaker is located please thank you
Gus69 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2024, 12:51 PM   #32
Gus69
H Ellis I found the issue with being nose on straton tge engine if ford fairlane 97 by pulling every fuse the fuse will stop the bee is the ingi tonnes 10ams red if you pull it out the n o side will stop but your seeds meter will not work
Old 01-02-2024, 08:24 PM   #33
Can someone translate this for me please? Is he saying, as I am guessing, something like: " I found the issue with the noise on starting the engine in my Ford Fairlane 97 (i.e. NL ) model by pulling every fuse; the fuse that will stop the beeping is the Ign (Ignition and Instrument Fuse) 10 amp red fuse; if you pull it out the noise will stop but your speedometer will not work" ? If so that's really no help as the instruments fuse also powers the warning beep whatever the cause so you have not found the root cause just turned off the warning beeper
Usually a warning beep will also be accompanied by one of the warning light jewels on the dash illuminating. So if a more critical or important fault like overheating, brake failure or no oil pressure happens you won't get a warning beep.
Check nobody has covered any of warning light jewels with a bit of paper etc; a common dirty trick with someone selling a used car with fault or in the UK getting it through a MOT test a bit like Hubnut did recently per https://www.youtube.com/watch?v=dssB92C4Lnc
