Old 03-07-2009, 03:54 PM   #1
debchow
Default Problem with my 85 Telstar
Hi there,
I am having some big problem with my beloved old 1985 telstar and I do not have much idea about cars. I am getting big clicking noise from the engine and it is getting worse every time I accelerate. I am not getting much race at the moment either.
The road side assistant told me the car is now running on 3 cylinders instead of four. He showed me that even after taking out one of the spark plug there is not much difference in the engine running. He further advised it could as simple as changing the spark plug or as complex as compressor (not sure) problem within the engine.
So wanted some advice from anybody. I appreciate your help
Thanks beforehand.
Dave
debchow is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2009, 04:26 PM   #2
dirty hands
Over Thinker
dirty hands's Avatar
have a mechanic do a compression test on each cylinder
if the readings are above 150psi that should be good
replace the plugs leads and distributor cap if needed
the next clicking may he the valves need adjusting
My car goes Brumm Brumm
dirty hands is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2009, 04:39 PM   #3
Hords
Treasure your balls?
Hords's Avatar
Sounds similar to the 87 TS Telstar I had. It had around 180k on it when the valve guide went.
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
