Old 29-10-2011, 07:13 PM   #1
nstg8a
3..2..1..
nstg8a's Avatar
Default sudden change in fuel consumption
basically, my au3 forte
has been getting close to 500kms to a tank of petrol for the last couple of months, i dont take much notice of what i put in it, e10/95, doesnt seem to matter which, no significant difference.
but the last two tanks of fuel ive struggled to get 250/300, both tanks were from seperate servos.
its running as averagely has it ever has. its always had a weird miss at idle, and sometimes its a bit lazy off the mark, but its been like that since i got it so i doubt that its the cause.
really the fuel economy was one of its few redeeming qualities... without that i doubt it will survive much longer.
any ides on possible causes?
nstg8a is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2011, 07:43 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: sudden change in fuel consumption
Have you changed your normal routes?
UK
Old 29-10-2011, 09:10 PM   #3
b2tf
not here much anymore
b2tf's Avatar
all the usuals - coils, plugs, leads etc. Maybe 02 sensors. AU's are a fickle bloody thing, they seem to let go with no warning.
RAM 1500
Old 29-10-2011, 11:15 PM   #4
au11futura
ROCKING THE EL FUTURA
au11futura's Avatar
clean the throttle body change plugs and leads also clean the air filter.
its letting you know everything needs a clean.
BA MK11 XR8 ENFORCER NOW SADLY GONE
My build that was http://www.fordforums.com.au/showthread.php?t=11267696
ENVI BA XR6T
BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX
NOW A EL FUTURA
EB MONTY NOW IN THE SHED
BACK IN THE E-SERIES
THREAD DIGGEr
au11futura is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2011, 11:28 PM   #5
au11futura
au11futura's Avatar
here you go
http://www.fordforums.com.au/showpos...9&postcount=43
http://www.fordforums.com.au/showpos...2&postcount=48
clean these first mate i used to do it every month as routine and never stopped getting the 500's to the tank..
ENVI BA XR6T
NOW A EL FUTURA
THREAD DIGGEr
Old 30-10-2011, 12:03 AM   #6
nstg8a
3..2..1..
nstg8a's Avatar
UK
i have started working two jobs, but if anything the extra distance travelled should be more economical than before, as its virtually a straight run as opposed to a million sets of lights.
o2 sensor was my first thought. can they be tested?
great info there, cheers for that.
ive been meaning to throw some new discs and pads at it for ages now, has that dreaded warped disc steering wheel shimmy, so i might just order new plugs and leads/coil at the same time, spend a weekend doing some maintenance on the old slapper.
Old 30-10-2011, 12:09 AM   #7
FGII-XR6
FGII-XR6's Avatar
Originally Posted by nstg8a
o2 sensor was my first thought. can they be tested?.
O2 sensor most likely candidate as it was sudden sometimes will throw a fault code but often not. if the sensor is more than 120 to 150Ks old replace it regardless
[SIGPIC][/SIGPIC]
Rides:
Old 30-10-2011, 12:17 AM   #8
nstg8a
3..2..1..
nstg8a's Avatar
speedo is showing 180kms, dunno if the o2 sensor has ever been changed.
Old 31-10-2011, 06:47 PM   #9
FGII-XR6
FGII-XR6's Avatar
sounds like a replacement is in order then. have a look at this http://www.ebay.com.au/itm/FORD-Falc...item231599e1c9
[SIGPIC][/SIGPIC]
Rides:
Old 22-11-2011, 03:11 PM   #10
webbiegareth
Was this problem fixed?
webbiegareth is offline   Reply With Quote Multi-Quote with this Post
