Old 27-06-2013, 07:21 PM   #1
Jesmat
Default RS2000 rocker cover original colour
Anyone know the actual original colour / colour code of the blue rocker cover for an RS2000?
Jesmat is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2013, 07:58 PM   #2
rag top
rag top's Avatar
Default Re: RS2000 rocker cover original colour
Mine was black. Not sure of the Mk1 RS2000 or the '76 german imports, but the 79 and 80 RS's I had all had black rocker covers. Blue was common on the TC/D 2L cortinas, and used in many a 2L escort conversion.
Current Rides:
2000 AU 5L XLS ute; 1970 Mustang project
Old 27-06-2013, 11:25 PM   #3
XB GS 351 Coupe
Ford Escort Section of forum may be
The Daily Driver : '98 EL Falcon, 5 Speed , 3.45 lsd
The Week End Bruiser : FPV BF GT 40th Anniversary, 6 Speed Manual, 6/4 Brembo and lots of Herrod goodies
Project 1 : '75 XB GS 351 Ute, Toploader, 9" with 3.5's
Project 2 : '74 XB GS Big Block Coupe, Toploader, 9" with 4.11's
In Storage : '74 XB GS 351 Fairmont Sedan
XB Falcon Owners Group
Mike's Man Cave
XB GS 351 Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2013, 07:33 AM   #4
EASYBOSS
Matakana NZ
EASYBOSS's Avatar
Black on a German assembled MKII RS2000
SOLD : BA XR8 4 Speed Auto in Mercury Silver, Bluepower CIA, Full Diffilipo Big Boy Quad System, Tune, 4.11 Diff Gears, FPV Starter Button, FPV GT Rear Spoiler, Tripod Gauges, PWR Trans Cooler. 230 RWKW's. Many thanks to Chris at Bluepower Racing Developments
Hers : F6X build #150 in Ego, Stock as a Rock, untill the warranty runs out, including the extended one.
My Work Wagon AU Futura Wagon in Gold.
On the Farm : Ford 6600 Tractor
EASYBOSS is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2013, 08:44 AM   #5
Jesmat
Thanks for your replies. It's a 1979 4 door RS. Cover is currently blue, so maybe Cortina engine has been fitted.
Old 28-06-2013, 02:54 PM   #6
EASYBOSS
Matakana NZ
EASYBOSS's Avatar
Should look like this, not the air cleaner, that's factory for twin downdraughs, I mean the colour of the rocker cover
Old 28-06-2013, 04:11 PM   #7
Jesmat
Thanks Easyboss. Problem solved. Cheers.
Old 28-06-2013, 05:12 PM   #8
EASYBOSS
Matakana NZ
EASYBOSS's Avatar
Should have mentioned that's a German assembled 1979 RS2000, not sure what the Aussie assembled ones were
Old 28-06-2013, 10:02 PM   #9
Escort_RPDriver
The Aussie Rs 2000 were no differant to the stock 2.0L escort Black rocker cover same specifacations as any GL or Ghia 2.0L
Rides
1979 Ford Escort Ghia 2.0L 3 Speed Auto
mods
head ported polished
extractors
speco cam.
1997 Honda Civic 3 door 5 speed
mods
extractors
cold air intake
lowered
white line front rear anti roll bars
white line strut brace.
riding on 17 inch shoe's.
Escort_RPDriver is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2013, 10:36 PM   #10
muzzy
muzzy's Avatar
Bugger, I painted my whole engine ford blue, oh well it looks good
RS2000 5 speed
Twin 44idf webers + other goodies
muzzy is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2013, 07:19 PM   #11
66GT
My 77 2dr GL 2L 4speed was originally completely blue motor from new. I thought all Cortinas & Escorts were blue except the RS having black motors. I could be wrong though.
66GT is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2013, 06:04 PM   #12
TITO
Except... the weber carb was jetted differently on RS2000's
TITO is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2013, 03:14 AM   #13
whooligan
whooligan's Avatar
Aussie RS2000s had Blue cam covers and air cleaners, NOT black.
The engine block should be black.
In every other way, the RS2000 engine is the same as the 2.0 Ghia and GL. Even carby jetting.
The cortina a had blue blocks and blue (plastic) air cleaners, which you sometimes see on early 2.0lt Escorts like rally packs.
Old 24-07-2013, 04:20 PM   #14
GT450
My RS2000 new in 79 was Black not blue.
GT450
GT450 is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2013, 10:16 PM   #15
whooligan
whooligan's Avatar
I recall that my silver RS (1979) did have a black cam cover but that had been recoed before I bought it. The other 3 were matching number 1980 models, all with blue cam covers from factory.
Old 24-07-2013, 11:27 PM   #16
TITO
GT450
And so did my rs2000 midnight blue two door with black engine and cam cover from factory and I have to say it.... The carby jets were a differant size compared to a stock cortina engine I bought to rebuild to suit a turbo. That was a long time ago but I still have a few marbles left.
Old 27-07-2013, 10:28 PM   #17
muzzy
muzzy's Avatar
The Carby jets on the single downdraft weber, varied between auto, manual and year model, as did the distributor advance curve, by now you would be flat out finding one with original jets.
RS2000 5 speed
Old 28-07-2013, 10:26 PM   #18
Jesmat
Made the decision to coat it in close to original rs2000 sno white. Right or wrong??? I don't know yet - we'll see how it turns out!
Old 07-06-2014, 09:30 PM   #19
bathurst-racer
As a matter of interest the RS 2000 head had slightly higher compression and these heads wore a black cam cover.
bathurst-racer is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2014, 08:21 AM   #20
bathurst-racer
Ooops my bad. It is higher compression pistons not the head. Thirty years is a long time to remember this stuff.
Old 19-06-2014, 02:50 PM   #21
polkgs
Vixen GS
polkgs's Avatar
I am an old Escort & RS2000 owner so I am going from memory here as well. My recollection also is black covers equals high compression engine and blue cover was low compression. I think all auto's had the low compression engine - 64kw as opposed to 70kw. Just going from memory - don't shoot me
polkgs is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2014, 09:34 PM   #22
PeterM1
Definitely black. I still own my RS2000 since new in May 1980.
Thanks,
Peter.
PeterM1 is offline   Reply With Quote Multi-Quote with this Post
