Old 23-07-2020, 09:25 AM   #1
cat007
Default Pure water vs coolant on the track
Hi all.
Just wondering if anyone has tested running pure water vs coolant in the same car on the track and recorded what the temp reached for each?
My FGX XR6T gets overheated on the track after not many laps and was wondering if running pure water, instead of coolant, for higher thermal efficiency is an idea to get a bit more out of my stock cooling system, without having to buy a larger radiator?
Hunt
cat007 is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2020, 09:48 AM   #2
superyob
Default Re: Pure water vs coolant on the track
Some years back, I was having trouble with a constantly overheating 302 (at idle). Upon advice given to me by forum members, I drained the coolant containing ethylene glycol and refilled with a product that did not contain glycol. My running temperature dropped by at least 5 degrees...
superyob is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2020, 11:39 AM   #3
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
You could try Redline Water Wetter
https://www.automegastore.com.au/red...hoCXBIQAvD_BwE
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2020, 12:19 PM   #4
Tassie f100
Guess the easiest way to find out is to drain the coolant and replace with some plain tap water.Give it a good workout and see what happens
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2020, 12:23 PM   #5
Bossxr8
Peter Car
Bossxr8's Avatar
Needs a corrosion inhibitor as well.
Old 23-07-2020, 12:44 PM   #6
superyob
This will work but I would fill with distilled water...
Old 23-07-2020, 12:56 PM   #7
cat007
Originally Posted by my67xr View Post
Yeah saw that. Might try that at track day with deionised and demineralised water. It has a corrosion inhibitor as well:
https://www.redlineoil.com/content/f...ech%20Info.pdf
Old 23-07-2020, 01:55 PM   #8
Tassie f100
And there is a potential problem.If the engine runs cooler with plain water you have answered your question, but could have long term problems unless you empty and refill after track days (which isn’t a big problem).As far as running track runs you don’t need inhibitor.
Old 23-07-2020, 03:41 PM   #9
roKWiz
Cabover nut
roKWiz's Avatar
Haven't heard much on the waterless coolants lately or was that a passing fad.
Old 23-07-2020, 04:10 PM   #10
Itsme
Experienced Member
Itsme's Avatar
These two products should be added to your water if you are discarding coolant.
Old 23-07-2020, 04:38 PM   #11
coo
Double edged sword.
Gycols are slower to absorb and release heat. But have a higher boiling point.
Plain water will trigger corrosion, especially in aluminum radiators.
The last thing you want is boiling esp around the head.
You haven't mentioned actual temperatures being recorded and where.
Is the tune (lean and ignition timing??) contributing to the heat?
Maybe do some maths; volume of coolant, vs gycol mix ratio, vs wanted boiling temp (under pressure). Then adjust your mix.
coo is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2020, 04:58 PM   #12
Vesper Martini
Vesper Martini's Avatar
Penrite race coolant?
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2020, 06:07 PM   #13
Blue Dog
Originally Posted by cat007 View Post
Hi all.
Hunt
The factory cooling system is NOT designed for track days.
Blue Dog is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2020, 06:58 PM   #14
hawke
hawke's Avatar
When glycol levels get to 30% or more, the heat transfer ability is reduced. For racing purposes, about 10% will give you a good balance between heat transfer, raised boiling point, and some corrosion protection. Water wetter will help as well.
Depending on where the water temp sender is located, sometimes, increased exhaust temps when racing will fool the sender to register a higher temp to the gauge. Check those temps with a temp gun in the pits when you get back to confirm the gauge reading.
Just my experience in running race cars over the last 20 years. Hope it helps.
hawke is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2020, 10:15 PM   #15
Pis-ton broke
Pis-ton broke's Avatar
you could try a soluble oil and water mixture, i have in one of my engines.
Pis-ton broke is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2020, 11:35 PM   #16
gooseneck
Put two small radiators in each wheel well with small fans on them and duct the air into your brake discs. Flip a switch inside the car whenever it gets too hot or do it automatically with a thermostatic switch or arduino.
Then if that doesn't reduce your temps add a bigger radiator.
gooseneck is offline   Reply With Quote Multi-Quote with this Post
