07-11-2011, 09:58 PM | #151 | |||
09-11-2011, 01:30 PM | #152 | ||||
AU DIE HARD
09-11-2011, 04:07 PM | #153 | ||
Do you reckon he would cut a genuine AU hose???
09-11-2011, 06:28 PM | #154 | ||
Little dearer than I would have liked, but it seems like pretty good insurance.
09-11-2011, 08:02 PM | #155 | ||
not here much anymore
Where do they fit in the cooling system Whoosh? Just anywhere you like in the bay, cut a hose type thing?
RAM 1500
09-11-2011, 08:25 PM | #156 | ||
AU DIE HARD
It comes with all the fitting info Aust, but I would rekon between the water pump and the radiator would be the go , but as Pinky says I wouldnt cut a new hose to fit it let alone a silicon 1 I would think that a old hose would do the job then after 1000 or so Ks you wouldnt expect much more crap if any to be in the system if your coolant is kept in good nick . then just take it off . Anyway will do a bit more research first and get back to you all
11-11-2011, 07:41 PM | #157 | |||
AU DIE HARD
Well all is good at the house of Windsor (touch wood) Hector Ms finest has taken to the road in anger again Here"s a few tips for those who like to dabble fixen $ hit for them self option 1 pay some body option 2 carn't afford it ,save up then If your still not convinced you will need a few specialist tools to get the mighty Wheezser apart or a mate with a shed full of them Hex socket set is a must, decent Allen key set, deep socket set or a eurotech hollow set and a mini max set is good as well,plus all the usual assortment , a Magnetic retriever of some sort is a priceless piece of gear as well, who new the blade from the scraper would just full out and land in the 25mm opening into the sump FFS .. are well such is life.. hope fully this will be the end of this thread now and I can move on just a few happy snaps for a fitting end thanks again for all the advice along the way, and as always me mate AU1XLS and Pinkbits ..
Last of the Flat white a few tools Nice one Hector M Cleaned and ready to rock Seto bear was waiting as were the go fast fluffy dice Cheers gang if any one needs more info.. send me a PM
11-11-2011, 07:53 PM | #158 | |||
5.6L x 2 pilot
Well done mate. Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
11-11-2011, 08:46 PM | #159 | |||
AU DIE HARD
Just poked around for a few Ks Stu checking stuff along the way (hence why I have left the clear header tank on for the min.) after a 1/2 hour or so gave it a bit up to the freeway limit, in 2nd gear in seems to hit the rev cut off fairly qwick and feels strong as, But I ve been driving the Mrs. Kia Rio for 6 months so it was always going to feel qwick I will chase Pinky up soon and we shall have a play and see
Did I mention Project Lift a Leg has arrived home
11-11-2011, 09:37 PM | #160 | ||
T3 TE50 Blueprint
I have been running a TEFBA cooling system filter since new in '02. I was getting machining swarf stuck in it from day 1. My Dad has been using them since they came out. So I guess it's hereditary.
-Craig |
12-11-2011, 12:44 PM | #161 | ||
Lost Boost Gained Class
good news whoosha glad the sleepping beast is out to play again
2006 BF Fairmont Ghia
2001 AU Falcon |
