Old 10-11-2011, 10:22 PM   #1
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
Default Help with car sounding like its running on 5 cylnders
ok guys i need help im outa ideas....
this is what happend
i drove the car one day all good i put $20 worth of Ron 98
next day started it and it sounded like its on 5 cyl
of changed spark plug leads
Spark plugs
iv checked for spark on all cyl ....
Going to change coilpack with spear 100% knowing that it works
im outa ideas :( could bad batch of petch do this or is there something i could check for like stuffed rocker or something....
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2011, 10:29 PM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Default Re: Help with car sounding like its running on 5 cylnders
Injectors or Coil Pack would be my guess....
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2011, 10:33 PM   #3
POELWYK
POELWYK's Avatar
i dont think its injecters its to of a sudden thing... im just seeing what other things it could be / look at i gota fix this as i need it... and my BA is going for a tune )
2001 AU Falcon
Old 10-11-2011, 10:41 PM   #4
GK
Walking with God
GK's Avatar
Question Re: Help with car sounding like its running on 5 cylnders
Bad batch of fuel?
Hope you get it sorted soon.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 10-11-2011, 11:16 PM   #5
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Where did the fuel come from?
C
ould be the fuel filter/pump? Bang the tank while the car's running, see if the noise from the pump changes...
Vacuum leak?
H
ow clean's the front of the motor, the crank angle sensor could be fouled?
D
oes it rev cleanly?
Fuel smoke?
Lifters w
ill make a ticking/rattling sound if stuffed.
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 10-11-2011, 11:25 PM   #6
POELWYK
POELWYK's Avatar
i got the petch from my normal place 7/11 old Mobal servo (good turn over)
No vacume leaks
the bay gets cleaned every cupple of weeks to watch for leats and so on
pump in tank i donno iits a bit hard to know as the car is Loud lol
there was a ticking sound comeing from the car when it gets hot b4 this happend
ill have to try and see i might go to another servo and get some more fuel and see if it helps or not
the car isent reving well down low once it gets up speed it feels ok ish not right but better
2001 AU Falcon
Old 10-11-2011, 11:30 PM   #7
mongrelEF
Bugger!
mongrelEF's Avatar
Sounds like bad fuel or weak spark......
L
ow fuel pressure is normally worse under acceleration.
D
oes it have reasonable power? Could be a blocked cat but that's not usually a sudden thing.
Old 10-11-2011, 11:36 PM   #8
POELWYK
POELWYK's Avatar
its got power its worked lol....
na it feels like its not running on all cyl
i might put a few leters of clean fuel in her and change the coil pack and see what happens what do u guys think
2001 AU Falcon
Old 10-11-2011, 11:45 PM   #9
mongrelEF
Bugger!
mongrelEF's Avatar
Sounds like a good starting point, yeah. Don't think from what you're saying that it'll be anything very major
Old 10-11-2011, 11:52 PM   #10
POELWYK
POELWYK's Avatar
yeah ill give that a try if all fails ill post back my findings with a vid if i need to
2001 AU Falcon
Old 11-11-2011, 12:47 AM   #11
Day-mow
rexnet
Day-mow's Avatar
coil pack wet? i find if my coil gets wet it runs like a pig. any of your plugs/leads died?
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Remember it is the internet,So beware of trolls, If you argue with trolls the kids will laugh at you
Follow me on twitter @ Day_mow
Day-mow is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2011, 01:32 AM   #12
mik
mik's Avatar
you beat me too it Day-mow , was just going to say , have you washed the engine recently? been through any floods lately?
Old 11-11-2011, 02:21 AM   #13
Dr Jekkyl
Disconnect the injector electrical connector for each cylinder one at a time.
If it makes no difference to how it runs then that cylinder is where your problem is.
It won't tell you WHAT is wrong but it has to be either fuel or spark.
Dr Jekkyl is offline   Reply With Quote Multi-Quote with this Post
Old 11-11-2011, 12:47 PM   #14
POELWYK
POELWYK's Avatar
Ba the bay hasn't had a wash in weeks I put new spark plugs and leads on it yesterday soo I'll give all that a try Sunday when I'm home next
2001 AU Falcon
Old 11-11-2011, 04:44 PM   #15
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Still got you old spark plugs and leads? Put them back in and see how it runs. (I would still have them lying around, my wife would have chucked them out)
Uk
Old 11-11-2011, 10:18 PM   #16
dieseltrain79
Cracked spark plug ? Does it do it at idle ? If so remove 1 lead at a time until you find which cylinder .
Could be Coil pack though if its constant .
Ticking when hot , IS it low on Oil ? maybe the oil is in need of a chnge
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 12-11-2011, 12:57 PM   #17
POELWYK
POELWYK's Avatar
na old leads where stuffed so thay got the bin (thay broke when removeing)
na its not low on oil it has just devalaped a tick when its hot i donno yet ....
this is how it sounded when working right
http://youtu.be/FN_tJfHdHR8
and
http://youtu.be/bDQN8T1Px90
and
http://youtu.be/o_znZjgh6aE
2001 AU Falcon
Old 14-11-2011, 08:22 PM   #18
POELWYK
POELWYK's Avatar
ok guys i pulled the injecters off and found number 6 did not make any dif so i investergated more and found number 6 on the coil was giveing odd a lazy spark when it felt like it or not at all ....
Changed the coil pack and the thing fired 1st kick
thanks for the help guys
2001 AU Falcon
Old 14-11-2011, 10:16 PM   #19
rowan194
Can you try to describe what "sounding like its running on 5 cylinders" sounds like? I noticed today that my AUIII I6 engine note seems to be more rumbly and throaty, actually sounds pretty cool, but I know it's not normal. :(
I've only ever had random split second misfires due to bad leads, never a cylinder that is totally dead, so I'm not sure what it sounds like... guess I'll be trying the sparks and/or injector plugs tomorrow to see what happens.
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2011, 10:19 PM   #20
POELWYK
POELWYK's Avatar
ill upload a vid my au dose not sound like a nromal au and do u get shuttering/ Loss of power??
2001 AU Falcon
Old 14-11-2011, 10:42 PM   #21
POELWYK
POELWYK's Avatar
heres a vid of it when it was sick
http://youtu.be/bPg6oVknSI8
2001 AU Falcon
Old 15-11-2011, 12:00 PM   #22
rowan194
Cheers for that. Hmm, mine is sort of like that, it is chugging a little, but not quite so bad. Once I'm in the car and driving I don't notice any difference, apart from the trip meter showing excessive consumption (got past 17L/100km the other day)
In the past 6 months I've replaced leads, sparks, coil pack, O2 sensor... so I'm thinking by now it's probably something mechanical. :( Or maybe an injector...
When pulling the injector connectors do you stop the engine between each one, or can you do it on the fly?
Old 16-11-2011, 05:53 PM   #23
POELWYK
POELWYK's Avatar
do it on the fly leave it running
2001 AU Falcon
Old 16-11-2011, 05:58 PM   #24
rowan194
Ok, next silly question. How are you supposed to disconnect the individual injectors? It's impossible to pull them all at the injector itself for most of them (fuel rail, air tubing etc in the way) so is there a way to disconnect them individually at the other end of the cable, or do they all feed into a single connector?
Found another coolant leak. *sigh*
