19-11-2011, 05:44 PM | #1 | ||
Hey guys, I'm having a minor problem with the steering in my AU2 Futura.
The car idles a little low (I need to look into this), however when I am doing low speed manoeuvres (ie parking in a car park) the steering chatters / shudders quite a bit. The car also loses revs to be at about 500 or so RPM, so I was wondering if the two were related? The power steering used to have a leak, however that seems to have fixed itself (Fluid was seeping around the seal where you add fluid), and the fluid level is full. Any ideas on how to get rid of this steering shudder / chatter? Thanks, Ben. |
20-11-2011, 01:00 AM | #2 | ||
Bugger!
Sounds like the rack binding internally. Hard to say for sure without seeing it, though.
Whoops, there goes another factory setup! Chop and change - butchering cars since 1990 |
20-11-2011, 10:11 AM | #3 | ||
When in doubt, GAS IT!!
My missus wagon has this problem too which started after the rack was changed and it seems AUs' are more susceptible to chatter than most. I was told of 2 likely causes. The first is air in the system. This can be easily remedied by basically jacking the front off the ground and spinning the wheel lock to lock a few times to push all the air out. The second, as explained to me by an old school mechanic, comes down to having used different fluids to top up with. For example, if there was say dot3 fluid originally in the system and you've topped up with dot4 then there are 2 different types of fluid in the system. They don't blend together but rather intermix so when they pass through the pump it's like thick-thin-thick-thin-thick-thin. At slow steering responses it doesn't cause a problem but during fast wheel action like in a car park where you can go from centre to lock or lock to lock quickly the pump can't cope with the change in fluid properties that fast so it shudders. The only cure is to bleed the system and put all new fluid in and make sure it's all one brand and type. When it was explained to me I thought it sounded logical and made sense as when the wagons' rack was changed, the guy who did it would have just pulled the rack, fitted the new one then refilled the system with whatever fluid he had on his shelf without fully bleeding the system to clear all the old fluid out of the lines, hence intermixing different fluids.
Bushbasher
20-11-2011, 02:33 PM | #4 | ||
I aired out the system and it seems to have helped a bit, and I will look into a fluid change at some time in the near future
Thanks guys |
20-11-2011, 03:58 PM | #5 | |||
I don't have a link to the retrain procedure but from memory you disconnect the battery for a while, then start the engine with 2 minutes each of, - neutral, no additional load - neutral, headlights on, fan speed high, A/C on coldest - drive (brake on), no additional load - drive (brake on), headlights on, fan speed high, A/C on coldest (Remember this is from memory. Hopefully someone else will correct me if I'm wrong.) Basically you're training the ECU to learn the range of loads the engine is going to be under at idle. After I did this you could barely see (or feel) the change in RPM when the A/C compressor kicked in while idling at the lights. It was a massive improvement. |
20-11-2011, 07:17 PM | #6 | |||
20-11-2011, 07:39 PM | #7 | ||
sounds like you need to replace your power steer pressure switch ,as it is also a idle up switch. Basicly it sensors when the steering is moved & causes engine to "idle up"
XC GS OLD SCHOOL MUSCLE Audi A4 S-line quttro Xc falcon Previous fords- xc falcon 500 ,250 x flow 3 speed xc gs worked 250 x flow 4 speed xa Fairmont 302 auto wagon xb falcon 250 log auto 4 door xb falcon 200 log auto ute xc gs project - had to sell :-( xc gs 302 4 speed 4 door xc gs 351 auto 4 door zf fairlane 302 auto zk fairlane 250 x flow carb auto zl fairlane 250 x flow EFI auto xg ute , BA falcon dedicated gas xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5 |
20-11-2011, 09:47 PM | #8 | ||
Got the stereo code (thanks to mum :P for writing it down), steering still does clunk but a fair bit less now, and car idles / runs a fair bit better now
20-11-2011, 09:53 PM | #9 | |||
Giving your throttle body a clean will also pep up your engine a bit, it will definitely be noticeable if you haven't done it for some time. |
