Go Back   Australian Ford Forums > The Sales Yard > Wanted Car bits and other general items
Wanted Car bits and other general items If you want it and it's not in the For Sale section, post it here
Old 28-11-2015, 08:03 AM   #1
el andrew
el andrew's Avatar
Default Territory or BF xr6t or xr8 front brake caliper mounts
Looking for these so I can fit 322mm discs to my BA turbo.
Would consider stuffed calipers that I could recycle the brackets from.
Andrew
el andrew is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2015, 09:24 AM   #2
el andrew
el andrew's Avatar
Sorry should have said I'm in ACT, but willing to pay postage of course
Old 30-11-2015, 12:06 PM   #3
JAZSXY
Parts Fiend
JAZSXY's Avatar
Default Re: Territory or BF xr6t or xr8 front brake caliper mounts
I have a front pair off 2012 xr6t that had done 28000kms. $200+post
Successful Sales With
frenzal56, falconxr, loosecannon, lima_been, bo5ton, Mardk, Chapter Four, leakey, POELWYK, Dman4.0, rayban76, tutor, PridenJoy, Aplito Futura, sbutler, Bosko, storta1, portokatsiki, AUte, 5.8, xxxg, FTW-302, LeadFoot81, Peuty, BillM, Sox, needfordspeed
JAZSXY is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2015, 09:16 AM   #4
el andrew
el andrew's Avatar
Thanks mate. A bit more than I want to pay as I really only need the brackets off them.
Old 05-12-2015, 04:31 PM   #5
MattSAU2XR8
I think these would work at $105 delivered from ebay... Used them on my FR and only needed to bend the brake hose bracket slightly so that the hose didn't have a kink in it.
http://www.ebay.com.au/itm/Ford-BA-B...oAAOSwyZ5Unn0g
MattSAU2XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2015, 06:29 AM   #6
el andrew
el andrew's Avatar
Thanks for that! I had been looking at those initially but was a bit concerned re quality given they hold the caliper on the car. Have they been ok and is there any brand on them?
Old 26-12-2015, 10:15 PM   #7
mattyman
I bought those ones off ebay about 1 year ago, and I believe there is now excessive wear in the guide pin bores which is causing my pads to continuously skim on the discs.
When I recently changed my rotors and pads, I checked the fitment and it seems very sloppy in comparison to what I have experienced.
Does anyone know if front Territory calliper brackets can be used on falcons with 322 mm discs?
Old 21-01-2016, 08:55 PM   #8
el andrew
el andrew's Avatar
I believe they can (which is what I am trying to source still). Or caliper brackets off bf xr6t or xr8.
However I just tried local ford wrecker who said the callipers and brackets are identical between 298 and 322 models, but the steering knuckle where the caliper mounts is different to cater for larger diameter disc.
I'm not sure I believe that.
Old 22-01-2016, 12:19 AM   #9
JAZSXY
Parts Fiend
JAZSXY's Avatar
I put 322mm turbo brakes on my fg xr6 without an issue. Changed calipers and rotors.
i have a front pair of fg 322mm calipers and rotors too btw for $150 if your still in need of a set.
Old 29-01-2016, 07:07 AM   #10
dant1612
He is correct. Territory 322mm brake setup uses the same brackets as the falcon 298mm setup. Falcon 322mm setups require different caliper mount brackets however.
Calipers seem more or less the same, the 322mm variants have a pad inspection window in the top
dant1612 is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2016, 09:41 AM   #11
Xtreme PaintworX
Xtreme PaintworX's Avatar
got a set of std ones of my 2011 GS $120 + freight
including brackets and calipers, hoses etc etc
Xtreme PaintworX is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2016, 08:58 PM   #12
el andrew
el andrew's Avatar
Thanks for that. So if I'm understanding this right, the falcon has the same mount on the car and the same caliper regardless of 322 or 298mm disc. However the bracket between the two (ie the bit in the Ebay link in this thread) is different.
The Territory on the other hand (322 as standard) has same caliper as above, same caliper bracket as 298mm falcon, but a different mounting point on car (which is how the caliper is spaced out to a sufficient radius for the larger disc).
So that means I can fit 322mm discs to my ba, but I need falcon 322 brackets to fit to my existing calipers, NOT Territory brackets.
Can anyone confirm or deny that?
Old 18-07-2016, 08:27 PM   #13
tichman
confirmed, brought in a pair of brackets off ebay, got 322mm rotors and they are on the car. Seem to work ok, just ordered another set for the Ghia I bought two weeks ago.
tichman is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2016, 09:08 PM   #14
el andrew
el andrew's Avatar
Thanks! Haven't bitten the bullet on this yet, but will when my 298mm rotors need replacing.
Old 22-08-2016, 09:34 PM   #15
BigCav
OzFalcon.com.au
BigCav's Avatar
can confirm after wasting an hour today that the rumor of terry brackets being all you need to fit 322 discs is BS, thanks to this thread for confirming
the terry bracket is identical to falcon
BigCav is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2016, 02:33 PM   #16
mikecool84
You mean the terry bracket is identical to the BA/BF standard caliper?
I.e. the territory complete caliper assembly when bolted to a falcon will only suit a 298mm disc and not the 322mm disc.
I.e. if you want 322mm brakes on a falcon, you need Falcon brackets from BF XR6T, BF XR8 and some FPVs.
Gotta be precise, I'm having issues with a wrecker right now with this exact argument.
mikecool84 is offline   Reply With Quote Multi-Quote with this Post
Old 23-08-2016, 02:57 PM   #17
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
That is my understanding also, so yes, correct
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is online now   Reply With Quote Multi-Quote with this Post
Old 23-08-2016, 10:19 PM   #18
BigCav
OzFalcon.com.au
BigCav's Avatar
Yes. Read 3 posts saying terry brackets would let you fit 322mm discs on a falcon but after doing it they were wrong. Bought my bf 322mm brackets on ebay today instead
Old 24-08-2016, 07:28 AM   #19
mikecool84
Thanks Cav,
Please let us know how you go and what the quality of the bracket is like... might be heading down this route soon if I cant get my issue sorted.
Cheers mate.
Mike.
Old 21-01-2017, 01:51 PM   #20
Volgarixon
Thanks Cav,
Cheers mate.
Mike.
Zombie post!
How did the eBay brackets go?
have 322mm Rotors machined and ready to go on BA - need brackets to make it work
Also - has anyone used the FPV 2 piston calipers in place of the K247 PBRs?
2011 Ford SZ TS - Bronze - Petrol RWD
2002 Ford BA XT - *SOLD*
Volgarixon is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2017, 12:44 PM   #21
mikecool84
Originally Posted by Volgarixon View Post
Zombie post!
The ebay brackets worked well, took a standard 297mm BA caliper out to 322 without issues, everything fit like it should and looks like a standard part. I've only put 100km on them since fitment with no issues and they certainly pull the car up well!
Old 23-01-2017, 01:40 PM   #22
Volgarixon
Righto - is the bracket the same as this ?
http://www.ebay.com.au/itm/Ford-BA-B...16.m2518.l4276
Advert says just need these + standard calipers and then 322mm rotors will fit
+ Add on question! Do you have 17" rims or do you need larger rims to fit, its looking like a very tight squeeze for a bigger setup behind the wheels
Old 23-01-2017, 02:09 PM   #23
mikecool84
Yes, they're the ones I bought, same seller even.
yes, all you need is those brackets a BA-FG standard caliper and 322mm rotors. I think you may need front brake lines from BA onwards (not sure, I think I had BA to begin with). +New brake pads (au are different and you'd be a lunatic not to!)
I have S2 17" XR Tickford rims and the clearance is good.... the brakes definitely fill the wheels though!
Old 24-01-2017, 09:10 AM   #24
mhyne
what sort of rotors did you fit ?
I am thinking of either the DBA T2 or T3 (4000 series) slotted.
Any suggestions on suitable pads ?
..and a cheap place to get all these ?
mhyne is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2017, 12:26 PM   #25
mikecool84
Plain jane RDA rotors, nothing special. the extra mass and diameter were enough for my needs. I fitted the 'performance' RDA pads, all up i'm happy with the combo. I haven't used t2 or t3's or performance pads before as they don't suit my driving style.
Anything that fits a BF turbo will fit this setup.
Old 24-01-2017, 09:09 PM   #26
Volgarixon
I know the chap at this place is frequently on here
http://www.racebrakessydney.com.au/p...-t3-dba-42107s
Was doing good prices in a forum sale
I got the pair in the link for the SZ 2011 Territory, mated with Bendix Ultimate
Grabby as heck - good setup
(I did buy elsewhere but that was due to not wanting to wait over xmas)
T2 are os manufactured, put me off a bit
T3 as linked are AU made
in hindsight, that's all hearsay & rhetoric, could be made up!
Old 15-07-2019, 08:06 AM   #27
KJ75
I am in the same situation with my 2014 Falcon XR6, and wanting to go bigger front rotor.
Can I use the caliper bracket from BF / FG XR6T and XR8 ?
KJ75 is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
