Old 20-06-2011, 11:37 PM   #1
347 mont
347 mont's Avatar
Default Walbro install
Hi peoples. I ordered a Walbro fuel pump from Summit and its arrived well and good but thats all I got, the fuel pump.
I didn't get wire harness or sock filter, guess I should of asked So I decided to have a look at what
I'm up for as I've read they're a bit tricky/fidlely to install,but not difficult. First of all what a crap design with
the lid that covers the fuel sender being sikkaflexed on and not screwed on. Then the black plastic collar that screws
the sender down in place was very hard to untighten, but I managed to get it however had to abort the mission
as I had a full tank of fuel. So I haven't got to take a look at the set up but I've also read that the Walbro is
much smaller than the factory pump and thats what make the job a pain.So not being able to have a good
look I tried searching for a "HOW TO" and only found one in the XR6 section, here is the link, is this the same
procedure for the AU, mainly the wire splicing bit of the job?
http://www.fordforums.com.au/showthread.php?t=11301220
Also friends as I only got the fuel pump do I need
This http://www.ebay.com.au/itm/Walbro-Wi...item3c9f5596d0
and http://www.ebay.com.au/itm/Walbro-Pu...item3ca13da458
and because the Walbro is pump smaller do people use this to make it a better fit in the cradle
http://www.ebay.com.au/itm/Walbro-Fu...item3c9f559ef0
I know that sleeve may not work as its for noise and vibration on external pumps but I read somewhere that
someone used it for fittment. Finally if you can't use that sleeve what are people doing for fittment.
I will take pics of my install and try and do a step by step post on the subject. Hope yous can
help answer my questions and I've made it easy for you to understand what I mean
My Walbro GSS294
Losing my patients with unfinished threads
Did the ideas people helped you with work or not!
347 mont is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2011, 04:49 PM   #2
347 mont
347 mont's Avatar
Default Re: Walbro install
Bumpity bump
Anybody?
Especially this question about this sleeve in the cradle
See post #1 for the questions,
Thankyou all
Old 23-06-2011, 04:52 PM   #3
RG
Back to Le Frenchy
RG's Avatar
That sleeve will be a good thing.
PM CAT600, he will be able to help a lot with this as my memory is a little hazy on it.
