19-04-2019, 01:49 PM | #1 | ||
Heys guys i got stuck into to my new project today but when it came to the really badly bubbled up rear glass tinting all i could seem to do was very slowly pick the tint off in small areas.
Its going to take hours doing it this way. I'm trying to get this done myself without damaging the rear demister wires aswell then i'll get some new tint fitted before RWC is done. Does anyone know a good trick for removing old window tint??? I was thinking maybe a heat gun which I do have an old one laying around??? |
19-04-2019, 01:56 PM | #2 | ||
BA/F6 BF/F6 SSV/R TTG
What did GOOGLE say????
BA BF FPV starter button repairs. PM me. Nizpro equipped and Tuned by the BEST in the west Xtreme Ford Tuning 479RwKw Fuel limited, more pumps and power too come. F6#0507 & #0639 Pro racer and Tech expert NIZPRO modifying falcons like Premcar can only dream of , see VIDEO below. https://youtu.be/oa4IfguGQ-A |
19-04-2019, 01:59 PM | #3 | ||
When I had some old tint removed by a specialist, he used steam then it scraped off reasonably easy.
jaydee351 4DV8 |
19-04-2019, 02:09 PM | #4 | ||
19-04-2019, 02:11 PM | #5 | ||
I used a steamer and scraper on my Lancer years ago. Similar to this: https://www.ebay.com.au/itm/11-in-1-...Un5W3b4lFVmeeQ
regards Blue |
19-04-2019, 02:14 PM | #6 | |||
That makes sense actually cos the glue on the back of the tint needs to get soft again before removing the tint. Then i'll try and remove excess glue with Metho or Turps or something??? Tmrws gunna be another busy big one. Thanks Jaydee!!!!!! |
19-04-2019, 02:15 PM | #7 | |||
Regular...with metamusal
19-04-2019, 02:15 PM | #8 | ||
Now Fordless
Yeah you need to get heat into it. Heat gun, steamer, hair dryer should do the trick. Helps if you have someone doing it on the outside while you pull it off.
19-04-2019, 02:15 PM | #9 | ||
Well then, ignorance is bliss. Good luck.
Took me 10 seconds on google to find out 3 methods to remove car widow tint... Just remember FORUM answered questions can come from the uneducated...
4 users like this post: |
19-04-2019, 02:19 PM | #10 | ||
Yes; I copied the wrong link the first time; there always a risk when you have numerous tabs opens and are having several "conversations" at the same time.
regards Blue |
19-04-2019, 02:26 PM | #11 | ||
regards Blue |
19-04-2019, 02:30 PM | #12 | |||
regards Blue |
19-04-2019, 02:56 PM | #13 | |||
I pay it because its given me countless ends of info and help on all my Fords i've owned over the years. Youz are all the ones that are the so called 'experienced/expert' Ford/Car owners??? **** it...dont worry ill sort it out myself....Just like everything else i have to these days. |
19-04-2019, 03:06 PM | #14 | ||
When it’s really cactus I’ve used cardboard boxes cut into sheet for masking, multiple layers of them, and methylene chloride stripper. Then meths and paper towels to clean up. Final clean of the glass with carby cleaner, it seems to remove residue effectively.
19-04-2019, 03:24 PM | #15 | |||
regards Blue |
19-04-2019, 03:29 PM | #16 | ||
3 users like this post: |
20-04-2019, 11:31 AM | #17 | |||
jaydee351 4DV8 |
20-04-2019, 01:39 PM | #18 | ||
Did this about 6 months ago on my EB. Just get or borrow a $50 clothing steamer from K-mart and a few wide razor blades to scrape the excess glue off. **** easy really, took me about 20mins per window. Gotta keep the steamer on the window to loosen the glue up as much as possible, not tear the tint as you pull it and you want most of it to come off onto the tint and not stay on the window
Just like this video https://www.youtube.com/watch?v=L9vzJDUM5Ag Don't use metho or turps for the excess glue. Not good for the plastics, stinks the car out etc. Just keep the glue hot and soft and scrape off as much of it as as possible then give it a wipe over with a little general purpose cleaner and a rag. On the back window you want it extra hot and do it very slowly and carefully so you don't **** up the demister. Run the demister for a while to heat them up, should make it a little easier to get the glue off of them and Use a plastic scraper if need be
1992 EBII Fairmont Ghia 4.0l <---Click for the Gallery! Insta@mooneye_ghia White on bright red smoothies with thick whitewalls. Cruising around to some rockabilly Last edited by Fev; 20-04-2019 at 01:58 PM. |
20-04-2019, 06:40 PM | #19 | |||
Awesome thanks mate i'll be getting stuck into it on monday morning!!!! Now, i'm going out for the night....Hav'nt been out on Saturday night for months!!!!!!! |
20-04-2019, 09:05 PM | #20 | ||
Double post ☹️
20-04-2019, 09:13 PM | #21 | ||
Hire a Wallpaper steamer/stripper from Bunnings if they still do them
Check out cost for hire/purchase |
21-04-2019, 05:49 PM | #22 | ||
A stanley knife blade holder hand scraper and Goof Off did some of the job today.
About $22 total at Mitre 10. Thers actually 2 layers....The factory original, then the aftermarket. AFter scraping most of the glue off with the scraper the Goof Off works great when applied and wipe off the excess glue with a clean rag. Gotta do left rear door tmrw, then slowly, slowly do the whole back window without damaging demister wiring!!! Its gunna take a few hours... |
22-04-2019, 08:00 PM | #23 | ||
I did the territory with a floor steams just the steamer part did a really good job.
23-04-2019, 03:40 AM | #24 | ||
Just wondering....My brother suggested yesterday...Why not just get a whole Excellent Condition rear window from wreckers and get panel beater to fit it when getting paint job done???
Removing the old tint is going to a PITA!!!! How much would wreckers want for a good rear BA-BF window??? |
23-04-2019, 11:51 AM | #25 | ||
Shockwave
Eucalyptus oil gets the glue residue off really well - well it did for me anyway.
Didn't hurt the demister wiring either. Cheers, |
23-04-2019, 12:10 PM | #26 | ||
Au Falcon = Mr Reliable
Hi QUIK6WGN, this link may help (post 63 on), good luck -
P.s, just in case you are wondering, the cheap portable steamer from Godfreys cost me under $30 lol - https://www.fordforums.com.au/showth...1430044&page=3 cheer, Maka
23-04-2019, 01:06 PM | #27 | ||
I removed the rear tint on my old BF wagon, came off reasonably easy, but as mentioned use towels.
Unfortunately, I’d love to share my method but I got it off google, and I’d hate to break your no google rule. |
23-04-2019, 05:43 PM | #28 | ||
Spoke to my wrecker today and thers NO rear windows cos they all get broken when wreckeing the cars.
He reckons he's got a mobile tint guy in the area that removed and replaced his BF sedan tint so ill be dropping in tomorrow after work to get a new jack and handle cheap and i'll also get this mobile guys number and enquire with him. |
23-04-2019, 05:44 PM | #29 | ||
Let me guess....You used VERY HOT water on a towel to make the tint and glue soft again so you can peel it off???
23-04-2019, 05:45 PM | #30 | ||
How much does a screen fitter charge to cut out the back glass? If you ideally need it out for repairs definitely go for two wins in one.
Thread Tools | |
Display Modes | |
