Old 17-04-2019, 10:10 AM   #121
cs123
cs123's Avatar
Default Re: NBN so far, whats your experience?
Originally Posted by devilcv8 View Post
Getting a new copper service from NBN is $300. There are no cheaper options like Telstra had.
As for the reasoning around FTTP and the cost or benefit of over 100Mb services, it’s simple. Everyone on a fibre service can get 100/40 now and faster speeds if required. However, for those on FTTN not everyone can even get 25/5 so forget 100/40 or anything faster. Also active equipment vs passive equipment, guess which one will fail more?
If you are so far away from the node that you are limited to 25mbs, then you're probably up for a substantial bill to upgrade to full FTTP.
I'm on FTTN, I'd love FTTP but happy to not pay the extortion to replace copper with fibre
I love Holdens....
cs123 is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2019, 10:53 AM   #122
EgoFG
Originally Posted by sgt_doofey View Post
I pay for 50/20. I get approx 32/11.
Sorry, Sarge, maybe it is already on record somewhere. How are you connected to the NBN ? FTTP ? FTTN ? - if so how far away is your node ? Are you Urban, Suburban, rural or Townie ?
EgoFG is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2019, 11:03 AM   #123
sgt_doofey
sgt_doofey's Avatar
FTTN unfortunately.
Not sure where the closest node is but can't be too close with those numbers.
My old house which was about 100m from the node saw a sync speed of about 44mbps.
Cheers,
Sam.
sgt_doofey is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2019, 12:04 PM   #124
Fed
I have to say I've not noticed any difference between my old adsl2 (15 Mbps) and my new broadband (45 Mbps), both tested at speedtest.net.
I did get some netflix problems when my speed dropped to 4 Mbps due to a line fault.
My only complaint is 'weak' wifi on the new gateway the ISP supplied me with, silly me thought being new it must be better than the old one.
So the NBN has given me no noticeable speed increase but taken away some wifi, I was better off with adsl2 and a modem that had better wifi.
Fed is offline   Reply With Quote Multi-Quote with this Post
Old 17-04-2019, 01:35 PM   #125
Mechan1k
Mechan1k's Avatar
I stuck with my old ISP Modem .... as it only used 2.4Ghz WIFI .... I have a 3-level split home ... and the modem is downstairs at one end of the house. I reckon I'd have issues if i went with the new modem with 5Ghz ... as coverage is less ... but bandwidth is higher.
It works for me at the moment .... so no complaints.
Old 18-04-2019, 07:55 AM   #126
devilcv8
I was explaining the benefits of fibre and dispelling some common myths.
Personally I’m on FTTN and am close enough to get 100/40 and have a maximum of 117 residences that can connect. Throw in a lot of elderly and local node congestion isn’t an issue for me.
Still hate this model of NBN due to its limitations
devilcv8 is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2019, 07:58 AM   #127
devilcv8
I’d suggest a quick fix is connect to 2.4Ghz wifi on your router rather than 5Ghz, but to get the benefits of faster speed, installing a meshed wifi network is cost effective and gives you the speed benefits of 5Ghz
Old 18-04-2019, 08:37 AM   #128
EgoFG
I Hate being bound by an ISP's router.
I use a wifi router connected as a switch (No DHCP server).
I want to be able to VPN to my home from a remote location, and VPN to a remote location from my home router.
I want content filtering on my router based on periodically downloaded rules.
I do not want an archaic and/or consumer piece of HW between me and the world.
Draytek support said that they could help out by replacing the ISP (Optus) supplied router, and putting it in a DMZ to keep the phone going ... this is my plan ... however I have some 'flux' in my work life that may delay this.
Old 18-04-2019, 08:42 AM   #129
Fed
I switched off the 5 Ghz wifi already because non of my devices have it.
Now I'm looking at wifi extenders but to be honest I think there's something else going on like a dodgy netcomm wifi router.
Old 18-04-2019, 08:57 AM   #130
sgt_doofey
sgt_doofey's Avatar
I use a Fritz!Box for my modem.
Wouldn't use anything else now.
Cheers,
Sam.
Old 18-04-2019, 09:25 AM   #131
prydey
Rob
prydey's Avatar
Same.
UA2 TREND 4WD BI TURBO
Old 18-04-2019, 01:45 PM   #132
EgoFG
Do not use a Wifi Extender !
Wifi Extenders take multi devices and channel it via a single wifi connection to the master
Most will give you another SSID (not zero handoff like we are used in on mobiles)
Best option is get a wifi router, ideally one that will step frequencies if it finds noise/competition (Netgear NightHawk is very good)
Something with Multi external aerials
Look at your placement - if you have some ethernet cabling in your home is is a great advantage (I have Cat6+ to all TV points, and some bedrooms)
Check your area using an app like "Wifi Analyzer" in Android Store by Kevin Yuan - might see that your neighbour is blasting you with a strong signal.
Old 18-04-2019, 05:54 PM   #133
MITCHAY
I've got my letter advising NBN will be ready mid June. I'm currently paying $59.99/mth for unlimited ADSL2+ and getting north of 10mbps+ consistently. Router currently showing 14.5mbps.
The lowest they are offering is NBN12 unlimited for the same price but have NBN50 which is an extra $10/mth.
I live close to both a node and the exchange so I hope I would get a decent speed on NBN50. Problem is you don't really know until you get it.
MITCHAY is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2019, 06:38 PM   #134
Burnout
Falcon RTV - FG G6ET
Burnout's Avatar
Wirless here for about 18months. It works, a bit slow, however does not work in rain, slightly heavier rain stops it completely.
Good thing is we're in drought at present.
BAII RTV - with Raptor V S/C.
RTV Power
FG G6ET 50th Anniversary in Sensation.
While the basic Ford Six was code named Barra, the Turbo version clearly deserved its very own moniker – again enter Gordon Barfield.
We asked him if the engine had actually been called “Seagull” and how that came about.
“Actually it was just call “Gull”, because I named it that. Because we knew it was going to poo on everything”.
Burnout is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2019, 07:06 PM   #135
fofo
My adsl 2, 30 years ago was faster than my 50 mbps nbn plan im on now
fofo is offline   Reply With Quote Multi-Quote with this Post
Old 18-04-2019, 07:37 PM   #136
henry351
henry351's Avatar
I have been on FTTP with TPG 100/40 for nearly 3 years now. I changed the generic router they send out to a TP-LINK Archer C9 which made a huge difference.
Thats at 6.36pm
2011 Fg GS Ute 5.0 Manual.
2015 SRT Jeep 6.4 Hemi.
henry351 is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2019, 04:28 PM   #137
kaniSS
BIG MEMBER ;)
kaniSS's Avatar
Originally Posted by deesun View Post
My area is on cable and we don't get NBN till next year, bit worried ours will go backward. Just gotta wait and see.
I'm in the same boat. Currently sitting on 80-90mb/ (9mb download per second) on cable and I don't want it to go backwards.
The slow rollout sort is working in our favor. God knows why they would cut this awesome cable and replace it with inferior NBN. boggles the mind.
2010 FG XR6T, EGO, MANUAL, LUXURY PACK.
kaniSS is offline   Reply With Quote Multi-Quote with this Post
Old 18-05-2019, 03:17 PM   #138
Bill M
Bill M's Avatar
NBN connected via HFC in the last 2 weeks. Went with the 46 Mbps plan bundled with phone and Fetch TV. Speed tested at 46Mbps and is an improvement over ADSL2 we had previously.
All good.
AUII XR6 VCT ute
20 years and still going strong!
Old 18-05-2019, 03:43 PM   #139
Got our NBN modem sitting on the dining room table, it’s been there for a week, happy enough with what we’ve got currently but then, we didn’t get home internet until last year so it’s a non issue anyway..
Old 18-05-2019, 09:03 PM   #140
nuthin' fancy
Lyminge, Shepway, Kent
nuthin' fancy's Avatar
Moved from ADSL to NBN 18 months ago.
Can't tell the difference.
Mel Brooks sums it up best;
"Comedy is when you fall into an open sewer and die, tragedy is when I get a paper cut"
nuthin' fancy is offline   Reply With Quote Multi-Quote with this Post
Old 05-07-2019, 07:06 PM   #141
MITCHAY
I had the NBN connected today on FTTN and am very happy that it far exceeded expectations despite all the horror stories.
Bonus is with the new router, the Wifi doesn't cutout when the microwave is on so can continue watching Foxtel when cooking
I picked the TPG 50 plan and have got it up over 47 down and about 20 up.
Old 06-07-2019, 07:15 AM   #142
burnz
VFII SS UTE
burnz's Avatar
General Note:
A lot of computers HDD are limited to around 80/60 that is where SSD will improve performance...
I don't often hear the sound of a screaming LSX.
But when I do, So do the neighbours..
GO SOUTHS
burnz is offline   Reply With Quote Multi-Quote with this Post
Old 06-07-2019, 02:49 PM   #143
Just moved from Cable to HFC with Telstra and my download speed has fallen from over 100 MBPS to less than 50 MBPS. Help desk has gone from polite and perfectly understandable English speaking Manila to unintelligible broken English with thick Indian accent and rude patronising attitude so I am have no luck getting it sorted. I am thinking of giving Foxtel broadband a try.
Old 06-07-2019, 03:13 PM   #144
Previously:
PING ms
12
DOWNLOAD Mbps
113.32
UPLOAD Mbps
5.02
Now:
Ping
10
ms
Jitter
2
ms
Download
48.0
Mbps
Upload
18.2
Mbps
Old 06-07-2019, 11:27 PM   #145
devilcv8
Originally Posted by aussiblue View Post
Now:
Ping
10
ms
Jitter
2
ms
Download
48.0
Mbps
Upload
18.2
Mbps
sounds like you are on a 50/20 NBN plan not a 100/40
Old 07-07-2019, 09:54 AM   #146
Yaw
Ford Fanatic
Yaw's Avatar
On cable/hybrid NBN HFC
Everyone is entitled to my Opinion
2007 Territory TX SY RWD Ego
Yaw is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2019, 12:22 PM   #147
Yes; I should be on the 100/40 but all the Telstra call centre idiots want to talk about is if my modem is plugged in correctly and working. I don't think their modem tests are going to fix it.
Old 07-07-2019, 08:14 PM   #148
b0son
Is that the plan you requested?
Check your address at https://myrepublic.net/au/ it will give you a more accurate speed estimate than nbnco give out.
b0son is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2019, 08:36 PM   #149
sgt_doofey
sgt_doofey's Avatar
Should go with an ISP that actually cares about their customers and knows what they're doing when it comes to troubleshooting, not Telstra or Optus.
Sent from my SM-G900I using Tapatalk
Cheers,
Sam.
Old 08-07-2019, 08:57 AM   #150
Maka
Au Falcon = Mr Reliable
Maka's Avatar
I know your pain aussieblue, wait till they tell you to make a record/order of when your modem drops out for a day or a week...
Then after the 2nd modem telspray will say we will send you another 3rd modem but the sound of crickets & smell of failure from their side means it actually may not turn up either..
I know its not what hopefully is going to be your outcome aussieblue but it was my great telstra experience & its still a pain half the time as we are still with them (dont ask or say peoples please lol )
cheers, Maka
