23-04-2005, 07:23 PM | #91 | ||
Boss for Go, L98 for Show
Hi Guys,
Mine is built 7/2001 sounds like mine is included. Yes i have noticed a weld on the drivers side of the steering rack. I was alittle worried about this but seems thats the fix. Anyone recommend a good dealer in Melb??
Quote: Jeremy Clarkson "The fact of the matter is this, from just about any angle this is an impossibly pretty car" |
15-05-2005, 10:57 AM | #92 | ||
Bought my S1 (02/00) wagon in Oct 03. When I test drove the vehicle there was some noise from the steering when turning the steering wheel. The idler pulley was also noisy. The work was supposed to have been done before we took delivery, but wasn't. Booked the car in for these jobs to be done and they had re-tensioned the rack and replaced the pulley.
When the recall was issued I was concerned because the rack had been re-tensioned and had the recall done asap. There have een no problems since. I haven't looked to see what was done but will at the next opportunity. Steve |
16-05-2005, 05:18 PM | #93 | ||
Ford a couple of recalls of Ford Falcons (AUs mind you)
http://www.recalls.gov.au/search_rec...Submit2=Submit
16-05-2005, 05:30 PM | #94 | ||
Problem: Steering rack mounting stud may loosen
Make: Ford Model: AU Series 1 & 2,Falcon Forte,Futura,Fairmont,Fairmont Ghia,Fairlane,LTD,FTE,Ute Variant: Date Range: 1 June 1998 to 22 May 2001 VIN Ranges: Status: Active Defect: Possibility that inappropriate servicing of steering rack retaining hardware may affect the integrity of the steering rack mounting stud. Overtightening of the steering rack mounting hardware may degrade the thread locking compound on the stud. Consequences: This condition may allow the stud to loosen. In extreme cases the stud may detatch from the crossmember. Corrective action: Ford dealers will apply a weld to the end of the stud to stop it coming out if loosened. Notif. Date: 17/06/2004 DOTARS No.: R04/075 Supplier Name: FORD Campaign No.: SRCC300
28-05-2005, 05:54 PM | #95 | ||
GT-P #0336
I got mine done yesterday. No problems. Steering feels fine.
2003 FULLY OPTIONED MERCURY SILVER BA GT-P BUILD #336
REVERSE CAMERA - SAT NAV - PIONEER SUB & AMP - SUNROOF - DVD PLAYER - CUSTOM DUAL EXHAUST ~Tuned By Bluepower Racing~ |
28-03-2006, 07:42 PM | #96 | |||
Posts: n/a
29-03-2006, 01:00 PM | #97 | |||
Drought Breaker
holdon perhaps you could read a post completely before flaming a member that has been here and contributed a heck of a lot more to this forum than you have in your five (5) posts! Constructive critiscism is widely and easily accepted whereas being a fr*gging know it all straight off the bat isnt taken at all. /rant
2002 AUIII XL W/- Custom Tray
ALL COUNTRY: SW Platt Mccann 5 Poster, GME 4706 7' Whippys, Uniden UH015SX UHF AND Scanner combo, Narva Taurus Bull lights, Hawk Grille, Series II Pursuit Side Skirts, Stickers on the back window and more eartags than a mob of cranky angus ALL GO: XR6 VCT donk and ECU NO MORE!! Now even MORE fun with 200kw XR8 and 5 speed, Tickford Cluster, 3.45 LSD, full custom twin system w/- 3" chrome angle cut tips : |
29-03-2006, 08:07 PM | #98 | ||
boys all they do is put a tack on the end of the bolts to stop them from comeing out all u have 2 do is grind off the tack if u want 2 replace your rack and use new bolts it,s simple
29-03-2006, 08:19 PM | #99 | ||
power steering fluid on the rack? They don't touch your power steering pump to do the recall. They put it on the hoist and spot weld 1 bolt thread. Sometimes they spot weld both bolts.
29-03-2006, 08:26 PM | #100 | ||
they call me Tibbo
There is alot of mis-imformation here.. Yes they put a tac on the thread of the rack STUDS, to stop them working loose. To replace the rack you undo the nuts on the rack side and slid it off.. THe studs can stay there
30-03-2006, 09:33 AM | #101 | ||
The Bolt was removable in the OLD ones. The job to be done is a quick weld. Thomson Ford has done MANY of them and I don't recall seeing any bad ones? You should have it fixed as it is a structural thing. Wouldn't like the Rack to come loose now would you?
30-03-2006, 06:54 PM | #102 | |||
Posts: n/a
30-03-2006, 07:43 PM | #103 | |||
You are may know about cars but you certainly dont know about the people that own them.
30-03-2006, 08:36 PM | #104 | ||
Fantastic Plastic
eeewwwww :( - this is gettin ugly ,
HOLDON ...seriouslly though - alot of people / nearlly everyone / including myself are/is still learning new things about cars all the time , they are changing all the time , no matter how much you know there will allways be someone who knows more , and it doesn't help to ram facts down peoples thoats as if everyone is stupid ! - people in this forum are here to learn and share knowledge in a positive way - not to be literally named " dipsh|t" for asking questions or maybe even been a bit off track.. c'mon now dude - your only 7 post into this forum , im new here too but don't just diss people like that plz ..ty .. end of my comments - i dont want arguements plz ;) .
------------------------------------------------------------ :eclipsee_ |
30-03-2006, 11:34 PM | #105 | ||
Club Moderator
i noticed today after having my xr8 on the hoist to fix the engine mounts, that my rack has had the recal done on it. (always wondered what the sticker near the door hinge was for ) anyway, all it has done, like most have said was a dab of weld on both bolts. it had no effect on the mechanic removing my rack today, so i guess from a safety point i would get it done. i guess if it only takes a few minutes to do, then tell the ford dealler you will wait for car and watch them do it. just as a piece of mind thing i guess. but i really cant see how dabbing 2 bits of weld on the bolts will cauz any other damage.
just my 2 c worth.
2001 T2 TS50 2002 T3 TS50 2006 FPV GT Racecar 2010 FPV F6 Ute 2016 FGX XR6 Sprint 2020 PX3 Ranger Wildtrak |
30-03-2006, 11:49 PM | #106 | ||
Fantastic Plastic
From applying a dab of weld you can damage the battery and electrical goodies if not disconnected before welding (earthing the overwhelming welding amps into the battery etc etc), heat from the weld traveling through the steel could melt seals etc etc , but i couldn't see a 'dab' of weld in that position causing that much heat that its gonna travel to extreme lenghts and melt seals unless u put a 'slug/snail' size weld on the thread or whatever.. i undecided - about all the advice i can offer on that 1
31-03-2006, 04:50 PM | #107 | ||
Back in a Blue Oval
Had mine done last week, same thing 2 welds... almost unnoticeable. i had to look closely
'13 Territory TX Diesel RWD. The Family Bus '08 Mitsubishi Pajero. The Off-road Machine |
31-03-2006, 05:17 PM | #108 | ||
Barra Turbo > V8
mine was done in june 04 confirmed by ford but i havnt a sticker :(
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels |
13-03-2012, 02:30 PM | #109 | ||
Highway Taxi
An old thread i know but................I had mine done years ago but now the bolt where the crossmember goes in is stripped and the weld broken. Had the car at Pedders yesterday looking at it. Back to Ford we go and there is no way i am paying for it. I called them and they are looking at it on Thursday. They didn't know what to do. Has anyone had this problem?
Close only counts in Horse Shoes & Hand Grenades. :evil_laug |
14-03-2012, 11:54 AM | #110 | ||
Flairs - Truckers Delight
Sleeperau, from memory I had one of my bolts break. I just replaced it with a regular high-tensile bolt from a fasteners place. That was 4 years ago, no problems since.
14-03-2012, 08:32 PM | #111 | ||
Highway Taxi
Thanks for that, I have not got under and had a look yet but apparently where it goes into the crossmember is stripped out . I can't get Ford to look at it untill Tuesday due to work. I used to work across the road from them but now Ii am 30 minutes away. I believe it is their problem as they did the recall. It needs some bushes and other gear as well so one less fix for me is good.
30-01-2016, 10:19 PM | #112 | ||
My stud where it goes into the crossmember is either strioped or broken thr loctite so thr bolt has come forward and the weld at back is now butted uo against the crossmember how to fix ???
18-06-2017, 11:16 PM | #113 | ||
I know old thread, but does anyone know how they fixed it with the B series. As we know same alloy c/member.
