16-10-2006, 05:10 PM | #1 | ||
Walking with God
Hi guys,
I may need to change my tail shaft (funny vibrations at highway speeds - vibes felt in transmission tunnel). Both the auto trans guy and my mechanic suggested changing one over to see if the vibes cease. Both blokes also agree that it's not wheel bearing noise, OR transmission vibes, OR diff related. The trans guy suggested using an EF/EL one as they are much more robust. This is because I changed the shaft late last year, but some of the vibes persisted. Do they change straight over? My understanding is that they do, but the EF/EL ones are heavier and more robust. Will using a heavier shaft have any adverse consequences on the other drivetrain components? Just in case, my mechanic is bringing 2, one E series and an AU one, just to be sure. What are your thoughts? Cheers everyone. GK
16-10-2006, 06:43 PM | #2 | ||
what condition are the uni joints in? around what speeds do you get these vibrations? i know you say highway speeds, but 100, 110? also, what revs is the car doing?
It can be determined if it's a driveshaft problem or something else a bit easier this way....find out what revs it's at when the problem starts, then stop the car, put it in first and speed up to the same revs, same with second and so on, if the vibe is still evident at the revs it's not a driveshaft problem as in the lower gears it's spinning faster than at highway speed in overdrive |
16-10-2006, 07:05 PM | #3 | |||
Walking with God
Vibrations occur at around 96ish kays. Car is doing about 1600ish revs. I've already done the test you're referring to. Now I've answered your questions, will you answer mine? LOL! Is the tailshaft compatible? : GK
16-10-2006, 07:07 PM | #4 | ||
im not sure if it would be long enough....then again if an auto from an ef/el can fit no probs into an au, and vice versa, then it may just work... from readings on here the manual boxes are shorter, but im pretty sure the auto's should be the same length...i'll have a look and see what i come up with
16-10-2006, 07:33 PM | #5 | ||
one more question gk, wagon or sedan that's playing up?
16-10-2006, 07:38 PM | #6 | ||
another post lol, it's looking like they should be the same, as far as fitting goes anyway, the same part numbers are showing up in au and el in the parts database, the other thing you may want to check, im sure the tranny guy and mechanic will anyway, is the number of splines on the trans and the driveshaft, as far as length goes i'm pretty sure it has a bit that can hang out the back of the box anyway...
so from what i can see, as far as length goes you should be ok, just the splines is all i'd probably really worry about... |
16-10-2006, 08:28 PM | #7 | ||
gday buddy
i have a series one au xr8 ute and i have had some issues with vibrations. Now when i bought the ute 2nd hand it had 75 000kms on it and it has a modified setup. IT was a 2 piece tailshaft from a commodore with a centre mount welded in the tunnel. When i realised, this i rang the original owner and he said he changed it due to vibrations at higher speeds. Now just recently i have changed the set up and got a new tailshaft through ford (alum) for free through a mate. it turns out that it didnt fit anyway as it was for the auto, not the manual. It was about 2'' too long. I couldnt find anyone to shorten and weld the tailshaft, scared of tig welding i guess. So i got a steel one made for $500 through a mob in condell park and it has turned out good now, no vibrations any questions just email me on mrphantom6@hotmail.com |
16-10-2006, 10:52 PM | #8 | |||
Walking with God
GK
16-10-2006, 10:53 PM | #9 | |||
Walking with God
If it's the same part number in the database, it should be ok I'd think! Cheers, GK
18-10-2006, 07:02 PM | #10 | ||
Are you sure its not brake shudder?
18-10-2006, 08:40 PM | #11 | |||
Walking with God
GK
18-10-2006, 10:24 PM | #12 | ||
has the tail shaft been off for any reason recently?
had any kangas,wombats,dogs, or humans bouncing up against the tail shaft recently? :dr_Evil: ,sorry had too ask,..... had anything done to your baby just before the vibes occured? |
19-10-2006, 06:30 PM | #13 | |||
Walking with God
I can't recall hitting anything but you never know. They are very light and don't take much to bend I know. Cheers, GK
19-10-2006, 06:51 PM | #14 | ||
have you had any luck getting an e series one tried yet?
19-10-2006, 08:44 PM | #15 | |||
Walking with God
I'm still a little concerned about the extra weight of the EF/EL unit doing damage, but I'm sure he'll advise me on that. In any case, I think he's got an AU unit as well. I really should get him to change the uni's while he's at it. Couldn't hurt IMO! Let you all know tomorrow, hopefully! GK
19-10-2006, 11:06 PM | #16 | ||
i can't see the weight affecting it that much, i can't see any of the other components being made any weaker between e series and au...i think all the weight might affect is your quarter time lol...good luck anyway, i hope it all goes well
20-10-2006, 12:29 AM | #17 | ||
if its a replacement tail shaft from a wrecker they can get banged around enem newey have been known to get dropped on occasions , or dropped by mechanic might need a balance , diff pinion ok??
20-10-2006, 12:37 AM | #18 | |||
Walking with God
GK
