Old 14-11-2010, 04:56 AM   #1
Falconxr68
Falconxr68's Avatar
Default Fogged up windows
Is there a way to stop the drivers side window, passenger side and the two rear windows from fogging up in raining weather? Its not very convenient to wind down the window when driving and neither is constantly wiping it with your hand.
The rears are important too because they are essentially your blind spot.
So my question is, how do you deal with fogging up windows other than the front and rear (which most cars have demisters)?
**MODS PLEASE CLOSE THIS THREAD, ITS AN ACCIDENTAL DUPLICATE!
Falconxr68 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2010, 06:00 AM   #2
Valid8
COOGES
Valid8's Avatar
Turn on your A/C.
COOGES- FG 50th ANNIVERSARY XR6T MANUAL / 1965 BUICK RIVIERA
Valid8 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2010, 06:56 AM   #3
The G6ET Spot
Tell your girlfriend to stop breathing so heavy when you go parking
The G6ET Spot is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2010, 07:13 AM   #4
wrongwaynorris
wrongwaynorris's Avatar
Yes turn on your AC as the dehumidifier / dryer will stop fogging .
wrongwaynorris is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2010, 12:56 PM   #5
ebxr8240
Performance moderator
ebxr8240's Avatar
Check for water leaks or wet carpets, boot etc ?
Sounds like too much moisture in vehicle ??
As said....
Heater on high with A/C , fan on high...
Daily driver GTE FG..
Old 14-11-2010, 01:36 PM   #6
geckoGT
Ich bin ein auslander
geckoGT's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always level headed and i notice him being the voice of reason when a thread may be getting heated
I get this a lot with the QLD humidity when driving home at night. Something I found that worked well is get the Rain X exterior glass cleaner (in big yellow spray bottle) and clean the interior glass well with that.
I tried the fog X but it was too much of a stuff around to apply and ended up patchy, the rain x cleaner was easy.
Growing old is compulsory, growing up is optional!
geckoGT is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2010, 02:52 PM   #7
T3man
T3man's Avatar
The only solution I can offer is ..... grow old ... worked for me ... and now I can't get a woman in the back with me.
Seriously though you just need to run your AirCon simple as that. You will find sometimes that full cold will clear the windows quite quickly ... then you can reset it to your comfort level for a while ... then do another cold boost as required.
Oh how wonderfull CC air con is! Set it on 22 and forget it LOL.
PS. Oh, and don't use Fog X - useless stuff. Rain X ticks all the boxes though.
Old 14-11-2010, 03:36 PM   #8
Falconxr68
Falconxr68's Avatar
OK will try the AC again, but I'm sure I've done it before... doesnt really help the sides.
Old 14-11-2010, 03:43 PM   #9
Ben73
Ben73's Avatar
My old car had demisters on the front side windows, as in it had air vents on the door aimed at the windows.
Ben73 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2010, 04:33 PM   #10
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
If you set the air flow to foot well and windscreen and leave it there then set the temp and fan speed to whatever is comfortable for the moment (with the A\C activated), the windows shouldn't get a chance to fog up in the first place. As soon as you jump in and start the car the A\C kicks in and puts dry air into the cabin and draws out any moisture before it becomes a problem. The only time my missus' wagon fogs up is if the A\C button or fan has been switched off.
Bushbasher
MINE- AUII Forte
Old 14-11-2010, 04:49 PM   #11
cjf
GT Hardcore
cjf's Avatar
As said put it on when you start the car, plus seeing your in Melbourne set the heater to warm with the a/c on and direct your side vents towards the windows.
BF GT - 6spd ZF Auto - 292.8 rwkw 1/4 mile 13.385@ 108.32mph @ Willowbank 5/03/11. in Qualifiying STREET SERIES ROUND 7
http://www.fordforums.com.au/showthread.php?t=11295036
Cragsted Race Engines -http://cragsted.com.au/
BPR CAI , PACEMAKERS 4-1, BALLISTIC 100cell RACING CATS, CROW CAMS GTP,
K LINE , XFORCE ,PSI VALVE SPRINGS, MANLEY H BEAMS, SRP PISTONS & RINGS, ACL RACE BEARINGS MELLINGS BILLET OIL PUMP, POWERBOND UNDERDRIVES, TT1-160 THERMOSTAT.
cjf is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2010, 05:16 PM   #12
Falconxr68
Falconxr68's Avatar
Bushbasher
Ok thanks for that, sounds like a plan
Old 14-11-2010, 06:10 PM   #13
GreenR
GreenR's Avatar
try Fastwax on the inside of your windows. Helps with fogging. It won't work %100 and completely stop fogging up but is much better than normal
GreenR is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2010, 08:06 PM   #14
Elks
Elks's Avatar
these boys a re right. Warm dry air will do it.
Oooh baby living in Miami....
Elks is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2010, 11:04 PM   #15
nb_351
building the xe...
nb_351's Avatar
what if like my fairlane you dont have ac haha, its windows down even in the rain
slowly but surely fixing up the king of the road
WANTED
P5 ltd/landau taillight centre panel
nb_351 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2010, 11:19 PM   #16
atec77
Cut Potatoe Cut Potatoe
rub it on the window inside
