Old 25-01-2012, 06:18 PM   #1
shayne93
66 Mustang
shayne93's Avatar
Default Can purge solenoid be bypassed?
The charcoal canister purge solenoid on my ute has broken and giving me an annoying vaccuum leak.
Can I unplug is and bypass it by running a line (where the solenoid hose usually goes in) from the manifold into charcoal canister to stopp the fuel smell.
the vaccuum leak sound from the solenoid (it broke on the canister side) was always on, from start to stop, so I think the solenoid was always on anyway.
shayne93 is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2012, 06:37 PM   #2
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
Default Re: Can purge solenoid be bypassed?
I'm not 100% sure here, but I think that if you have it open to the manifold during open loop fueling (eg, Wide open throttle), you will then upset the target air/fuel calculations. Normally this solenoid is off during WOT. Purge solenoid is usually open while engine is under Closed Loop control (idle, cruise) and the o2 sensors are providing feedback to the ECU for corrections. I don't know how much difference it would make anyway. Someone like 5.0ED might be able to clarify this for you, or send him a PM.
-Craig
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2012, 06:39 PM   #3
5.0 ED
5.0 ED's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with sound technical advice. Technical Contributor: For members who share their technical expertise. - Issue reason: has helped a number of AFF members with their cars, particularly with EEC tuning
yeah i looked at this, the canister purge is suppost to only open during closed loop at which the o2 sensors pick up the extra fuel and correct the mixtures with the short term fuel trim's.
Should be fine just blocked off. But i would still try sourcing another unit from the wreckers, should be very cheap they are thrown out a lot....
T058 TS50 - 302 AFR165, Victor 5.0, Custom Cam, tuned by me, 245.6rwkw 329rwhp at 6800rpm.
5.0 ED is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2012, 06:49 PM   #4
crakrz
T3 TE50 Blueprint
Only 2 mins later and he appears........LOL
Old 25-01-2012, 07:04 PM   #5
5.0 ED
5.0 ED's Avatar
I heard my name mentioned hahahaha...
Old 25-01-2012, 07:52 PM   #6
BHDOGS
Could it not be tuned out or disconnected and the tables redone
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2012, 07:55 PM   #7
shayne93
66 Mustang
shayne93's Avatar
I've got a V8 nc fairlane in a paddock, would the solenoid off this fit/work
