07-01-2012, 07:39 PM | #1 | ||
not here much anymore
After some confirmation, I am about to order an intake pipe (doing it cheap through work just to see how I go with it) and I am planning on getting a 3" ID pipe with a 60deg bend, and a couple of 3" silicone flexi joiners.
I have 65mm TB and also the G&D Airbox setup but the bit that concerns me is the bend, is 60deg the right angle for our intakes? If someone could confirm please.
RAM 1500
07-01-2012, 10:57 PM | #2 | ||
I would say 60deg is about right although I am unsure of what angle the intake runs into the G&D box.
Edit: oversize picture fail! Last edited by Cúl-Báire; 07-01-2012 at 11:09 PM. |
07-01-2012, 11:00 PM | #3 | ||
Thanks, Ive seen that pic before. I'll order this gear in and see how I go. Less than $100 lost if it's no good anyway. I also have a mate who is a welder and very handy with this sort of stuff if it doesnt end up working the way I want it to (as simply as possible!)
RAM 1500
09-01-2012, 10:34 AM | #4 | ||
I'm very interested to see your end result, and if it works would like the part numbers that you've ordered.
HIS: AU III XR8 220, 5 speed manual, short shifter, MSD coils, ACRON CAI, Front 330mm brakes with C4 calipers and braided lines HERS: BA Fairmont, vapour injected LPG I reject your reality and substitute my own! |
09-01-2012, 10:39 AM | #5 | ||
Boost is here!!
60 degrees is spot on Austin.
STREETBUILT RACING '99 XHII XR8, 363w, GT4508R on 16psi, E85, C4, 910rwhp - ET coming soon! '78 XC Falcon 500, Desert Gold, 351w, V2 on 16psi, E85, C4, 9" - 10.15@132mph! |
09-01-2012, 11:04 AM | #6 | |||
cheers Shaun Current SY FPV F6X Territory #214 Previous FG MkII G6E Turbo built by Heinrichs Performance and Tuning BFII FPV TORNADO #0021 351rwkw - Heinrich Performance and Tuning "Milk is for babies. When you grow up you have to drink beer" - Arnold Schwarzenegger |
09-01-2012, 12:22 PM | #7 | ||
Thanks Jeff, I will update when parts come in, alll easily available too. I only have a slight concern that the pipe I've got coming may not be quite long enough to go from TB to MAF but if it's not I have a backup option that should still work out ok.
Other than that tap a hole for IAT and it should be all good.
RAM 1500
09-01-2012, 02:56 PM | #8 | ||||
Back to Le Frenchy
A section of concertina connection piping will fix this.
09-01-2012, 05:17 PM | #9 | |||
RAM 1500
10-01-2012, 12:49 PM | #10 | ||
T3 TE50 Blueprint
I have done it slightly different to most, some will like it, some won't. I cut the elbow of my original intake tract which then still retains the original ACT sensor position, then used a straight section of 75mm exhaust, painted matt black. One silicone joiner put into very hot water to expand over the MAF and 2 extra clamps, all done. I basically copied this idea off Jimt3te50's T3 years ago.
10-01-2012, 05:39 PM | #11 | ||
Craig can you please stop posting pictures. Your engine bay is far too clean.
RAM 1500
10-01-2012, 08:37 PM | #12 | |||
Now With 2 Cylinders More
WAYYYYY too clean! I eat from plates that arent that clean! |
10-01-2012, 08:49 PM | #13 | ||
T3 TE50 Blueprint
Aw shucks, you fellas are so kind.
10-01-2012, 09:43 PM | #14 | |||
RAM 1500
10-01-2012, 10:04 PM | #15 | |||
T3 TE50 Blueprint
12-01-2012, 08:55 AM | #16 | |||
RAM 1500
14-01-2012, 10:38 PM | #17 | ||
I've made a little bit of progress this afternoon.
This is basically a bit of a dummy run of how the final product will fit up. I made this by copying crakrz' idea of cutting the elbow off the factory pipe, and using a piece of 3" pipe to replace the corrugated part. The silicone joiner at the MAF end is an off the shelf part and fits over the MAF and the pipe easily. So far this has cost less than $20 and I don't know if it's just me but I do think throttle response has improved a bit, but the primary aim of this is aesthetics not performance. I'm not happy with where the IAT sits so in the final result it will be underneath so it can't be seen. The 60deg bend has arrived at work but it's a lot shorter than I expected so I will need to order some straight section and have it welded. I have a mate who is a welder who is going to give me a hand with it so once it's done I will do a full list of part numbers for those who want to do the same thing. Apart from the welding, all of the parts I am using are available through Autobarn (my work) but other shops would have something similar.
RAM 1500
14-01-2012, 11:13 PM | #18 | |||
sliding by you...
Well done, looks fairly neat IMO, maybe something I should consider, how much of a difference did it make with regards to induction noise? +1 for craigs engine bay!! you know you are allowed to drive the car too mate!!! |
14-01-2012, 11:19 PM | #19 | |||
As for induction noise to be honest I think it actually might have quietened it down, but I am getting more crackle on downshifts and as I mentioned I think there's a tiny bit more throttle response. Bit more driving to really test it out is in order I think.
RAM 1500
15-01-2012, 12:45 AM | #20 | |||
sliding by you...
Worth it just for the throttle response alone i reckon! good on ya... |
15-01-2012, 08:23 AM | #21 | ||
T3 TE50 Blueprint
Good work there Aust. You mentioned about welding two pieces together. Could an exhaust shop do a longer version for you? I think that's how some others have done it? You would have found that the rear clamp doesn't have much purchase on the rubber because of the radius at the base of the boss for the IAT sensor. I just trimmed about 2-3mm off the side of that to give the clamp some room. Once you get some shorter screws for your maf adapter, the finished product will very neat.
Sk8xr8, she's a daily family truckster, but I do try to stay on top of it. Thanks for your comments, makes the cleaning worth it then. Are you going to join us in Albury on the 26th Jan? -Craig |
15-01-2012, 09:38 AM | #22 | ||
Craig
yes I did have a bit of trouble with the clamp near the IAT bung, there isn't much to get the clamp to hold on to. It is on there now though and hasnt let go which is good. The material I'm ordering in is pre polished and to be honest I got one piece in hoping it was enough, but it won't be so I'll get another piece to match it and use that. If i hadn't have got the first piece in I wouldnt bother but I have it so I may as well use it. The MAF screws will be changed too to clean it up and once it's done the manifold will likely get a polish. My welder mate is also making a new plate for the manifold (replacing the 5L V8 one) which will have a bit of a custom thing put on it. It'll take a few weeks but should look ok once all done.
RAM 1500
15-01-2012, 09:51 AM | #23 | ||
The dearest bit is that I now think a 70mm TB is in order..........
RAM 1500
15-01-2012, 10:05 AM | #24 | ||
T3 TE50 Blueprint
No real advantage Aust unless you have big plans. But if you do the cam and heads, then maybe. There are different airflow settings in the ECU for the different t/b sizes. But that won't be an issue for you soon, will it Aust?
-Craig |
15-01-2012, 11:13 AM | #25 | ||
from the pictures posted above it looks as both of you have made the intake smaller ?
15-01-2012, 11:17 AM | #26 | ||
T3 TE50 Blueprint
It's still 75mm at the inside diameter, so there is no change. It's just the wall thickness of the rubber making it look smaller.
-Craig |
15-01-2012, 02:57 PM | #27 | |||
I'm thinking about changing the throttle body purely for looks, 5mm extra isnt going to make a huge difference (if any).
RAM 1500
16-01-2012, 04:19 AM | #28 | |||
sliding by you...
18-01-2012, 12:55 PM | #29 | ||
5.6L x 2 pilot
Albury Australia Day AFF meet. All are welcome to join us.
http://www.fordforums.com.au/showthread.php?t=11347124 Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
18-01-2012, 03:53 PM | #30 | ||
A little off topic, but regarding intake pipes and other air induction, has anyone put heat proofing around their pipes and box? Does it make a noticeable difference?
