Old 16-02-2012, 10:34 PM   #1
XR_6falcon
Default electrical problem..?
Hey all i have a AU S3 xr6 and it has a strange problem. Sometimes while driving along everything on the dash and the sterio will sort of flash/reset, and when i come to a stop and turn the car off it will completly die. I checked the battery terminals, they are nice and tight and the alternator is charging the battery. Has happend twice now and I am starting to get worried, has anyone expericed this before and any ideas how to fix it?
Cheers!
Big dreams, not enough money
Smoke tyres, not drugs
XR_6falcon is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2012, 10:50 PM   #2
philfree
Default Re: electrical problem..?
What do you mean by die like can't restart?
2000 AU II Fairmont Ghia with tint, stero, Tickford body kit, 17in mags
2000 Nissan Patrol ute 4.2 td with 155rwhp
1982 Mitsubishi l200 express 4x4 converted to home built buggy 2.6 efi with megasquirt ecu
philfree is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2012, 11:17 PM   #3
XR_6falcon
as in the dash goes blank the clock goes blank but when i turn the key everything comes back?
edit: the first time it happend i had a play with battery termianls and E came up on the dash and odo came back up
Old 16-02-2012, 11:48 PM   #4
FGII-XR6
FGII-XR6's Avatar
I would be looking for a bad earth
[SIGPIC][/SIGPIC]
Rides:
Old 17-02-2012, 05:57 PM   #5
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
You mention that the clock goes blank? When it comes back, is the time correct or been reset? If time is still correct, power or earth has not been lost. You may need to dig deeper - possibly ignition switch? Just a guess, when you turn ignition off, everything goes blank. Is this the same as what it does under the fault condition?
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2012, 06:47 PM   #6
XR_6falcon
Stu
the first time it "died" i had to reset the clock and radio stations and the second time only had to reset the radio, so im leaning towards a bad earth atm. Also its not the same under fault condition the odo reading normally stays on all the time and when it dies the dash goes blank
Old 18-02-2012, 08:24 PM   #7
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Yes, tend to agree. Bad earth or supply to the fuse box. Good luck in chasing it.
Stu
2002 AU II LTD
Old 01-03-2012, 06:48 PM   #8
XR_6falcon
instead of making a new thread i thought i would just add to this one. It has developed a pretty bad miss fire now, although when its cold its fine but once it warms up it starts to miss and carry on. At idle there is a quite a bad miss! I changed the fuel pump and filter because i was having starting issues not enough pressure when primeing. Now my question is could it be the coil pack cause all these issues?
Old 02-03-2012, 09:39 AM   #9
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Coil pack sounds like a possible culprit for the rough running issue but I doubt it'll have anything to do with your electrical gremlin.
Bushbasher
MINE- AUII Forte
