Old 23-10-2017, 04:02 PM   #151
auxlr8
Default Re: Definitive AU1 to AU2/AU3 brake upgrade thread
Thanks for that. Planning on changing to ba 303mm caliper and rotor
auxlr8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2017, 04:09 PM   #152
auxlr8
so territory is 328mm ventilated and twin piston and also bolts up to standard lines with spacers? That sounds like an even better option
cheers
Old 23-10-2017, 04:10 PM   #153
PG2
#neuteredlyfe
PG2's Avatar
Originally Posted by auxlr8 View Post
Thanks for your reply. When you say u didn't even disconnect the rear caliper, how did that work? Standard ford au irs is a solid 287 mm disc and single piston caliper. The ba rotor is 302 mm ventilated and the ba rear caliper is twin piston from what i understand. Either way thanks for clarifying that the standard/braided au irs rear lines will attach to the ba caliper. My apologies for the extensive questions, just getting my head 100% before the job is tackled.
Originally Posted by tkfd
The BA is still only a single aswell, but larger piston and pad area, plus of course larger rotor to suit.
Don't know what PG2 means either ? But aren't you changing to the 328mm rear rotor (territory/BFGT)
I didn't remove the caliper from the brake line. I just change the saddle that the caliper sits in.
Old 23-10-2017, 04:15 PM   #154
tkfd
tkfd's Avatar
cheers
That's what I did, but caliper is still only single piston, but with larger pad area, larger piston. I made custom lines up.
Will need the 3mm spacer (I actually used a 3mm wheel spacer behind rotor to clear wide wheels, but recommend you use the 3mm washers on caliper mount)
tkfd is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2017, 04:19 PM   #155
auxlr8
Thanks guys for all your help. Im lucky enough to have a mechanic for a mate whos going to help me/show me how to do the front and rear conversion but want to make sure i have everything i need first
Thanks again
Old 23-10-2017, 04:21 PM   #156
tkfd
tkfd's Avatar
...I also drilled out a hole for that grub screw, as Territory/BFGT rotors done have one. Also watch AM toe-link balljoint as the AM ones are fatter than OEM and come awful close to rotor. I just knocked off 1-2mm off the balljoint casting on the grinder, its only casting daggy bits anyway.
Old 23-10-2017, 04:30 PM   #157
Silver'
T-Series Club Member Vic
Silver''s Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent write ups on AU technical issues.
Post #30 tries to explain the lines.
https://fordforums.com.au/showthread.php?t=11377772
I did the same with my aftermarket toe-link end tkfd. So far, they haven't failed!
TE2 #116
Build/Maintenance thread here.
www.fte.ford.com.au lives! 2001 2002
Add a T-series to the Registry HERE
Silver' is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2017, 04:42 PM   #158
auxlr8
Is the grub screw actually needed? Wont the studs and wheel nuts locate the disc anyway? What have you guys done in regards to the dust cover? Im thinking of just completely removing it?
Old 23-10-2017, 04:49 PM   #159
Silver'
Silver''s Avatar
If you mean the stone shield, I ended up removing it.
If you mean the rubber grommet that covers the adjuster, I used BA ones (on the right in this picture.
TE2 #116
Old 23-10-2017, 04:54 PM   #160
auxlr8
What is the rubber grommet for? This is the first time ive heard of it
cheers
Old 23-10-2017, 04:58 PM   #161
Silver'
Silver''s Avatar
The hole in the rotor for handbrake adjustment isn't covered by the wheel so a grommet seems like a good idea.
You can see it in this pic.
TE2 #116
Old 23-10-2017, 05:08 PM   #162
auxlr8
Thankyou, makes perfect sense now
Old 23-10-2017, 05:37 PM   #163
wobblysauce
316,500km
Silver', Do not think they're referring to the Handbrake hole but the tapered one that alines the Disk to the Hub.
-RIP- the Ol taxies came a foul and is no longer with us.
07 BF Falcon XT MKII Dual'o'Fuel Wagon Ex-Taxi with 940,000km.
06 BF Falcon Futura MKII Dual'o'Fuel Wagon Ex-Taxi with 840,500km.
Was going for the Barra 1,000,000km... but was cut short, time to reset the clock.
wobblysauce is offline   Reply With Quote Multi-Quote with this Post
Old 23-10-2017, 05:41 PM   #164
auxlr8
I was referring to the locating hole on the disc as my understanding is that its really not needed as the studs, wheels and nuts locate the disc anyway but it was good to find out the info on the rubber grommet for the handbrake hole.
Thanks again for all the info
Old 23-10-2017, 05:46 PM   #165
tkfd
tkfd's Avatar
yea gotta remove the dust cover, a lot of swearing will happen as its fiddly,
The grub screw isn't really needed, but I think why they put it there is for when you adjust the park brake. You cant do with wheel on. The rotor needs to stay square. Guess you could nip up all the wheel nuts.
I put the grub screw in.
Old 25-10-2017, 01:25 AM   #166
Silver'
Silver''s Avatar
My 328mm rotors didn’t have any provision for the grub screw. I’d use it if it was there.
TE2 #116
Old 06-11-2017, 08:06 PM   #167
auxlr8
So guys I don't know if I'm doing something wrong or I have some wrong parts. I've got the lower control arm and upright assembly as one piece on my garage floor and loosely looking at how the ba carrier and caliper bolt onto the upright and it's just dosnt look like it will fit. The bottom ba bolt might but the top bolt looks to short to fit on the au 3 upright and even if it did it looks like it's too far in towards the body for it to go over the disc. Am I supposed to be using the au3 bolts on the au 3 upright with the au3 carrier and then attach the ba caliper to the au3 carrier? A little confused now, any advice on what I'm doing wrong?
Old 06-11-2017, 08:17 PM   #168
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Question Re: Definitive AU1 to AU2/AU3 brake upgrade thread
Got any pics to show us?
UK
Old 06-11-2017, 08:29 PM   #169
auxlr8
Trying to work out how I can attach pictures mate and that's a struggle atm too.
Old 06-11-2017, 08:32 PM   #170
JC
Miami Pilot
JC's Avatar
When you quote a post to reply, there is a box below the message box called Additional Options. One of these is manage attachments - click this and then browse to the pic on your PC, and upload it/them.
Ford Performance Club ACT
Old 06-11-2017, 08:35 PM   #171
auxlr8
I'm using an I phone is that why I can't attach?
Old 06-11-2017, 09:09 PM   #172
auxlr8
Struggling to upload pics from my iPhone. I'm thinking maybe the wreckers gave me the wrong lower arms and uprights maybe. On the passenger/left side with the curve of the lower control arm facing forward and stamped LH the caliper position is still facing the rear as per my current series 1 where it should now be forward as per series 3?
Old 06-11-2017, 09:58 PM   #173
BlueBear
Shockwave
BlueBear's Avatar
Sound like the wrong upright, should definitely be mounted on the front of the axle line.
This is mine part way through the conversion, the suspension changed over, but the old caliper still hanging there - drivers side.
Cheers,
BlueBear is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2017, 10:07 PM   #174
auxlr8
Yep, thankyou for that photo, it does appear they have given me the wrong upright and lower arm assembly. No wonder why I couldn't quite work it out. Thanks heaps. I'll go back Wednesday after cup day to get the right parts. Should my ba carriers and calipers use ba carrier bolts or should I be using au2/3 bolts?
Old 06-11-2017, 11:07 PM   #175
JC
Miami Pilot
JC's Avatar
These are the pics of the parts auxlr8 was supplied with:
Old 06-11-2017, 11:10 PM   #176
JC
Miami Pilot
JC's Avatar
Are they AU1 spindles with AU2/3 sway bar bits? Or could they be the spindles for premium brakes?
Old 06-11-2017, 11:17 PM   #177
auxlr8
When I went to the wreckers I asked for au 3 lower arms with hubs and spindles, uprights and au3 sway bar and mounts. It's taken a month for them to have the time to get it all together and it now looks like they have accidentally given me au3 sway bar, mounts and links but with au 1 lower control arms and uprights.
Old 06-11-2017, 11:41 PM   #178
BlueBear
Shockwave
BlueBear's Avatar
The uprights aren't just on the wrong bottom arms are they?
Has the bottom balljoint been disconnected?
If so, just swap over the uprights and see if they look right, just that they look correct from my recollection. For example, the ABS sensor is in the correct position, they are on the front side of the series I stubs...
Cheers.
Old 06-11-2017, 11:46 PM   #179
auxlr8
Nah it was removed as one piece with the lower arms and uprights still connected without the ball joint broken and still connected. I'm thinking they have just given me series 1 lower arms and uprights with a series 3 sway bar and mounts?
Old 08-11-2017, 06:44 PM   #180
auxlr8
So I went to back to the wreckers today with all my parts and begin to have a crack that they gave me the wrong parts.... luckily before I opened my mouth the owner took me to the donor car.... indeed a series 3 au. An xr6 that for some reason had sseries 1 uprights on it which then led me to believe it had the premium brake combination that indeed used series 1 uprights on a series 3. Would anyone know if this premium option that used series 1 uprights were twin piston caliper and what sized discs? I've got the wreckers now looking for those original calipers in case they are twin piston and may bolt straight onto my au1 Fairmont ghia.... bit of a long shot but maybe?
