Old 04-12-2007, 11:25 PM   #1
railtrolley
railtrolley's Avatar
Default What does Base on dash screen mean?
Hello All, Just put cruise control, a standard AU Ford set up, in my AU II Tradesman. After I reconnected the battery, and started her up, the word Base appeared on the little screen on the dash, where the odometer numbers are. The word vanished after a few seconds, and it ran ok, and the cruise control works fine also. I'm just wondering if anyone knows what it means?
Cheers.
railtrolley is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2007, 11:35 PM   #2
au adam
au adam's Avatar
Means its a base model dash i think.Should have it on the back of the cluster too.
au adam is offline   Reply With Quote Multi-Quote with this Post
Old 04-12-2007, 11:58 PM   #3
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
did it to mine , as i just chucked a battery in without th ealternator an dit said BASE on the Screen ...
Weird
Daniel
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2007, 12:01 AM   #4
JC
JC's Avatar
Yes, it means it's a base cluster. The Police ones come up with a P, and the T series ones with a T. XRs come up with "Mid", IIRC.
Mods: Tune, ShockWorks and GT335 replicas in 19 x 8.5 & 9.5 35p offset with 245 & 275/35/19 Michelin Pilot sport 5s
Daily: BF2 Fairmont Ghia I6 ZF, FG 19” Lux packs with 245/35/19 Toyo and Pirelli tyres, Bilsteins & Kings
Ford Performance Club ACT
Old 05-12-2007, 12:12 AM   #5
clontarf_x
um
mine does none of the above
on reconnecting my battery, it shows a kind of upside-down f symbol...
|_
|_
kinda like that
clontarf_x is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2007, 12:14 AM   #6
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Nah , Mines in Bits .. Still waiting on my Alternator to be Delivered
AU2PWR
Old 05-12-2007, 12:22 AM   #7
InfernoSR
Sales Representative
InfernoSR's Avatar
Does this only come up in the Series II and III? as i've never seen it in my Series I...
Old 05-12-2007, 08:39 AM   #8
BOON250
Mine says FAir after reconnecting batt...
1972 Lincoln Continental Mark IV
460 V8 C6 All original .
Triple Brown 1 owner from new !
BOON250 is offline   Reply With Quote Multi-Quote with this Post
Old 05-12-2007, 09:13 AM   #9
james22
With da Warlords
james22's Avatar
Mine says Base - Then flashes P. Then goes into speedo calibration mode and displays SPEEDO -2
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 21-11-2011, 03:55 AM   #10
dopeydazza
dopeydazza's Avatar
Default Re: What does Base on dash screen mean?
I have a AU2 forte (2000).
I flattened the battery, recharged and reconnected. LCD screen said base, however I feel the idle is set too low now and car stalls at intersection, it was working perfectly before I flattened battery by leaving lights on.
Has the computer been reset to basic programming?
dopeydazza is offline   Reply With Quote Multi-Quote with this Post
Old 21-11-2011, 08:58 AM   #11
JC
JC's Avatar
Yes, it has. You need to get it to learn - either by driving it for around 200km or so, or you can do the learn method:
Originally Posted by www.aufalcon.com
- Reset Computer by disconnecting battery (Take off the positive terminal lead)
- When power is re-connected, start car and idle in this sequence
- 2 minutes idling with the transmission in drive and A/C on.
- 2 minutes idling with the transmission in drive and A/C off.
- 2 minutes idling with the transmission in neutral and A/C on.
- 2 minutes idling with the transmission in neutral and A/C off.
- Drive the car on the road, for at least 5 minutes under variable throttle positions.
Old 09-01-2012, 11:33 PM   #12
dopeydazza
dopeydazza's Avatar
Thank you for the info, It took almost 2-3 weeks for car to relearn itself and drive 'perfect' again. I kept forgetting to do the idle sequence but took roughly 200-300 kms. At start I was fretting at driving but now not concerned anymore as feel its safe to drive again.
Old 10-01-2012, 12:40 PM   #13
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
Impressive 47 month-old thread mine
Old 13-01-2012, 07:59 AM   #14
Mechan1k
Mechan1k's Avatar
There's some Gold threads in them hills
I miss reading some of these old posts from way back when.
Old 21-12-2013, 11:11 AM   #15
wallablack
(o)(o)
My AUII 200 Ute has just done the BASE thing too.
I disconnected the battery for 10 minutes (not to do any wiring etc) and reconnected it.
Warning lamps all on and even the needle is showing a full tank of fuel (which it has) and the fuel light is on.
The digi dash bit shows "bASE" and that is it...no start...nothing.
Fuel pump starts etc though.
I understand the learning sequence for the computer etc but it would help if the bugger would start to begin with.
Foolproof systems do not take into account the ingenuity of fools.
0-100 in 60 seconds (unloaded), 0-100 in 4m57s (loaded)
wallablack is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2013, 11:49 AM   #16
Mechan1k
Mechan1k's Avatar
Which fuel light is on ... the normal fuel low lamp ... of the fuel lamp with the X through it.
If that's the case ... the fuel cut-out may have been triggered and you need to reset it.
Old 21-12-2013, 11:52 AM   #17
wallablack
(o)(o)
Nah just the normal low fuel (orange) lamp.
Old 21-12-2013, 12:04 PM   #18
wallablack
(o)(o)
Also a note....
I was just checking all of my earths and power and when I was looking at the starter motor + I noticed a small circular female 2 pin round plug which is not connected to anything nor could I find a male to go to it.
What is this plug for and should it be connected?
Old 23-01-2015, 01:56 PM   #19
arlenn
Hi all just wondering my car says base on the lcd screen and i have nothing at all the fuel pump isnt preping no wind just wondering if anyone knows wat to do to get it to start
arlenn is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2018, 06:17 AM   #20
manaaki04
I'm just curious to know if anyones seen the symbol t come up? I've done a v8 conversion in my series 2 ute to the v8 asf it comes up with like a lower case t before I turn the key on after I've connected the battery. Then the red hand flashes and wont start.
Sent from my SM-G965F using Tapatalk
manaaki04 is offline   Reply With Quote Multi-Quote with this Post
Thread Tools
Display Modes
