Nitro FG XR6T Ute LOVE IT
Location: Homeless in the Parks. Oran, Wakefield, Morgan
My brief love affair with the Wankel Rotary engine in my series 6 RX-7 race car is over.
I always hated the sound of the things but then I drove one on the track and the light weight of the engine helped car balance so much that I was hooked. I can see why they are still track weapons after many years, even against latest model cars. To get them really fast you need a big turbo but the heat generated causes problems in endurance races (my preferred race) My beloved RX-7 has given me many joyful moments and although we have found the root cause of our problems (did not replace oil coolers after a crank breakage and the left over debris contaminated 2 new engines) I just want simplicity. Sure if we were dumb enough to repeat the oil cooler issue with any engine it would also be contaminated and fail under race conditions BUT I am over rotaries just want simplicity. It has been fantastic while it lasted but I am now looking at putting a V8 in the RX-7. Either that or sell the whole car but it is so well developed that I a lightweight V8 seems logical to what has become part of the family. He has his own personality and my grandson loves him Therefore I want N/A and BAGS of torque for reliability and drivability. A standard engine with the breathing sorted is all I ask. The yanks put LS1 and LS2 into RX-7 and instructions and kits available. Toyota/Lexus Quad Cam also interests me. Apparently under 200KG and available under $1000. They tell me internals cope with big power. Is this true? Anyone know? Does Ford have anything? Is there something else I should consider? I will weigh the 13B engine and turbo for comparison at some stage. How can I find out the weight of an LS2 and Toyota Quad Cam? I DO NOT want too much weight so anything cast iron is a no no. Do I want Carbie or EFI? (I am useless on the tools) Any ideas very welcome
An Extra Tax System to fix Global Warming would work as well as an Alcopop tax works to stop schoolies getting drunk. Totally useless. Just like the Government proposing it |
![]() Clevo Mafia Inc.
6.0 litre LS2 weighs 450lb or 205 kilo, lighter than the Ford V8's at least until Coyote is released.
The 1UZ is around 175 kilo but would lack the torque of the LS. |
If that's the weight of a LS2 they would be hard to go by. The extra capacity would give you an engine that doesn't have to work as hard. Parts are available compared to the toyota engine. The toyota is an engine built to rev, resulting in faster wear rates ect ect...
nissan V8 with twin turbos
#6 | |||
5 Donkeys to the Camel
There is a reason LS series engines are so popular in conversions.
See my parts thread, parting out REDXR347! clicky Peuty, Enigma or Idiot? You decide.
Founding member of the almighty
WINDSOR WARLORDS
![]() Weezland
![]() Join Date: Aug 2005
If budget is not an issue a complete aftermarket engine is the way to go, something like nascar spec but with more cubes and less rpm which will give a long service life between rebuilds.
A Dart or world alloy block of around 9.0 - 9.2 deck height with a big over bore and stroke giving about 430 - 440 ci, high poirt racing heads and roller cam, I would go with a carb, but thats personal choice, it will weigh the same as an LS engine but make a fair bit more hp and torque, and is made for racing and thrives on it. The downside is the cost, you would be looking at about 30k at least, depending on what you wanted exactly.
XA Falcon 10.8 @ 130mph manual 3900lb BFMk2 XR6T ute |
#8 | ||||
Low 20s for a nascar engine and revs is their friend, when not reved in the built range ie 7500-9000rpm they get harmonics causing extra bearing wear ect. Dodges are the worst with the low rpm harmonics. It will last longer revving it hard Quote:
Thats a little complicated and might not last that long. He doesn't want turbos. |
#9 | |||
![]() Weezland
They only rev them to 9500 due to the 358ci capacity limit, if they were allowed to build them bigger they wouldnt need those revs to hit the power targets and they would last alot longer, I have never heard of this harmonics thing, and am very sceptical, how can a part last longer when its working harder and under alot more stress due to more rpm, its impossible.. If you re read my post, you will see Im not talking about a nascar engine, rather, a high capacity V8 using nascar like induction, which will make big hp and t/q at alot lower rpm, and as such will be less mainenance and alot less highly strung with a broad torque band. An engine like this will cost you around 30k, I have something similar in my XA..
I sell them (with history)
EDIT: Walt cant go over 6 litres, cams thingy. Double EDIT: Ive been told this about engine harmonics by reputable engine builders, apparently at revs the cranks start running true ect. Last edited by KPOJ : 16-08-09 at 07:57 PM. |
#11 | |||
![]() Weezland
suffice to say I would build one that ran in the 5000-7500 range for better longevity, less stress on everything, from the bearings to the valvetrain..
#12 | ||
What sorta limit in capacity is there?
Ls1, L98, LS2 are great bang for buck options. possibly a windsor/clevo depending on weight and revs required. A little windsor can be built to rev, but it will cost... In a race car i dare say EFI would be ideal as long as fuel supply is up to scratch...
A philosopher is a person who finds a problem for every solution . 95 EF XR8, Advance headers, Vortech V2 t trim blower, Ported Cobra Manifold, Capa Switch Chip Eliminator. 307 rwhp 395 ft/lb 13.2 @ 105mph Now NA- AFR 165 heads, 1.6RR, Ported Cobra 269rwhp 14.2 ... needs stall and 4.11's 1977 CL Chrysler Panel Van, 360, 727 torqueflite auto soon to be restored. |
CLEVO MAFIA.
![]() Join Date: Jan 2005
Most stuff involving CAMS is 6.0l
. . A real man fights... Not because he hates what is in front of him, but because he loves what is behind him... |
#14 | |||
Captain Awesome
Mate go with a Land Rover 3.5L V8. It will rev a little harder than you want but they are all Alloy. You can pick the whole motor up with on arm if you can find a place to grab. A little supercharger and you can't lose. I was going to put one in the Gemini and race it but I need to get a job first lol.
1994 EDXR8, 388 Windsor stroker & GM 6/71 blower.
*555rwkw*
Soon to be the proud owner of a 1988 Jaguar XJ6 - black with white leather and a supercharged 351 Cleveland.
#15 | ||
Windsor or clevo would be to heavy, the car is already heavy enough. 6l max
#16 | ||
Dad and i race a bmw with the lexus 1uzfe motor. In standard from it will rev to 8,000rpm and will last forever at those revs. But they seriously lack power until turboed, so steer clear of that one. Ours produced 135rwkw stock, amd currently has 250rwkw with the stadard injectors holding us at 6psi boost.
If i had my time again i would have put the chev alloy v8 in it. More expensive to buy, but cheaper to hot up, and huge power with small changes - cam/pipes/chip and 300rwkw is achievable. They also have far more adapter plates available. The lexus needs custom bits, which add up very quickly. As for Ford product - probably the best motor currently is the xr6t motor. The v8s are heavy and not as well supported for parts. An alloy windsor style motor would be good, but very expensive
XA coupe 9.93sec @ 135mph BA GT-P for the shed BF XR6T 12.8 @111mph with the 10psi generic tune Landrover disco 18.8 @112km/h "A tale told by an idiot, full of sound and fury, signifying nothing." Macbeth |
#17 | ||
LS2 would be the go, plenty of info on the net from the states about the conversioin FD RX7s, you may need a complete drivline rethink also, not sure if the box nad diif would cope with the extra torque I would go injection rather than carby and look at dry sumping the LSx engines are prone to oil surge/starvation when the cornering gs get high. It would be a weapon but will not be as easy to drive with the extra torque, power down out of corner will be a problem.
I have a soft spot for the rotary turbos, heres a mates FD with 320kw... its good for 1.02 round wakefeild http://www.natsoft.com.au/cgi-bin/r.../2009.WAKE.S5.Y http://www.youtube.com/watch?v=ybaypCrq8kY A 1uz vid also with ITBs http://www.youtube.com/watch?v=clRvHdA47rw
SA IP cars 15,25,51 & 77 (Sharperto Racing) http://www.sharperto.com.au/ Last edited by toyocharged : 16-08-09 at 10:00 PM. Reason: 1uz sound horn |
#18 | ||
A big thank you to everybody who has contributed. I love the AFF. You guys are great.
I will try to address each item but please forgive me if I miss a few. Definitely do not want any forced induction even 6PSI. I realise that handling may suffer but in the chase for reliability and simplicity BUT it is a price I might have to pay. The handling now I must say is unbelievable and I might not get that again. Then again there is great fun to be had in having so much torque on tap from a dry sumped LS2 that a power slide or two at the end of a race is on the cards. Drivability may be a problem with power down but I will have to keep the OTC - Organic Traction Control - well maintained. RX-7 is no drifter. More a spinner. The jury is still out on the weight differences despite lots of googling. The weight difference of the engines may be as little as 40lbs (450 Vs 410) By the time I exclude all the turbo stuff – intercoolers, 50MM Pro waste gate, etc this may be even less? The V8 engine itself may have a higher centre of gravity so weigh is not the only factor that will affect handling. Budget is “as low as possible”. This is hobby racing without sponsors so $30K engines are out of the question for a retired bloke but a built race engine around $8 is a real possibility. It would be a dream to sell the complete single turbo conversion as one kit for somebody wanting to convert a twin turbo setup RX-7. · 13B engine brand new to be built in next week or two · Double Ceramic Coated T4 turbo · Double Ceramic Coated manifolds · Larry Perkins heat shielding · Intercooler and piping · PWR radiator · Almost new 50mm Turbo Smart waste gate · Exhaust · Apexi FC computer · All ducting and 15” Pod · Anytthing else I have forgotten The dream would be to take that money and fund most of the V8 conversion. KPOJ has given me some excellent prices on NASCAR stuff for the driveline which is well priced, high quality, light and readily available. If I go the Toyota route I am in the realm of expensive Motorsport upgrades again so that has been ruled out. LS2 dry sumped it is. Current fuel supply will cope. It has two Holley Blue fuel pumps feeding from the fuel cell to the swirl pot and a Bosch 044 from there. Unless you guys can tell me otherwise. Thanks again for all the input. Keep it coming.
An Extra Tax System to fix Global Warming would work as well as an Alcopop tax works to stop schoolies getting drunk. Totally useless. Just like the Government proposing it Last edited by Walt Kowalski : 17-08-09 at 10:35 AM. |
#19 | ||
![]() Performance moderator
![]() Join Date: Feb 2005
1JZ or 2Jz ?? Yes back to turbo .. But they are very durable..
How about the 4.6 Cobra engine?? Cheap in U.S but a little expensive here.. Chevy seem to have weight to power advantage and aftermarket performance parts.. I guess your after 400 / 500 usable h.p ?? In a light good handling body it would be very quick..
Real cars are not driven by front wheels,real cars lift them!!... BABYS ARE BOTTLE FED, REAL MEN GET BLOWN. Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! Dart 330ci block turbo black pearl EBXR8 482 rwkw.. |
#20 | ||
Watts a panhard.
I dare say the weight difference between the LSx and a 13B with all its turbo accessories will be a wash. You could set the V8 fairly well back into the engine bay, as they are fairly compact. I don't think handling will suffer as a result of the swap.
The 2JZ is a good motor, but I think it would be very long, tall and heavy - not particularly suited to the RX-7.
I don't have low self-esteem. I have low esteem for everyone else. |
#21 | |||
Scar Non?
Wanna sell the 13B mate.....
2002 BA MkI XR6 - ET PB 15.443 w/out custom tunes. Mods: Redback 2.5in" Catback, 2.5in" Hi-Flow Cat, Hurricane Headers, K&N Air Filter, F6 Lower Intake, GT Upper Intake, Custom Intake piping, SCT XCAL3 w/Custom Tunes - 200.1rwhp Quote:
#22 | ||
Walt as profi has found out the L98 is the gun engine compared to a LS2, much better head design
SA IP cars 15,25,51 & 77 (Sharperto Racing) http://www.sharperto.com.au/ |
#23 | ||
a friend who is pretty up on engineering reckons early LS blocks suffered from flex, he was in the same boat as yourself, having a severly modded supra , after getting it to the max power levels wanted a cheap reliable transplant for more power, he went for a late model brand new compact LS motor complete engine manifolds coil packs for 5 grand odd if my memory serves me, it might be worth looking into.
First On Race Day
#24 | |||
The problems from heat sink are too much for me. Things just melt despite the best efforts, materials, shielding, installations etc. Brad's l.02 at WP has become legendary. Probably the fastest RX-7 ever at WP? Somebody correct me please. My best is a 1.04.32 (lap 128) in enduro tune and setup with 220KW ATW. I wanted to go to that RENEW day but engine No 4 was not quite ready. Getting a pattern here anybody? I am missing events because the thing is in the workshop. Brad can really drive (His Dad is pretty handy too) and it is a REALLY powerful car. I am told 370KW bridge ported turbo. Is that correct? It is beautiful too. I was actually at the importers the day they unloaded it from the docks. 11,000klms from memory. I told a guy about it and next thing it was in his workshop getting fitted out for Brad. I was also in that same workshop (that pattern again) on the Tuesday after Brad’s legend 1.02 lap when a guy with a 2008 Porsche Carrera S came in and said "I want an RX-7 for the track”. Apparently all the Porsche guys were talking about Brad's lap. I saw the guys beautiful Porsche out the front but he definitely wants an RX-7. I think he's getting a Pearl White one based on a late model Series 8 RZ. Now what’s this about L98? I have never heard of it so THANK YOU for the tip. Anybody got any more clues about L98?
An Extra Tax System to fix Global Warming would work as well as an Alcopop tax works to stop schoolies getting drunk. Totally useless. Just like the Government proposing it Last edited by Walt Kowalski : 17-08-09 at 08:40 PM. Reason: font size |
#25 | ||
| Thread Tools | |
| Display Modes | |
