20-10-2009, 07:20 PM | #1 | ||
Just slidin'
Thought people might be a little interested in this, so here we go.
Tools needed: 8, 10, 13, 17, 23mm sockets, spanners, and ratcheting spanners (all would help, any will do) 3 mm Allen key with a long shaft Torque wrench Lever bar Philips head screwdriver Spark plug socket 1. Take off your intake, leaving behind your airbox bottom half. There is 5 x 10mm bolts to undo. Also disconnect your oil breather from your intake and/or rocker cover. 2. Number your plug leads with a nikko or some tape. Disconnect them all, and lie them over your intake side. 3. Disconnect your PVC valve, it just pops out, but be gentle with it. Disconnect your throttle cable from your rocker cover at the same time, its 1 x 8mm bolt. Disconnect your throttle cable from, your throttle body, just like on a pushbike with a hand brake setup. Tie the throttle cable onto the strut on your drivers side of the bonnet. 4. Pop off the hose from the brake booster that runs over the rocker cover, leaving your rocker cover free of accesories. 5. Take out your thermo fans. Take out the little hose running along the top of your thermos, it should just pop out. Disonnect the wiring loom, I use a little flat head screw driver to lightly push down on the clip. There is 2 x 10mm bolts to undo on either side of the radiator. Lift the thermos up an inch or two, then pull the drivers side out (may need a wiggle) and then the passenger side. 6. Take off your snorkle. Youve all done one of these, two little philips head screws. Then just twist, and pull. 7. Take the rocker cover off. Its just 4 x 13mm bolts. You have to lift the back of the rocker cover off first, then the front. 8. Undo and take off power steering resevoir brackets (x2) and the resevoir itself. First take off you serpentine belt, then undo the 9 x 13mm bolts, 1 x 10mm bolt, and one x 17mm nut. It will all just fall apart now. Make note of which length bolts go where, you dont want to put it back together, and keep stuffing around trying to find out which one goes where. 9. Take out the spark plugs using a spark plug socket (21mm?). Clean them up if they need it, or replace them as its a good time to. 10. Find top dead centre (TDC) using a long screwdriver to feel where Piston 1 is at its highest point before returning down. Do this by putting the screwdriver down plug hole 1 and ensuring the mark on your vernier gear is close to being perfectly inbetween the two yellow links on your timing chain. Cable tie the chain to the vernier gear. Use a 23mm Socket to turn the crank to turn the engine. 11. Take out all 28 x 10mm rocker gear bolts. Beware not to drop ANYTHING from this point on, you dont want a socket in the bottom of your engine. Beware not to drop the sleeves sitting inside the head that the rocker bolst go into. Lever of the rocker gear and set aside. 12. Release the tension on the timing chain, using the 3mm allen key. Its on the inside of this bolt: It simply releases when turning it a certain way, remember how you done it as this will come in handy later on. Also it may take a while to find out how to get the allen key in there. 13. Undo the Bolt that hold the vernier gear on, its a 17mm bolt. Slide off the vernier gear. 14. Lever out the cam, it may stick a little to the oily guides. Slip in the new cam, be gentle not to damage anything. 15. Put the vernier gear back on, there is a little slot where the cam will slip into. Reset the tension on the timing chain, push in, turn and allen key should pop out, check the chain is tight. Redo the bolt that goes into where the tension is set from. 16. Put the rocker gear back on, ensuring that the rocker gear is in the dowels in the head. Do it all the bolts up to 27nm, working from the middle out. Double check them when your done. 17. Re-attach the power steering resvoir and both the brackets. Its a bit fiddly, so get over it, lol. 18.Put the rocker cover back on, and all the accesories. Put the serpentine belt back on, wind the engine over with the 23mm socket on the crank to ensure everything is right. Do this for two complete revoloutins of the engine (all pistons). 19. Put the plugs and plug leads back on, reattach the throttle cable, and intake. 20. Put the thermos back in and the snorkle back on. Double check everything, make sure you have no bolts left over, and nothing is lying oose in the engine bay. Thats it, start it up and listen for any weird noises. If there is, shut it down, and do it all again to make sure everything is right. If there are no noises, take it for a spin, and in first gear slowly go right up through the revrange to ensure there are no funny noises. Do this SLOWLY. And thats all there is. Should take about 2-3 hours just going nice and slow with music, and a BBQ cooking. Thanks to Blackers10 and my mate chook for the hand to do everything. Josh Mods, can you please make this a sticky.
MD Mondeo - For the family
20-10-2009, 07:24 PM | #2 | ||
Afterburner + skids =
Awesome write up mate - I can see this coming in handy with a lot of the TQE owners around here.
20-10-2009, 07:27 PM | #3 | ||
Just slidin'
Hehehe, thanks bloke. I forgot to mention, this is for a BILLET cam, not a regrind, I have NFI how to do one of those puppies, Id say its all the same, bar the shimming.
20-10-2009, 07:44 PM | #4 | ||
Critical Thinker
*subscribes* good info to know.
Thanks The Monty
20-10-2009, 07:46 PM | #5 | ||
Rusticating
Nice work, thanks.
Tune needed?
Territory SYII RWD, BFII RTV tray |
20-10-2009, 07:47 PM | #6 | ||
Just slidin'
I went from a fairly huge cam back to a stock cam, so I needed to "un-tune" it, lol, ie: flash it back to stock.
20-10-2009, 07:49 PM | #7 | ||
Lost Boost Gained Class
good write up will come in handy when i go and put a cam in my car will this be the same if i was to go and use the JMM DEV3HL cam i got if i get all the right gear for it?
2006 BF Fairmont Ghia
2001 AU Falcon |
20-10-2009, 07:53 PM | #8 | ||
Just slidin'
Yes, except for the part where you spend hours trying to get in the shims.
20-10-2009, 07:57 PM | #9 | ||
This thread is definitely a sticky contender....
20-10-2009, 08:04 PM | #10 | |||
thanks mate if i have probs i know where to take my car then : YOUR HOUSE
2001 AU Falcon |
21-10-2009, 02:40 AM | #11 | ||
SKID IT
Very handy write up mate. Will come good for all people that don't know anything about it.
Monty is now doing cams for a slab and $50 lol
Style, Create Your Own
BF XR6T Ute - 422rwhp tuned by FPT Toowoomba Where the boost junkies hang out -Forced Ford Forums |
21-10-2009, 05:26 AM | #12 | ||
Great write up Monty.
21-10-2009, 02:13 PM | #13 | |||
Rusticating
21-10-2009, 02:41 PM | #14 | |||
Back to Le Frenchy
Nice, better add this into the useful threads sticky!
21-10-2009, 04:58 PM | #15 | ||
Nice write up mate, wish this was around when i did mine!
Sticky for sure!
Daily: AU Forte Wagon Project: AU Fairmont - Wants to be turbo The Family Car: 2009 G6E Turbo Future fun: 1968 Ford Galaxie 500 |
21-02-2010, 03:19 PM | #16 | ||
ROCKING THE EL FUTURA
great write up mate, very basic stuff yeh.
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
21-02-2010, 09:12 PM | #17 | ||
Walking with God
Great work!
GK
07-05-2016, 08:55 PM | #18 | ||
Many thanks for this...
