Old 05-08-2006, 05:58 PM   #61
telstar85AS
thought i had a problem but all is good now.
telstar85AS is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2006, 10:33 PM   #62
89 S-PACK
ive just recently bought a 86 telstar sedan... manual of course
i took it in for rwc and theres a few things ive gotta replace
outer cv boots
all the brake line hoses
and the right front control arm bushes
th ething is i dont have an gregorys workshop manual yet.. and i need the tensionwrench settings for -
- the nuts on the end of the cv joints( the ones that bolt to the wheel hub )
- and the lower control arm bush bolts
some places ive spoken to have just told me to do them up tight but i want to do it properly and by the factory settings
Still about lol...
02 (VX) Holden Commodore Equipe series 2 S/wagon.
Manual, Lsd, Catback, Svsi lpg.
still a nice reliable upgrade from the old magna..
89 S-PACK is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2006, 07:45 AM   #63
dirty hands
Over Thinker
dirty hands's Avatar
Post
front hub nut is 240 nm
the nut should only be used once if you see a groove on the stub axle
you use a screwdriver and hit the nut into that groove after tension to lock the nut in place
or it may just be a spring washer and split pin castellated nut type
the lower control arm bush bolts (no listing for bush bolts)
Suspension unit /control arm
if the bolts a thick then use 119 nm if smaller use 30 nm
other torque setting for that area
Control arm inner mounting nuts 119 nm
Suspension unit to steering knuckle 119 nm
Suspension unit to body 30 nm
Ball joint nut 55 nm
Tie rod end nut 45 nm
My car goes Brumm Brumm
Old 14-08-2006, 01:54 AM   #64
89 S-PACK
Talking
thanks for your help... now ive just gotta put it all back together on monday afternoon
but how many litres of trans fluid does the 4spd manual gearbox hold???
2 litres came out but theres been evidence mines been leaking around the speedo drive
Still about lol...
Old 14-08-2006, 09:03 AM   #65
meanbow
Welsh...and proud
meanbow's Avatar
Default Headlamp removal
Hi there all...i'm in need of assistance in the removal of the front headlamps on my '83 telstar
i need to get the units out to change the headlamp bulbs, as i think mine are blown, as i have no high beams....yet my Driving lamps are still working when i engage high beams or flasher. i've already tested the circuits, and there is current going to all the right places...yet do you think i can get the stupid bulbs out to check them?? :jab:
one one side...i have the aircon pipes and washer/expansion tanks, on the other, the battery. so as far as i can tell...you need to take the units out to change the bulbs.
even the manual i got for the equivelant Mazda 626 mentions removing the headlamps, yet i can't really see how they come out in the first place
any advice/help would be apreciated, as the car is going in for an M.O.T in a few weeks
meanbow is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2006, 09:04 AM   #66
dirty hands
Over Thinker
Automatic transmission information
ATF type F --- full service 5.7 litres
warm up the engine cycle through the gears put the car in park check oil level
should be between L and F
leak should be fixed
look for other leaks at the oil pump,vaccum modulator and drive shaft seals
oil pan bolts 8 nm
no sump nut setting nm (not over tight its only aluminiuim)
Old 14-08-2006, 09:16 AM   #67
dirty hands
Over Thinker
[QUOTE=meanbow]Hi there all...i'm in need of assistance in the removal of the front headlamps on my '83 telstar
the manual assumes you have already removed or got the extras out of the way
so yes you are correct
do the bulbs first before going to all the trouble of removing the lamps etc
dont touch the surface of the headlight bulb --the finger print left blows the bulb within days (dont ask me why )
I came across a quirk the rubber boot sometimes pulls out the wire connection to the headlight bulb on its own I was driving a long and I thought the bulb had blown and it was the wire connector coming off the bulb all the time so I took the boot off for a while and no problem
so you have the mounting brackets and undo the securing nuts and the manual says to remove the head lamp and turn signal as one unit
Old 14-08-2006, 09:22 AM   #68
meanbow
Welsh...and proud
meanbow's Avatar
: without sounding sanppy or ungrateful...but HOW do i get them out?
i can't see any obvious nuts/bolts, apart from the headlamp adjustment screw on each unit.
it's been driving me nuts all day
Old 14-08-2006, 09:33 PM   #69
dirty hands
Over Thinker
does this help ? this is in a suppliment I have
step 4 the plastic stuff around the light has to be undone to get the lamp right out
Old 14-08-2006, 10:46 PM   #70
dirty hands
Over Thinker
it is not an easy job
you see the bracket at the end of the light ,there are two of those each side ....
I hope you can see the screws
and I did break the plastic surrounds to get the headlights out the screws had rusted
Old 15-08-2006, 07:03 AM   #71
meanbow
Welsh...and proud
meanbow's Avatar
Thumbs up thanks!
thanks for that, dirty hands.
i managed to get the units out and replaced the bulbs, now i have lights again!
you are great :Reverend:
while i had them out, i replaced and upgraded the bulbs to crystal ultra blue's...what a difference in the dark they make
Old 15-08-2006, 09:45 AM   #72
dirty hands
Over Thinker
manual transmission sae 80 /w 90 Capacity full service 3.4 litres
fuel tank 60 ltres
brakes dot 3
cooling system 7 litres
engine oil with filter 3.9 litres
engine oil without 3.6 litres
Old 25-08-2006, 03:26 AM   #73
dirty hands
Over Thinker
if anyone has suggestions as to what other helpfull information should be in this section please let me know
Old 25-08-2006, 03:42 AM   #74
GRNKPR
DPC PERFORMANCE Race prep
GRNKPR's Avatar
Sell It
: : i will excell with the knowledge i get on here : :
FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria FPV & XR Owners Club of Victoria
Ford Performance Car ClubFord Performance Car ClubFord Performance Car ClubFord Performance Car Club
GRNKPR is offline   Reply With Quote Multi-Quote with this Post
Old 25-08-2006, 06:29 AM   #75
dirty hands
Over Thinker
mmmm after 1,172 posts you have made that is your best advice
ok I will keep that in mind :eclipsee_
Old 29-08-2006, 12:03 AM   #76
GRNKPR
GRNKPR's Avatar
now i have more posts its still the same advice aaaaarrrrrgggggghhhhhhhhhh im a pirate
Old 04-09-2006, 05:17 AM   #77
meanbow
Welsh...and proud
meanbow's Avatar
Default recommended mileage change of cambelt
Hi again...just a quickie this time
what is the recommended maximum mileage for a timing cambelt on the '83 Telstar as mine is now pushing 73,000 and to my knowledge it hasn't been done.
i basically need to know how long it can go at a MAX on the current belts, as i have to save a bit of cash to pay a mechanic to do the job first
and no sarky comments about changing the car instead please... :
Old 04-09-2006, 07:06 AM   #78
dirty hands
Over Thinker
50,000 km
I made 2 posts on how to do a timing belt -- page one
near the bottom the picture is a shocker
the timing /belt pully has to come off and you work through the wheel arch
I have done it myself but you have to mark the top cam sprocket and not move the engine you can be one knotch out due to the new belt
also check the water pump
I think there is an allen key for the tensioner but I didnt need it
I just slipped the new belt on ---
the timing pully just slipped off after i undid the nut (you might be lucky )
Holla if you need more information :1syellow1
Old 16-09-2006, 01:54 AM   #79
dirty hands
Over Thinker
Default turbo information
I dont know a heap about the turbo versions :
these two sites might help :
http://www.mx6.com /forums
http://z3.invisionfree.com/tx5/index.php?
Old 07-10-2006, 12:34 AM   #80
meanbow
Welsh...and proud
meanbow's Avatar
Question More dash problems...
Hey all...again
this is a major question on the dashboard of the early Telstar...i thought i had the dash problem licked on my model, but all of a sudden...it's started back up again with the intermittent working nonsense.
does anyone know if the dashboards between the models fitted with a digital and an analougue are interchangeable..i.e are all the connections the same?
from a book i managed to get hold of for an equivelant model Mazda 626,a talk to the local Mazda dealer and from a limited knowledge of stripping the damn thing down countless times....it seems very similar to me
just a yes or no will do, thanks :
Old 07-10-2006, 08:00 AM   #81
dirty hands
Over Thinker
check if the digital uses a speedo cable or a sensor at the gearbox
no other info in fittment
Old 07-10-2006, 09:27 AM   #82
meanbow
Welsh...and proud
meanbow's Avatar
i can tell you from experience...it's a speedo cable, not a sensor
Old 07-10-2006, 06:14 PM   #83
dirty hands
Over Thinker
two attachments it is all I have
Old 17-10-2006, 07:00 PM   #84
rammed wx
Default kc laser head gasket
i have a kc laer with a blown head gasket.
if i pull off the head and get it machined and a new gasket.
is it difficult to put back on?
is there any special tools etc.
just wondering, because the mechanic is trying to charge me $800.
thanks
rammed wx is offline   Reply With Quote Multi-Quote with this Post
Old 17-10-2006, 10:00 PM   #85
dirty hands
Over Thinker
a laser question is best answered by the laser guru "vippin" pm him
$800 is about right allowing for head work like welding valve seats a head reface
$400 for head and gaskets and 3 hours labour
special tools- torque wrench, metric sockets ,and a repair manual to know how to get the timing belt right .
Old 18-10-2006, 05:58 PM   #86
GRNKPR
GRNKPR's Avatar
2 months ago i said sell it and your still going aaaaaarrrrrghhhhhhhhhh im still a pirate
Old 19-10-2006, 08:50 PM   #87
meanbow
Welsh...and proud
meanbow's Avatar
and out of all those bits you have listed, how many of them have YOU fitted or worked on....? :dr_Evil:
aaaarrrrrrrggggggggghhhhh! 4:
Old 29-10-2006, 08:54 PM   #88
AutoTX5
Default TX5 Automatic Transmission
I have a Ford Telstra TX5 1989 (sorry it is not an '87) with electronically controlled automatic transmission (EC-AT) (G4A-EL).
The problem is there seems to be unnecssary kick down of the auto, possibly into a lower gear or a slip. This seems to happen regulary during city/suburban driving where there are speed humps and other traffic.
So it seems like that the accelerator is sensitive to slight movements of the foot, and causes the kick down and the revs to go up.
I have tried adjusting the pressure control cable for the auto but a guage is required to check the line pressure accurately.
There is also a Hold button on the auto selector so that the auto stays in the selected gear. This helps but it means you must change the gears manually.
AutoTX5 is offline   Reply With Quote Multi-Quote with this Post
Old 29-10-2006, 10:51 PM   #89
dirty hands
Over Thinker
there is a kickdown band adjustment that can be done at any automatic workshop (someone who knows fords )
and a service oil change and filter would be a good idea
the transmission control tcu or ecu or the icu unit may be faulty
undo the battery teminals for 10 minites this may reset your computers
if nothing changes you may need a diagnostic of those units
wont be a line pressure problem as you have all the gears
Old 01-11-2006, 09:39 PM   #90
AutoTX5
Thanks for the info. Here is some feedback:
I recently changed the Auto oil & filter. A bugger of a job as I had to undo the engine mounts so that I could get enough room to remove the oil pan so I could change the filter. The maunual says you only need a lever to raise the engine???
I also tried to adjust the band (** is this the one your talking about? **) while the pan was out, to the spec of 11 Nm, but it was too hard to undo the lock nut, so I left it. Spewing about this!!!
I have also removed the control unit a while a go so I could put some LED's on the gear change leads that go to auto, but could not make sense of the LED indications. So the battery was disconnected for a long time anyway. A big long reset.
Any other advice I can use as a do it yourselfer or questions I should ask an Auto specialist to make sure they know enough about this type of auto before they dive into it?
