Old 17-07-2017, 11:03 PM   #1
undertow
Technical Contributor: For members who share their technical expertise. - Issue reason: AU Aux input HOW TO.
Default How to add Aux In to your factory head unit
I like the look and fit of the factory head units but not the of lack inputs.
Fortunately it's quite easy to hack in aux in to these head units. All you need is a spare 3.5mm aux cable, or an old pair of headphones to rat for the cable, and a soldering iron & multimeter etc. The end result is quite neat as you can run the cable behind the ashtray etc and out into the centre console storage area.
This article has been moved to the technical portal.
undertow is offline   Reply With Quote Multi-Quote with this Post
Old 18-07-2017, 08:01 PM   #2
SSD-85
Default Re: How to add Aux In to your factory head unit
Someone give this fella ALL the beers.
Ive been wanting to work this out for years.
PLEASE STICKY THIS THREAD
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2017, 12:31 PM   #3
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
Great idea for non premium sound headunits.
For premium sound, just use this.
Which i have been using with great success
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2017, 01:06 PM   #4
falcongt4me
TSCoA member Qld
falcongt4me's Avatar
Where are these? ebay?
Cheers,
Martin Mac.
2002 AUIII TS50 Liquid Silver #206 (ex NZ)
T-Series Club of Australia member; QLD
falcongt4me is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2017, 02:42 PM   #5
mif73
CNC fixer guy
mif73's Avatar
They sound good as long as you make sure the "cassette's" head is aligned to the tape deck's head, or else you may find the left and right channels are of different volume, if so, you can wriggle it with your finger to adjust it.
You can still find these adapters at shops and online.
The other mod you can do with the S1 CD changer type deck is to install a DPDT relay inside the deck and intercept the CD changer L and R audio signals into the deck for an AUX in function, sounds really good!
You then just install a small switch to select between CD Changer audio or AUX in. (only works while a CD is actually playing though as the deck mutes the audio otherwise).
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player.
Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers.
mif73 is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2017, 02:47 PM   #6
PridenJoy
ebay US
http://www.ebay.com.au/itm/ION-Audio...72.m2749.l2649
Are you talking about the bluetooth unit i posted a pic of above or the cassettes with aux cable?
I have been using the bluetooth one and have experienced no issues, sounds great.
Old 20-07-2017, 02:50 PM   #7
Mechan1k
Mechan1k's Avatar
Done ... to make it easier to find for all.
Old 20-07-2017, 02:55 PM   #8
mif73
CNC fixer guy
mif73's Avatar
ebay US
Just the regular aux cable type, but they both can have the same problem if not aligned, not really a big deal for most people though.
The other thing with various blue tooth devices is you are at the mercy of the Digital to Analog converter sound quality, again not an issue for most people.
Cheers, Andrew.
Old 27-03-2024, 10:00 AM   #9
adriantillin
adriantillin's Avatar
Great article - thanks and thanks for making it sticky 👍
adriantillin is offline   Reply With Quote Multi-Quote with this Post
