Wanted Car bits and other general items If you want it and it's not in the For Sale section, post it here |
27-04-2024, 06:04 PM | #1 | ||
someone in the ringwood vic area to run a check on my ecu as vehicle cranks no start and we have checked everything else. standard forscan diagnostics reveals no fault codes
29-04-2024, 05:56 PM | #2 | ||
Are you able to check for volts across your injectors and coil packs?
29-04-2024, 06:08 PM | #3 | ||
Check you haven't blown the coil fuse. It's in the fuse box inside car.
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. |
