Old 03-05-2008, 04:47 PM   #1
DWC
Question Cruise buttons
The coast/resume button on my S1 is busted. I don't have a Gregory's manual or anything yet, so how do you get them off.
All I need to do is glue the button back together and reinstall it.
I'm assuming in advance that Ford will bend me over for a new one
cheers
Dave
DWC is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2008, 08:55 PM   #2
BFD83
BFD83's Avatar
I'm pretty sure there is screws behind where the buttons are and they should come off that way?
BFD83 is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2008, 09:37 PM   #3
Peuty
Afterburner + skids =
Peuty's Avatar
You need to remove the airbag using a 5 sided torx bit. Once it has been removed, then there will be two screws holding the buttons on.
Oo\===/oO
Old 03-05-2008, 10:46 PM   #4
DWC
Never pulled one out. I'm assuming that the torx screws are under the plugs on either side of the wheel?
Are the bags easy to get out once the screws are removed or is there more to be done?
Plus, what triggers the airbag? I'm guessing electric pulse so I should disconnect the battery??
Dave
Old 03-05-2008, 10:54 PM   #5
xftorque
LOW 'N' QUIKK XF UTE
get a pro to remove it, ive seen a shoulder dislocated by an air bag going off while trying to remove it ouch!
xftorque is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2008, 01:44 AM   #6
scrivens
quarter pane
scrivens's Avatar
Have a look at post #23 in this thread:
http://www.fordforums.com.au/showthr...24#post2040024
Covers how I installed CC on my Forte and the first part has the info about getting the airbag off. Check on eBay or the dismantlers - better to buy a new set of switches rather than try and fix the old ones as they'll probably just break again if glued.
scrivens is offline   Reply With Quote Multi-Quote with this Post
Old 04-05-2008, 12:35 PM   #7
Peuty
Peuty's Avatar
Not an issue as far as I am aware. I've done a few and I've never seen it happen before.
Oo\===/oO
Old 04-05-2008, 01:50 PM   #8
waggaclint
waggaclint's Avatar
as long as the battery is disconnected for 5min before ya take the airbag off it will be all ok.....
waggaclint is offline   Reply With Quote Multi-Quote with this Post
