The Thread Killa
Coupla things of interest I found while surfing eBay:
Race Mode Kit VariPower Controller To be honest, I'm curious enough to consider buying one of these to test, but I don't want to f--k up my car. Opinions, anyone?
"It is the mark of an educated mind to be able to entertain a thought without accepting it." - Aristotle |
#2 | ||||
FGX XR6 Lightning Strike Sedan BA XR6 Mk II Shockwave Sedan - Now Sold - gone but not forgotten mods: 20% under drive, Pacemaker Comps 4495' (ceramic coated) , 3' Metal Cat, XR6T exhaust - twin 3' tips, F6 CAI, K&N panel filter, PWR trans cooler, customed tuned by Heinrich Performance Tuning HPT 183.7rwkw. Quote:
check out this re the varipower kit
http://www.tyresmoke.net/ubbthreads/...?Number=410094 I suspect the race mode thing is the same, changing the resistances that the ECU sees so it overfuels. Making the ECU think the engine and the air are cold might do it. cheap and cheerfull. At least the varipower one includes a variable resistor, so you could try it and increase the extra fuel until a problem arises or a light comes on. Personally, I'd not touch it with a very long pole unless I was prepared to trash the engine. |
do it.... dare ya...
Non-Regular Member
#6 | |||
So somehow I doubt it. Pity. |
#7 | |||
Fiestata!!
If you installed such RACE MODE into your car, I am sure that you will be *** kicking by the Ford Service Technician while you perform your car service (my friend is a trainee technician in Dale Ford Service Center). However, they suggest to change only the performance kits (but not recommend for vehicle under warranty) include spark lead and plug, K&N panel air filter, fuel injector and a fuel controller, ECU reset (about $400-$450 - depends on the brand name) from proper garage. This might helps 10-15HPS without damage the engine. |
#8 | |||
Yours for $40 inc postage within Aus
Ringo |
I clicked on the links and nothing comes up, it says something about being invalid
2006 WQ Fiesta Zetec Sea Grey Interior:- MOMO Blue Leather Gear Knob, Window tint, Scuff Plates, ST Black & Blue Leather seats, Soundstream Amp & 5x7 speakers, Sony Headunit, Pioneer sub & Amp. Under the Hood:- Superchips ECU Flash Tune, Denso Iridium plugs, KV85 Magnecor Leads, BMC CDA Induction. Exterior:- Spoiler, clear side repeaters, Lowered (35mm) King Springs, Whiteline 22mm Rear sway bar, 2" cat back exhaust with a dual conversion, Konig 17" Hotswap with Kumho Rubber, HID's. |
#10 | |||
Thats because those items have been sold i guess, if you ebay search you should find some more but make sure you search worldwide as i believe they are only available in the UK
Ringo |
