Drag Racing Discuss Drag Racing here be it dirt or tarmac. Sponsored by Sydney Dragway. |
What sort of tyre pressures should I be using at the drags on my XT?
Cheers Brad
'68 XT Fairmont, 9.48@141.6 '69 Capri '95 triumph speed triple, '10 Fat Bob My XT Fairmont http://www.fordforums.com.au/showthread.php?t=11298079 My capri track car http://www.fordforums.com.au/showthread.php?t=11492523 |
what sort of tyres are you running? weight? hp?
It's my call pizzoff, and I just called it |
your best bet is to get a set of M/T Street Radials don't race on the street tyres.
#5 | |||
I was planning on running the MT street radials, sorry I should of mentioned that. the car would be around 480 - 500 HP & I reckon about 3600 lbs with me in it So what pressures do you think would be best? Cheers Brad
Patience is a virtue
15-18psi mate. Outside these ranges won't do much good. Checkout the M/T website for their bulletins and reccomendations.
417ci CHI headed XD. Dynamic transmissions C4 Track times 60ft pb 1.365 ![]() 10.173 @ 134.97mph 1/4 6.324 @ 108.93mph 1/8th PB SOLD ![]() |
Thanks Joe
& for anyone else who wants to know http://www.mickeythompsontires.com/tech.php?bulletin=s3
Are you going to invest in some caltrac's or slapper bars? They are a good investment. I went a 1.48 60ft on oztracs this last wknd so they help hook you up
#9 | |||
I figured Id run with them first & see what happens. How much are oztracks & where do you get them from? Ive never driven a car down the chute but I have had my current bike & my last 2 down there with a best time of a low 11 Any advice for a first timer would be appreciated Cheers Brad
What are the Macdonald Bros version like?
http://www.mcdonaldbrosracing.com.au/trackrods.html
#11 | |||
Brad this one doesnt run anywhere near these pressures (22-24 rings a bell) , using slidealinks though http://www.fordforums.com.au/showthread.php?t=11258423
#12 | ||
I'm running 18psi and can go to 14 if I have to but only on the strip.
Ian |
#13 | |||
i bought those then got some 10mm lower plates made up to weld the rear mount to. dont forget to reinforce the rear spring perches as well to stop them breaking off |
#14 | |||
Were the macdonald brothers version of the traction bars a "bolt up fit" or do they need some mods to fit? Cheers Brad
#15 | |||
although i did have to grind a bit off one of the bolt heads either side because it was just touching the chasis rail when it pivoted. just check that when you bolt it all in to dummy up where you need to weld the rear mounts too. (weld the brackets so you have plenty adjustment either way so you can back them off or put a few turns off preload on the leaf) |
#16 | ||
So when do you plan to give the track a touch up ?
#17 | |||
I'll let you know how I go. Cheers Brad
#18 | ||
Sounds sweet a much wider radial than Blocker runs (235/60/15) enjoy your racing :-)
#19 | |||
Looking at doing the same thing |
#20 | |||
Seems to know his stuff He runs a EK that does 9.1
#21 | ||
Dont run any less than 14psi in ET Street Radials . They will start to loose traction and your 60' will go backwards .
I always run 16-17psi in mine .
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
