13-08-2014, 09:27 AM | #31 | ||
I already have a motorcraft one on its way, as I had also read many negative comments about dorman.
13-08-2014, 10:52 AM | #32 | ||
5.6L x 2 pilot
Tool is not needed. Before you remove the old, take the black cover off, set you crank to TDC on the compression stroke - you will see that the tab on the sync will be exactly mid point in the gap - insert your new sync in the exact same position. It will make sense when you do it.
Regards Stu
25-10-2014, 11:58 AM | #33 | |||
Does the cam sync. affect the oil pumping through the motor? (If it does... could it be still turning but not effectively pushing oil up to some parts of the head?) - I have a problem with noise when warm and around valvetrain on cylinder 3. (Everything was replaced - lifters, pushrods, rockers, valve springs, retainers - valves were reused.)
'01 AUII XR8 Ute - "200kW" - As good as burning money. |
05-11-2014, 01:49 PM | #34 | ||
I dont chance those imports check out Ghostraceparts on ebay they sell Ghostauto camshaft synchronizers ,I purchased 1 run it in my street machine doesn't skip a beat looks trick aswell hand built for Australian muscle cars
06-11-2014, 09:12 PM | #35 | ||
T-Series Club Member Vic
I'd not recommend Taiwanese 'Standard' brand to anyone. Mine last less than 12 months and a P250 owner had one do the same thing but eventually it sheared off it's pin and stop turning the oil pump.
Either get your Motorcraft one rebuilt by a distributor reconditioner, or get Motorcraft. The GhostAuto ones look great and I'm sure the seller is very confident in his product, but I personally don't see any reason to get away from Motorcraft. Post 290 http://fordforums.com.au/showthread....390554&page=10 The Ghost product is currently listed under the title, 'AU XR8 AU1 AU2 AU3 5LT 5.6LT Camshaft Synchronizer Tickford fpv TE 50 TS50'. At $330 I personally would want to know it was good for 200,000k's+ |
06-11-2014, 10:40 PM | #36 | ||
Gday Mate one of my mates put me onto the Ghostauto camshaft synchronizers he has put 120,000 k on his ghostauto camshaft synchronizer , hasn't skipped a beat , ive put 60,000 k on mine no problems at all in my 5.6lt 347 , each to their own I guess ,im happy with my purchase Ghostauto rocks
06-11-2014, 11:14 PM | #37 | ||
not here much anymore
RAM 1500
3 users like this post: |
06-11-2014, 11:50 PM | #38 | ||
3..2..1..
That ghost auto one looks identical to the dorman one I'm using.
07-11-2014, 01:00 AM | #39 | ||
07-11-2014, 07:18 PM | #40 | ||
3..2..1..
Where are the ghost auto ones made?
11-07-2016, 10:53 AM | #41 | ||
are those ghost auto syncro's still available?
17-01-2019, 11:11 PM | #42 | ||
Hey man. just wanted to say thats a nice looking a.u. in your photo.
