#31 | |||
All people have the right to stupedity but some people abuse the privilege |
#32 | ||
Id say rusty killed alot, head gaskets would have killed some more, scrap'ies (never looks right however I spell it lol) would have killed a few, young roster heads followed by 'power junkies ' ( if it lets me say it )
#33 | ||
#34 | ||
What a good article, they know about comfort, , simplicity, reliability and common parts!
I6 + AWD |
#35 | |||
I thought from VB Commodore they were using a much better steel, only the windscreen became a problem area after the old one was pulled out and took the paint off, then the problems kicked off ! Then again back in the 1960's to say 1980 we had highways that were the type that you had to get 2 wheels off onto the dirt when a car came the other way, so the left side coped a lot of mud etc and many % people did not bother to wash their cars well or parked them outside. More Dirt roads as well years ago and dirt gets in the bottom of the doors and then rain and due from sitting out side makes more rust and the bottom of the doors would block up, i would have to poke a stick up the drain holes many a time as you would hear water splashing when shutting the door. Look at how wide the roads are now ! no chipped windscreen once a month anymore nowadays. I just believe that people back from before 1990's did not look after a car as well as some do nowadays. I think more people have learnt to look after their car nowadays because you have to Radiator coolant for one or else ! many more know this nowadays ! before such was no an issue ! So i hear people claim that the VL 3.0L was a crap engine ? i reject that and put such down to not servicing them correctly and not bleeding the radiator is a big mistake many made. Falcons got better with rust from XD on and were the much the same to the end, maybe a bit better. But i believe that the steel from 1972 to 77 with ford and Valiant was that Holden got first dibs regarding steel and Ford came 2ed but had to import some times and Valiant's came 3rd so they had to get steel imported at times and this was old crap steel that was melted down to make new steel, but within this was small % of rust that was within the brew, even tho they had skimmed off all of the crud from the top ! Am i correct for them years, maybe they got the art work better regards such. The VB Commodores got a new formula for steel they claim and coating and a smash repair dude i know well said that welding this steel was harder than before. |
#36 | ||
Purveyor of fine filth
Ford never really sorted their panel prep and paint processes in Australia, whereas Holden to their credit pulled the digit out with VN and they didn't look back. The only Commodores VN and newer I see that are rusting are the ones that are poorly repaired after a shunt.
#37 | ||
BLUE OVAL INC.
Up until VN production Holden only dipped the bodies to the waist line and because they went through the dip on a conveyor the wave and wake created a void around the rear windscreen base which rusted out, this processed changed with VN and the whole body was dipped.
Falcond prior to EA were prone to rust in the plenum which would flood the front floors and required substantial work to repair in removing windscreen, dash, gaurds, bonnet and then cut open. I had a beautiful XE in 2000 but couldnt take it out in winter for this reason. Obviously E series suffered head gasket issues that really affected not only daily driven cars but limited the used engines available in wreckers too. The funny thing is, they fixed that in AU and wreckers couldnt give them away. I spoke to a mate who owned a used car yard back in 07 and he said every manual Falcon he could get his hands on went up north to indigenous communities as they loved them and paid way overs to what could be sold for down here, he said lots of yards did the same. Probably plenty still active albeit unregistered. I got a nice XE S pak off him that day as it was auto and worth nothing, gave it a straight gas conversion and sold it to a FF member. So there are a few factors at play. |
4 users like this post: |
#38 | ||
Forgot to mention taxis
#39 | |||
#40 | ||
Regarding XF/XG/XH utes not surviving compared to Holden utes, remember that the Falcons have always been used for work, where the Commodores have usually been for play.
Holden even tried a 1 tonner VZ and I think they only sold a few hundred. Sure they rusted but I've been through heaps of wreckers and rarely did I see one scrapped solely due to rust.
#41 | |||
They made 1 Tonners in both VY & VZ & they sold many 1,000s in 2WD, but the AWD version was VZ only & it sold in much smaller numbers. Dr Terry |
#42 | |||
Cabover nut
Genset and granite to Beechworth today 4 new tyres on the way home.
#43 | ||
B1 - J & D Services
![]() Join Date: Aug 2005
Do not discount the thousands of Falcons used as race cars over the years having a significant effect.
Mr. Brett Johnstone. ![]() 2007 Honda Odyssey 2002 Ford Laser 2000 Ford Falcon Wagon Egas 1999 Subaru Imprezza Sportwagon 1998 Holden Suburban 2500 1995 Land Rover Discovery TDI 1994 XG XR6 Longreach 1983 Holden Rodeo 1982 ZK Fairlane 302 six seater 1975 Datsun 120Y wagon 1970 MG Midget 1967 Rover 2000TC Soon: Model T. |
#44 | |||
Maybe the fact that the Falcons were used as taxis while the Commodores weren't might have some effect. |
#45 | |||
Cabover nut
#46 | ||
praek tih kl jo kr
#47 | ||
Experienced Member
Correct, I still see plenty of HQ's getting around, not bad since they were considered a rust bucket.
#48 | ||
In some instances, scrapping a vehicle that’s become unroadworthy may yield more in return than trying to fix it.
I remember seeing a 2020 price of $6,600 for rebuilding ZF6HP. and think it must surely be more now… |
#49 | ||
Same with Hyundai Excels, when was the last time someone saw one of those things? The excel racing series took them all from us
![]() Saw there's a Mazda RX8 racing series, thats the next nugget car thats going to completely disappear - those things would be stacked 10 high at the tip otherwise. Only thing they're good for is LS conversions. |
#50 | ||
G8 220 and in the same carpark a DC LTD - both well looked after.
Yesterday a burgundy EL XR6. Day before a unrestored XB GS. (See it occasionally getting around) There's also an old duck getting around in unrestored ZK Fairlane near me.
#51 | ||
praek tih kl jo kr
#52 | |||
RS The Faster Fords
![]() Join Date: Feb 2014
Before the Excels it was the Daihatsu Charade, when I had my GTti race car the only way to get parts was to buy whole cars, even then you had to be quick, the speedway guys were buying up and hoarding everything.
#53 | |||
Dr Terry |
#54 | ||
There are a few different figures around on Holden build numbers. Drive and News seem to agree on the HQ as the biggest selling Holden and the VT as the biggest selling Commodore.
Drive said: “485,650: The biggest selling Holden of all time, the HQ Kingswood, made from 1971 to 1974. 303,895: The biggest selling Commodore of all time, the VT series, made from 1997 to 2000. https://www.drive.com.au/news/holden...ws-since-1948/ News said: “The VT was the biggest selling Commodore model of all time, with a staggering 303,895 built over almost three years. However, that’s still not as high as the HQ Kingswood (485,650) in the 1970s.” https://www.news.com.au/technology/i...73e59e92554186 Carsguide offered this opinion as to why the VT was so successful: “ It also helped that the Falcon of the day was regarded as ugly, prompting buyers to flock to the Commodore in droves.” https://www.carsguide.com.au/car-new...he-years-35814
2022 ZH Escape ST-Line AWD 2.0L Ecoboost |
#55 | |||
praek tih kl jo kr
I think most Holden figures are what were sold in Australia, they sold knock down kits to South Africa too |
#56 | ||
Yesterday I went for a drive from Melbourne to Echuca and back. I saw no less than 8 AU falcons/fairmonts in aii body variants. I only saw 1 vy commodore. AUs have certainly outlasted by miles the same era commodores.
#57 | |||
And the Falcons were in good condition, a lot of FG series I saw.
Ford Rides: Ford Fiesta ST Mk 8 -daily- closest thing to a go kart on road for under 50K FG X XR8 smoke manual - Miami hand built masterpiece by David Winter, BMC Filter, JLT Oil separators, Street Fighter Intercooler Stage 2, crushed ball, running 15% E85 and 85% 98- weekender |
#58 | ||
Cabover nut
There's still a good supply of HQ utes and tonners (occasional wagon, Monaro's and Statesman) getting around but not so much of the Belmont/Kingswood sedan variety.
#59 | |||
While Earlier Commodores were European based to varying degrees, by the time you get to VE, the body/chassis is 100% Aussie designed & built. The drivetrains are mostly US units. I doubt that you would find anything Euro in a VE or VF. Much like the Falcon, early ones were very US-based Then less so by XA & even less so by XF. EA onwards doesn't have much US left in in them. AU onwards nothing left. Also all Holden build figures include all overseas built units, because they were CKD packs. The packs were made here then exported & they knew the exact numbers. Dr Terry |
#60 | ||
I thought big end bearings on the Falcon sixes remained a constant?
As to the VE, weren’t the locks (Huf) a German company?
Apple, Table… something! |
