13-02-2013, 04:24 PM | #1621 | ||
Imagine a full 20L jerry can of fuel and a empty 20L jerry can of fuel. If you put a hose between the two fuel taps and turned them both on the full can will drain into the empty one until the fuel level is equal between the two ie each half full
13-02-2013, 04:36 PM | #1622 | |||
Pethy FG XR8 Ute
yeah i new about that, but when i posted that other stuff i read his post again and was thinking about something else when i read just that and confused myself thought it had to do with something else ...thank god its fly out day, 9 days of work is doing my head in
FG XR8 Ute 2010 Nitro, Mods so far: Herrod CAI, headers, Ballistic cats, Cat back Manta dual 2.5" with X pipe and hotdog mid section, Mellings oil pump, Summit racing 60mm twin throttle body, and Yella Terra plenum Powerbond 25% under drives, Sports bar, now fitted with Koya Inox R1's, the rears are 20x10 with a 40mm offset and the fronts are 20x8.5 with a 35mm offset total of 285.5 rwkw and 642nm when Herrod cams in 290rwkw GSXR 750K7 with goodies, dyno'd 136rwhp, 10.567sec for the strip |
13-02-2013, 06:57 PM | #1623 | |||
That said, a few years back when I was selling SunPower systems a SunPower 3kW would be averaging between 18-20kWh in Perth over a 12 month period. It is to do with the broad spectral response of the panel i.e. even though the maximum power is 3kW, different panels can make different amounts of power in different light conditions. Imagine batteries like a series of rainwater tanks. Just like when all the tanks are connected, as you draw water off, the water inside the tanks will naturally find its own level and they will all have the exact same amount of water in them at any given time, electricity stred in batteries is pretty much the same (if that makes sense lol)
DAS IT MANE
13-02-2013, 07:39 PM | #1624 | ||
6 hours per day is the accepted yearly average of usable solar hours per day,....assuming you are in the "central" band through australia......to get your "average" kilowatt output, you times your kilowatts by usable solar hours
if you are in "the central band" then you work it out by 3 kilowatts X 6 hours per day = 18 kilowatts remember this is an average and will vary,....... summer you should be getting a lot higher (more solar hours per day) winter less (less solar hours) hence the "average" in "the zone" the average will apply, below "the zone"...will be less and above (toward banana bender country) it will be more this time of year, in an "ideal" situation i would expect 20 kilowatts out of your system, winter it may drop to as low as 12 kilowatts, perhaps even less........but without taking many measurements, including angle, northern exposure ETC...... it is extremely difficult to say if you are below "spec" my GUESS is yes it is not performing as it should
--------------------------------------------------------------- G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II... may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon! |
13-02-2013, 08:02 PM | #1625 | ||
Too many Fords........ :)
We really need to know how the Panel strings are connected - 3x5 or 1x7+1x8.
Let us know if you can tell, without digging too deep into the system.
Current Projects 97 EL V8 wagon - cool cruiser, or street bruiser? CLICKY 93 XG panel van - at your door in 60 secs, or the first hr is FREE........ yep, that's the goal. 95 XG ute - awaiting a head gasket...... grrrrr. 74 XB GS pano..... factory optioned with all the good stuff..... not much there now. ........long term resto. XB Coupe and Van TV Ad you know........ there's a little bit of Bathurst in every Ford Falcon.... think about it |
13-02-2013, 11:20 PM | #1626 | ||
Pethy FG XR8 Ute
yeah i will get on in the roof tomorrow and check out how they hooked it up, but they did tell me it was hooked up in 3x5 panels
i kept telling him i was hitting 16 units a day in the beginning of sept on some days and it hasnt gotten any higher even though there is more sun now than in sept?? he didnt have an answer for it i will get a few pics tomorrow and see what angle the panels are etc the highest i have seen from my is 16.7 units for a day and that was the other week
14-02-2013, 01:09 PM | #1627 | ||
not enough mate.......I'd expect a couple of 20's in there.......but as sparky says..... really hard to tell from a distance
14-02-2013, 03:58 PM | #1628 | ||
His: : BA RTV V8 Lightning Strike LILP Gas :FG XR6 Kinetic Eco-LPI, Hers: Titanium Territory, Smoke |
14-02-2013, 04:15 PM | #1629 | ||
Any chance the panels are dirty and just need a good clean to up the kW/h? Is there a spot above them where birds can sit and crap on them?
Cheers, Sam. |
14-02-2013, 04:55 PM | #1630 | ||||
What has not been suggested is perhaps a hot spot on one of the panels i.e. busbar has lifted off one of the cells causing it to become much hotter than the rest of the cells and acting as a resistor... If you're game enough to you would have to hop up on the roof and inspect every solar cell and look for any bubbles in the busbars (15 panels @ 72 cells per panel, might take a while!) Quote:
DAS IT MANE
14-02-2013, 04:57 PM | #1631 | ||
Also I just got back from my Bathurst road trip and found out the BDM is working a sustainable festival in Seymour for the rest of the weekend so won't get to work on that bulk buy deal until next week sorry guys!
We'll get one organised soon enough
DAS IT MANE
14-02-2013, 07:11 PM | #1632 | |||
Rob
according to you, my system is rubbish (TVS - made in china) so i'm pretty happy with how my rubbish system is going at the moment. |
14-02-2013, 09:56 PM | #1633 | ||
Pethy FG XR8 Ute
i did a bit of adding up and for 5 months from july to the end of december i made a total of 2333kwh total didnt get june as they were installed towards the end of the month
i think Jan total for the month was 470kwh odd i think the panels are clean i washed them a couple of weeks ago and it made no real difference i didnt get time to get up there as i had a few ute problems today but thats another story
14-02-2013, 10:03 PM | #1634 | ||
yeah! thats around 15.5 KW average.......without seeing your system i still say thats a bit low
Jan. 15.6 KW......should have been higher than your previous average...... cleaning can give you a few hundred watts but not a hell of a lot, depending on the amount of grime present mine are close to brown at the moment and it shows......16 KW produced and dropping after producing a consistent 20 KW until the last dust storm gotta get off my bum and give them a scrub
15-02-2013, 02:19 PM | #1635 | |||
Not happy now a smart meter has been installed. used to enjoy the back spinning disc of the old meter. |
15-02-2013, 02:33 PM | #1636 | ||
I'm surprised you get any sunny days in Goulburn, lol. My bil +sil are building in Goulburn atm and have decided not to go the solar route. I think they will be sorry in the long run. Big house, 4 very young kids and its their family home probably forever. Whats the FIT in NSW nowadays?
igodabigblackshinycar and I relented and allowed a BMW into the garage. |
16-02-2013, 12:14 PM | #1637 | |||
Looking for clues...
On a good sunny day I've seen up to 30kwh a day, on a cloudy rainy day I've seen it as low as 13kwh (mind you I haven't documented anything, and don't check every day). I know Brisbane is a different latitude to Perth, I'm not sure if that makes a difference to Comagutsa's figures.
2016 Ford Falcon FG/X XR6 Turbo you beaut ute 1985 XR4Ti Sierra - Build Thread 1971 Fairlane 500 and... a collection of Jeep Towpigs and... two collections of rust and some new plastic bits roughly shaped like an F-Truck and.... some spare metal bits with holes in them |
17-02-2013, 05:45 PM | #1638 | ||
Pethy FG XR8 Ute
righto i have gotten into the roof and stuff noes what im looking at haha
on top bugger if i know whats happening with the wiring here as i cant get under there ok this is in the roof and then those wires that come out of the white conduit go into this box and then they come out and go over to the garage the wires that are not in the white conduit you see in the pic 3 up that come from the bottom panels also then meet up with the one that comes out of the box (above pic) and go into the garage together found this text on some stuff sent to me when i brought it System overview 15 x Suntech STP200S-24/Ad+ (North) Azimuth angle: -180°, Inclination: 25°, Mounting type: Roof, PV peak power: 3.00 kWp 1 x SB 3000TL-20 Technical data Total number of PV modules: 15 PV peak power: 3.00 kWp Number of inverters: 1 Nominal AC power: 3.00 kW Annual energy yield (approx.)*: 5076.10 kWh Energy usability factor: 100 % Performance ratio (approx.)*: 83.3 % Spec. energy yield (approx.)*: 1692 kWh/kWp Line losses (in % of PV energy): 0.46 % Unbalanced load: 3.00 kVA *Important: The yield values displayed are estimates. They are determined mathematically. SMA Solar Technology AG accepts no responsibility for the real yield value which can deviate from the yield values displayed here. Reasons for deviations are various outside conditions, such as soiling of the PV Modules or fluctuations in the efficiency of the PV modules. Sunny Design 2.20.1. they are telling me its hooked in 3x 5 panels but i cant tell ???? any ideas
FG XR8 Ute 2010 Nitro, Mods so far: Herrod CAI, headers, Ballistic cats, Cat back Manta dual 2.5" with X pipe and hotdog mid section, Mellings oil pump, Summit racing 60mm twin throttle body, and Yella Terra plenum Powerbond 25% under drives, Sports bar, now fitted with Koya Inox R1's, the rears are 20x10 with a 40mm offset and the fronts are 20x8.5 with a 35mm offset total of 285.5 rwkw and 642nm when Herrod cams in 290rwkw GSXR 750K7 with goodies, dyno'd 136rwhp, 10.567sec for the strip Last edited by comagutsa; 17-02-2013 at 05:51 PM. |
18-02-2013, 01:48 AM | #1639 | ||
From the looks of the cabling, they could be 3x5.
Which way do the panels face? North, East, West (or god forbid..... South)
18-02-2013, 02:00 AM | #1640 | ||
Have you got any pics of the inverter setup?
18-02-2013, 02:11 AM | #1641 | |||
Where about's in the solar system, was this picture taken? On one end, or in the middle? I could be wrong, but if the panel on the r/h side of the pic, is an end panel........ it appears that it's just plugged into itself, without being a part of the system. Can you take another pic showing where the wires go for that panel?
18-02-2013, 10:16 AM | #1642 | ||
oh boy.....I can see a multiple of failings here.......junction boxes zip tied to bearers?
wiring able to rub on different surfaces unsupported wires wiring sitting on the roof.......I dont know much about the solar wiring side, I'll leave that to the qualified, but I would not be real pleased with the install
18-02-2013, 11:14 AM | #1643 | ||
Yeah they have gone a little crazy with those cable ties...
DAS IT MANE
18-02-2013, 11:17 AM | #1644 | ||
This is what it should look like behind the panels, this is one of the commercial systems that we have installed
And of course, Stagg specialises in Sexy Solar ahahahahah
DAS IT MANE
18-02-2013, 11:33 AM | #1645 | ||
much better, however you do have far more room under yours to tidy up!
18-02-2013, 11:52 AM | #1646 | |||
I could be a little sneaky as I'm going out to quote a previous PV customer on a SHW system, I could ask if I can climb up on the roof and inspect his system and get some photos. That particular home might have some interesting photos, as the customer has a slate roof of 35 degrees and with slate roofs we have to make perforations using a specialist slate roof tiler. We also had to use a cherry picker and he has high ceilings. I haven't been out to look at his system but let's hope that my sparkies did a good job!
DAS IT MANE
18-02-2013, 12:00 PM | #1647 | ||
yeah! I'm still not sure about this solar hot water.......had a call from Origin last week with a very good offer......I just dont know!
18-02-2013, 12:09 PM | #1648 | |||
However, expect to pay anywhere from about $4000 to $6000 for a system. I believe Origin is offering the Dux Sunpro systems too?
DAS IT MANE
18-02-2013, 12:19 PM | #1649 | |||
Pethy FG XR8 Ute
yeah its an end one ..i will get back up there later and get some more pics for you panels are facing north and i will get a pic of the inverter for you also later today yeah not really happy with the wiring job
18-02-2013, 12:25 PM | #1650 | ||
Wiring seems that everything is in place, but whether it looks sloppy or not shouldn't really affect the performance of the system.. As long as everything is actually wired correctly it shouldnt matter how it looks
That said if I got solar panels put on my roof (if I could afford a house lol) I would still want a clean job.
DAS IT MANE
