Old 21-07-2019, 12:15 PM   #1
MrDavo69
Default Tool for removing the sump plug on my Mondeo 2010 MB TDCi?
Hi All,
I have a Ford Mondeo 2010 MB TDCi 2.0 Litre.
I'm now trying to change the oil. However it is proving difficult to find the correct tool to remove the sump plug.
I tried a T50 (hex) tool, but that stripped the plug slightly (as shown below).
https://yadi.sk/i/u9ZzJB4s9rJymA
Can anyone please tell what tool I need to remove this plug?
Also does anyone know what thread size the sump plug is?
I ideally want to replace the one that I currently have with a standard bolt.
Any help will be really appreciated.
Kind Regards,
Davo
MrDavo69 is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2019, 09:36 AM   #2
russellw
russellw's Avatar
Default Re: Tool for removing the sump plug on my Mondeo 2010 MB TDCi?
The sump plug is an M14x1.25 and I believe the fitting is actually an H8 size (8mm hex key).
Old 22-07-2019, 01:22 PM   #3
NZ XR6
Yes, definitely hex and not Torx. I would suggest a hex socket to remove it, not a L shaped key.
I'm not sure a normal bolt will work as the drain hole is slightly recessed.
Good luck.
Old 22-07-2019, 03:01 PM   #4
These https://www.supercheapauto.com.au/p/...es/326049.html
Old 24-07-2019, 09:43 PM   #5
cobrin
Challenge Accepted!
cobrin's Avatar
cold chisel is what I used on mine from the damage Darra Ford did to the poor vehicle over the years (amongst other lazy sh*t they did). Couple of taps around the edge saw it start to move and come free. I replaced it with a different plug and thought about a smart-0-seal plug but couldn't be bothered in the end.
It's been crossed threaded (see what I'm saying Darra Ford) and is still hanging in there cause it's only a plug and doesn't need a breaker bar to be 'done up'. /end rant
Undecided replacement...
Old 19-05-2020, 12:35 PM   #6
bucknbuzz
[QUOTE=cobrin;6321679]cold chisel is what I used on mine from the damage Darra Ford did to the poor vehicle over the years (amongst other lazy sh*t they did). Couple of taps around the edge saw it start to move and come free. I replaced it with a different plug and thought about a smart-0-seal plug but couldn't be bothered in the end.
keen to learn how you did this, I'm in the same boat, trying to do my first service on a 2010 focus and the hex fitting is rounded (i think they done the bugger up with a rattle gun last service). when you say a few taps around the edge, what exactly did you do?
thanks
bb.
bucknbuzz is offline   Reply With Quote Multi-Quote with this Post
Old 19-05-2020, 02:46 PM   #7
Also an option https://www.supercheapauto.com.au/p/...ce/345462.html
Old 19-05-2020, 02:51 PM   #8
bucknbuzz
Originally Posted by aussiblue View Post
these look good but its too late, I fear the bolts rounded on the inside as the 8mm allen key on a socket I have fits it but only just catches on corners without locking in, so I can't undo the bugger, i need an idea on how to get a damaged one out.
thanks for the tip, im heading up to SCA today so may check them out.
bb
