29-01-2020, 04:54 PM | #1 | ||
The Mistubishi 4N14 is a TD, described as having a "variable diffuser".
Now I'm only guessing, but assume this is the view without any of the intake, which presumably would run through an intercooler to the other side. So what is the "Diffuser"?? And what does it do?? That big thing on the exhaust output, is that a DPF, or just the cat? I know some engines mount them very close to the output.
Time to Make the Hippies Cry Again Last edited by Crazy Dazz; 29-01-2020 at 05:04 PM. |
29-01-2020, 06:20 PM | #2 | ||
IIRC the job of the diffuser is to slow the speed of the air flow while increasing pressure.
My uni studies are very old but I think Bernoulli's principle is releveant here. |
4 users like this post: |
29-01-2020, 07:37 PM | #3 | |||
Thailand Specials
29-01-2020, 07:50 PM | #4 | |||
Ah ok, so it's on the air side. Might not even be in the picture, as the intercooler etc is missing.
Time to Make the Hippies Cry Again |
29-01-2020, 08:23 PM | #5 | ||
Pretty sure it's a cat.
Dpfs are further down the exhaust.
29-01-2020, 09:34 PM | #6 | ||
my take on it is a variable vane in the outlet diffuser That is the (technical name of the compressor housing)just like they do in the exhaust housing but in reverse .
29-01-2020, 10:10 PM | #7 | ||
Yep, as others have said. It’s a divergent duct, reduces velocity but increases static pressure. The Mitsi in the ad probably has variable vanes similar to a jet engine compressor I’m assuming. More crap to fail in the never ending quest to make the wheel rounder
https://www.mech4study.com/2017/11/c...ompressor.html |
2 users like this post: |
30-01-2020, 12:02 PM | #8 | ||
30-01-2020, 01:28 PM | #9 | |||
Found a reference here of another type of variable diffuser but i'd say idea is the same with the mitsubishi one: http://www.glturbo.com.cn/english/vvd.asp
30-01-2020, 01:54 PM | #10 | ||||
orientation of the DPF has no impact on how the soot is trapped. look carefully at the outlet of the can. the tube is for pressure sensor and that is to determine how full the DPF is |
30-01-2020, 04:55 PM | #11 | ||
Thanks simon. Appears to be a ceramic coated dpf. I have not seen this system before. I have only seen dpf's horizontal and further down the system.
30-01-2020, 09:02 PM | #12 | ||
They put the diffuser in the air intake, so you can use different oils to make the exhaust smell nicer.
2004 Mercury Silver Falcon XR6T - 5 Speed 2017 Platinum White Mustang GT - 6 Speed 2022 Blue Thai-Special for Daily Duties - Auto |
3 users like this post: |
