Old 11-06-2021, 07:55 PM   #1
kiwimagic
kiwimagic's Avatar
Default DRL relay trigger wire
Hi All.
My wife has asked me to add some DRL's to her 2009 Ford Fiesta.
I have fitted the lights and a relay to power them. What I can not find is a ACC controlled power source in the engine bay to trigger the relay to operate the DRL's. I can only find power sources that are all ways on.
Any suggestions of where to look.
cheers
kiwimagic
1990 F150 351 W. XLT (for Sale)
1991 SAII Verde Capri Convertible DOHC (sold)
1994 SE XR2 Turbo Capri Convertible DOHC (Sold)
2010 Ford Fiesta (wife's Car)
2017 Blue Sky Monterey caravan.
2017 Ford Ranger XLT.
kiwimagic is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2021, 01:30 PM   #2
russellw
russellw's Avatar
Default Re: DRL relay trigger wire
If you look at the engine bay junction box, one of either F23 (15A), F30 (20A) or F36 (20A) should be blank as they are used for 'optional' features so you should be able to power the relay from one of those as they are only 'hot' in the run position.
Old 12-06-2021, 10:57 PM   #3
kiwimagic
kiwimagic's Avatar
Where is the engine bay junction box found. ? Is it the fuse box on the passenger side
Old 12-06-2021, 11:31 PM   #4
russellw
russellw's Avatar
Have a look at the wiring schematics for your model in our Tech portal as it contains the locations of the various junction boxes.
Old 27-06-2021, 09:58 PM   #5
Luke Plaizier
Lukeyson
Luke Plaizier's Avatar
In the engine bay, that Junction Box might be referring to the box clipped to the back of the Battery Box? It can be a bit hard to get to and remove, but that's the only one i can think of. The main high current breaker fuses are nearby as well - the big 40, to 120A jobbies.
Luke
If the human brain was simple enough to understand, we'd be too simple to understand it.
Luke Plaizier is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2021, 10:38 PM   #6
kiwimagic
kiwimagic's Avatar
Hi. Yes that is the fuse box I found the power source for the lights and also have found a Acc power point for the trigger wire. The top row of fuses are powered all the time. But the second row power up in Acc mode.
