Old 01-12-2015, 07:38 PM   #1
George V
Question AU 2-3 remote: Unlocking all doors with one button press
Hi,
Anyone know of any aftermarket AU 2-3 remote fob capable of unlocking all doors with one button press?
I bought a few aftermarket fobs off ebay over the years; could not programme any to "all door opening" mode .
Regards,
George V
George V is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2015, 08:49 PM   #2
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
Default Re: AU 2-3 remote: Unlocking all doors with one button press
Only genuine remotes i have had success with in opening all doors with one press.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2015, 10:02 PM   #3
david lee
i had to replace mine about 4 years ago and at the time they were $120 new i paid $20 from a wrecker and still works good you can get them on ebay for about $12 from china but i dont know if i would trust them but for that price what have you got to loose.
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 01-12-2015, 10:38 PM   #4
foxtrot3
foxtrot3's Avatar
Originally Posted by George V View Post
Hi,
Regards,
George V
Hi might be that they cannot transmit both button pushes at once to change the opening mode. Cheers MD
HI
I'M MICHAEL
Old 01-12-2015, 10:47 PM   #5
SLO247
I didn't even know it could be changed. Whats the procedure?
SLO247 is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2015, 09:02 AM   #6
foxtrot3
foxtrot3's Avatar
Hi. Should be the same as the BA, hold down both the lock AND the unlock buttons on the remote at the same time until the blinkers flash. When you use that remote the car will unlock single door then a second press will unlock the rest of the doors. Change it back the same way. Only works with the 4 button remote. Cheers MD
HI
I'M MICHAEL
Old 02-12-2015, 12:11 PM   #7
david lee
you have to press the unlock button twice to unlock all doors
Old 02-12-2015, 12:30 PM   #8
PridenJoy
^or keep your finger on the unlock button.
Old 02-12-2015, 04:36 PM   #9
George V
Hi,
So there is no aftermarket option for this. I have a few of those and tried; you can not reprogram them by pressing both buttons.
Last of my OEM unit failed recently - broken soldering / joints. Time to order OEM units. Mrs uses my car once in a while to transport our toddler; fumbling with remote to open back passenger door is not an option....
Thank you all,
Regards,
George V
Old 28-01-2016, 01:03 PM   #10
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
My understanding is that the function is not 'remote' based, but BEM based.
Once you set the BEM to have an unlock command unlock all doors (as all AU's should be, always, ever) then it's right for all remotes that you have coded to the car.
Old 29-01-2016, 07:32 PM   #11
rmack
rmack's Avatar
I have both a OEM and 3rd Party keys, both are programmed to the BEM.
I can change the OEM to single or dual stage unlock.
3rd Party can only do single stage.
Each key can behave in it own way. Not one out all out.
BUILD AU II FAIRMONT GHIA
HERS
AU II Fairmont Ghia
7" DVD/GPS Radio
19" Wheels
HIS
FG XR8 Ute
Lux Pack
Tech Pack
Touch Screen GPS
rmack is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2016, 02:20 PM   #12
Spurious
Exactly.
Spurious is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2016, 10:59 AM   #13
Whoosha
AU DIE HARD
Whoosha's Avatar
Originally Posted by Riksta
Old 17-01-2020, 11:19 AM   #14
Steve D
Irregular Member
Steve D's Avatar
Exclamation Re: AU 2-3 remote: Unlocking all doors with one button press
It's true it is the BEM that keeps a record of which remote is set to two-stage unlock and which is set to one-staqe unlock. However it also depends on the remote accurately transmitting the button combination.
The OEM remote transmits the codes according to the buttons pressed (and the BEM works out how to interpret the message) and, if multiple buttons are pressed, the remote says so. The clone remote must be only signalling that one button is pressed, even if more than one is pressed. The software must stop checking the other buttons after it confirms the first one is pressed.
They must have missed the subtle difference when doing their reverse-engineering.
She mostly takes : Ford Territory TX AWD (SY 2006)
*** Wheels magazine COTY 2004 ***
I usually get: Mitsubishi Magna ES (TL 2004)
*** Wheels magazine COTY 1996 ***
Steve D is offline   Reply With Quote Multi-Quote with this Post
