Old 27-11-2011, 02:34 PM   #1
5.8
5.8's Avatar
Default Au II falcon LPG backfire
A mate's AU2 4.0 litre falcon had a backfire on LPG yesterday. It seems to be now running an about three cylinders even on petrol. Any ideas on what might be the problem, maybe the coil pack? and any ideas on what may have caused the backfire. It happened when accelerating from a standing start.
5.8 is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2011, 03:10 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default Re: Au II falcon LPG backfire
Its a bugger but you could try different leads in different spots (undo from coil pack and change) having checked all are OK. I can't see the aback fire would stuff the coil pack. I had to change my inlet manifold gasket as it was letting in air.
Uk
Old 27-11-2011, 08:19 PM   #3
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Suggest MAP sensor may have been damaged; it's in the manifold just under the throttle body on those so a real pita :(
Also check manifold gasket and all vacuum hoses very carfully - spray degreaser around while it's running.
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 27-11-2011, 09:31 PM   #4
Uncle_Ken
Uncle_Ken's Avatar
Good call, mine has done that.
Uk
Old 27-11-2011, 09:42 PM   #5
FGII-XR6
FGII-XR6's Avatar
spraying carby cleaner is even better you hear a definate change in engine noise if there is a leak
[SIGPIC][/SIGPIC]
Rides:
Old 20-02-2014, 04:06 PM   #6
bolebrand
A duel fuel factory fitted LPG falcon au2. Started bak fire recently, changed spark plugs, running ok then back fired, changed leads, running ok but two weeks later back fired again every now and then when engine is cold. Running ok when engine is hot or on petrol. Is it the mixture or coil pack? Any advice?
bolebrand is offline   Reply With Quote Multi-Quote with this Post
Old 20-02-2014, 07:09 PM   #7
GK
Walking with God
GK's Avatar
It could be running lean. That also causes a backfire.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 21-02-2014, 10:54 AM   #8
bolebrand
GK
Thanks. Had mechanic looked at this morning. It was stepper motor got jammed causing too lean or rich and backed fired. Sprayed with CRC to release jamming and off it goes beautifully.
Old 22-02-2014, 08:29 AM   #9
GK
Walking with God
GK's Avatar
Glad you got it sorted with a minimum of fuss. It's great when you get a fix like that!
GK
Now gone!
On LPG
Old 22-01-2019, 09:48 PM   #10
alexs
Had the same problem, I blew the diaphragm on the mixer.
Went to Jollys, got another mixer, easy fix.
You can check by unplugging the little air hose going to the mixer, if nothing changes that means diaphragm blown.
alexs is offline   Reply With Quote Multi-Quote with this Post
Old 23-01-2019, 08:14 PM   #11
Uncle_Ken
Uncle_Ken's Avatar
Alexs the original post was in 2011. Good update idea.
UK
Old 11-02-2019, 06:01 PM   #12
raysute
Backfire on LPG?
My AU ute runs on LPG, and when it backfires, I always check the plug gap.
No more than .8mm, and all will be OK. Sometimes too many backfires will also damage the plug leads.
Ray
2002 AU-111 at 350k
raysute is offline   Reply With Quote Multi-Quote with this Post
