02-11-2005, 10:04 PM | #1 | ||
G'day all,
Got a problem with the speedometer. '76 MK 2 When I come to a stop it drops below the 0 ( Zero ) thus throwing it out by 20kms / hour. Anyone know of a fix for this ? And NO there are no stopping pins on the dial for this model, its all hidden behind. Thanks |
02-11-2005, 11:51 PM | #2 | |||
No longer driving a Ford.
Never heard of that happening, and I no longer have access to an Escort to have a look for myself to try and find the problem and solution. First thing that came to my mind was that the speedo itself may need to be rotated so it sits on 0km/h when you're not moving, however not sure how to do that or if it's even possible, sorry.
12-11-2005, 03:18 AM | #3 | ||
Rotating the speedo wont work as the trigger for the trip meter is in the way
Anyone else got any ideas ? I'm in Queensland and I do believe there is a speedo shop somewhere near Rocklea / Coopers Plains. Have no-idea where it is. Dearly need help Thanks |
12-11-2005, 11:06 AM | #4 | ||
Do you have access to a spare speedo to try??
Current Rides: 2000 AU 5L XLS ute; 1970 Mustang project |
12-11-2005, 05:16 PM | #5 | ||
No unfortunately :(
12-11-2005, 07:13 PM | #6 | ||
Silhouette AU1 TS50.
I think your needle might have been moved from it's correct position. Maybe try removing the cluster, then the speedo itself and align the needle.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947) PIC'S OF MY T1 TS50.
12-11-2005, 11:12 PM | #7 | ||
Thanks, will see if it can be done
Cheers |
13-11-2005, 10:32 AM | #8 | ||
What dash do you have at the moment? I can check to see if my mate has a spare.
13-11-2005, 06:39 PM | #9 | ||
so is the speedo totaly out of wack, like when your driving 60 its reading 40? id pull everything apart and check myself
14-11-2005, 10:12 PM | #10 | ||
What I might do is put an internal stopper so the clock stops at 0 ( Zero ) not under ... It may work
Let you know Cheers |
19-11-2005, 06:26 AM | #11 | ||
my speed and rev gauge are crazy
mind of their own |
