08-04-2006, 09:50 AM | #1 | ||
as the tile sugests, does the 5 speed from an EA fit into an EL? An oppurtunity has arsien where i can get the whole car for dirt cheap, so i would be able to steal pretty much everything from this car, except the computer.
So would it bolt straight up? I know one of you guys has recently done a conversion, so i'd love to hear from you! Cheers Matt |
08-04-2006, 10:43 AM | #2 | ||
yep..same motor basicly,,just bolt it all up and a way ya go..
2000 AU Wagon |
08-04-2006, 11:00 AM | #3 | ||
Genuine V8
HSVETA did this conversion EA-EL a few months back.
Before FPV there was Tickford. Dont forget WINDSR plates for sale. (VIC) PM if interested. |
08-04-2006, 11:14 AM | #4 | ||
likes falcon's
ecu is kinda useless but, and you have to make modifications to your existing wiring loom, pedal box has a differnt brake switch, just make connectors for it and use that
www.carhubsales.com.au |
08-04-2006, 11:39 AM | #5 | |||
I *think* Walkinshaw put a EA T5 in his EL Fairmont.
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
08-04-2006, 11:45 AM | #6 | ||
It will go in no problem, but the Flywheel and clutch are different EA / EB-EL.
08-04-2006, 12:37 PM | #7 | ||
The clutch is smaller in an EA and has a 3 bolt presure plate as apposed to EB2 onwards which have a 6 bolt clutch, you can still use the EA clutch and flywheels though. Also the EA pedal box needs to be modified slightly, there are heaps of posts on this so do a search.
08-04-2006, 01:20 PM | #8 | ||
hmm eyebrows
Remember too that you will have no synchro for reverse. Before you put in reverse, just slide the stick into 5th and then back into reverse otherwise you will look like a noob when you grind the gears all the time.
1999 Range Rover 4.6 V8. Soon to have a new blue oval bent eight. |
08-04-2006, 06:42 PM | #9 | ||
i put a ea box in my ed and had to buy a new rear yolk for the diff cos the ea ones are different
:eclipsee_ Cant save! my car is my Wallet []D [] []\/[] []D []\[] |
