Old 13-06-2015, 12:23 PM   #31
lotus
Default Re: E Series big brakes
Originally Posted by Qwik6 View Post
Have you had any problems with the kit lotus?
Got a wheel alignment today. All went well.
Car handles good and I can feel no problems.
I have a problem with the rotors in that i had then skimmed but they still shudder when applied. More prevelant at high speed (highway) but can still be felt when driving around town.
Will have to look at what other alternatives I have than using the EL GT rotors.
We salute those brave souls that enter the DARK side
lotus is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2015, 07:53 AM   #32
Sparksy
I'm on a Boat!
Sparksy's Avatar
Hey Lotus
Does it shudder when cold or when warmed up a bit, reason I ask is some brake pads when new can feel like your rotors are warped when the heat up, just gasses coming out of the brake pad, had this a few times at the track. It will stop after a while.
Here are my brakes, transformed the car, worth every penny. Also from race brakes Melb I believe.
Also have el uprights which have a slightly better Ackerman angle so the inside wheel turns a little more than the outside wheel for better turning.
Also have AU Top arm and pedders AU caster camber kits which give me 10.5 deg caster which feels awesome on the road.
El Tazo's 96' DFII LTD, TE50 5.0l, AFR165, Qtrhorse, T5, Pedders Coilovers, No Stege, Thumpin twin system, AU upper arms 12 Deg Caster.
95' DF LTD, TE50 5.0, T5, Rip Shifter, Sunroof, FBT grille, Clarion HX-D2, 343mm Quad Piston AP's ,Koni Yellow Front, Red Rear, 14" Caster.
79' XD 5lt Clevo Supra 5 sp Hotwires and some usual rust, needs a resto, It will wait for me.
76 Celica Ra23 with Lexus 4lr V8, kaaz LSD, Quad piston RX7 front brakes.
1999 BMW 328ci, Topaz Blue, Manual, Sunroof.
Sparksy is offline   Reply With Quote Multi-Quote with this Post
Old 04-07-2015, 06:34 PM   #33
lotus
Pretty sure it is 1 or maybe both the rotors. Just got back from work yesterday afternoon so haven't had much time to check them out. Jacked up the front today and the right hand rotor is scrubbing at one place. The left seems ok, but I will take both rotors off and get them checked out. If there is a problem with them I'll have to look for alternatives that are available or get something made up.
Old 04-07-2015, 06:45 PM   #34
Sparksy
I'm on a Boat!
Sparksy's Avatar
Yeah that doesn't sounds great.
I'm happy to take some pics of my FBT brakes if your looking for a problem but I would imagine once you have a close look it will be clear.
Old 14-07-2015, 10:21 PM   #35
El Tazo
Dick off, Mr Slattery
El Tazo's Avatar
I think I'll be going the RBS kit with the AU twin-pistons to fit under 17s. I've heard a few bad things about the UPC setup, but it's a grand cheaper than the RBS one.
DF LTD - Toasty warm 5.0, manual, coilovers, shed queen
Winner - Best Fairlane/LTD NA/DA Onward at Geelong AFD 2015
PCOTM July 2015
BF Typhoon - manual, bolt-ons, noice tunes, abused every time it's driven
Previous Projects:
Festy - Daily XR4 Grandad's ZJ: Laid to rest Danny's EL Fairmont - Barra-swapped, left home
How To's:
A half-decent 6.5" speaker install in an EF/EL 85A Clevo alternator upgrade
El Tazo is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2015, 08:45 PM   #36
lotus
Had the rotors reskimmed, fitted them back on the car and work great. No more shudder and pull the car up better. Will have to go for a good run and see how they are. At the moment the car is under cover as I am away working at Newcastle and might not be home for about a month.
Old 01-08-2015, 09:28 AM   #37
El Venom
normality is boring
El Venom's Avatar
My upc brakes have been great
Factory v8 with turbonetics 67mm turbo, haltech ecu, aeromotive and raceworks fuel system, cobra intake and a few custom bits thrown in
El Venom is offline   Reply With Quote Multi-Quote with this Post
Old 01-08-2015, 10:50 AM   #38
El Tazo
El Tazo's Avatar
Just a coupla questions, if you'll endulge a potential buyer: any issues fitting them? How many Ks have they done? What sort of driving? Which offset are yours?
PCOTM July 2015
Previous Projects:
How To's:
Old 02-08-2015, 10:12 AM   #39
El Venom
normality is boring
El Venom's Avatar
Fitting mine was easy even had my 4 year old daughter helping. Offset I am not 100% but I am running genuine BA xr8 18x8 rims and they are a close fit to the upright but no clearance issues.
When I got the kit I was in form it has done 10,000km's and everything still looked great, as for my driving I have taken threw mountain runs with speed and towing loaded trailers, higher speed emergency stops (dam roo's) and general running around which for me 98% of the time at 100km/h and I like to stay near that speed for as long as possible including the corners.
One thing that did change though when I fitted my kit which I wasnt expecting was the effect on my handling. The car became alot more responsive and direct with the steering input and it took a little bit to get used to it. I am unsure why it has done that and my only thought is that the kit came off a XH and I fitted it to and EL but been checked out and drives straight and within spec and I am loving it.
Old 02-08-2015, 03:11 PM   #40
El Tazo
El Tazo's Avatar
Wow mate, that's a pretty glowing review!
PCOTM July 2015
Previous Projects:
How To's:
Old 02-08-2015, 06:34 PM   #41
El Venom
normality is boring
El Venom's Avatar
1 of the best upgrades I have done. Now I am used to them my driving style/ habbits have adjusted slightly to suit and just become second nature
Old 08-12-2016, 07:19 AM   #42
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
One of the best upgrades I did as well and the wheel choice was opened up to anything available for AU+ instead of stuck with the slim pickings available for pre+au.
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
