Old 10-04-2017, 10:59 PM   #1
yojabbajabba
Default Installing Fog Lights on a MC LX
Hey all,
I'd like to know whether the wiring for the foglights is already there for when install a set of aftermarket foglights. I picked up a set from AliExpress and wanted to know if it would be a matter of plug-and-play or whether I'd need to create my own sub-loom (my 2015 MC LX has the fog light switch assy in the cabin already).
A
yojabbajabba is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2017, 02:55 AM   #2
bundybear75
bundybear75's Avatar
Default Re: Installing Fog Lights on a MC LX
Following......
2012 MC Mondeo LX TDCi Wagon - Highway Hack 392K km and counting - Now gone 😢
2008 Peugeot 308 HDi - Highway Hack II
2008 Citroen C4 HDi - Highway Hack III
2010 Peugeot 308 HDi SW - Shaggin Wagon II
2016 VDJ200R Landcruiser GX Wagon - TTD V8 Power !
2017 Toyota RAV4 GX Wagon - Shopping trolley - Gone
2022 Volvo XC40 T4 Inscription - Shopping trolley II
2002 BMW R1150GS
bundybear75 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2017, 06:53 AM   #3
russellw
russellw's Avatar
Where the switch is installed then so is the fog lamp loom so you should find the two connectors somewhere!
Russ
Old 11-04-2017, 10:25 AM   #4
cobrin
Challenge Accepted!
cobrin's Avatar
its been my experience that there are some parts missing, you can fill those items and it'd be functional as expected.
switch - even though you have one it may not be operational for fog lights
wiring loom harness to bumper fog lights - both sides
Fog lights (perhaps a mounting bracket)
that's about it
Undecided replacement...
Old 11-04-2017, 03:28 PM   #5
Mondaveo
Mondaveo's Avatar
How many fog lamp buttons in your LX?
In the Titanium there are two. Front and rear.
The rear fog lamps are integral with the taillights and present across all grades. Fronts are only fitted on Zetec and Titanium.
I'd be very surprised if you have both front and rear fog lamp buttons with the front button unconnected. Usually manufacturers use a blank in place of a working switch. If you only have one fog lamp switch, you'll probably find that it's for the rear lamps.
(The front fog lamp button is to the left of the headlight switch and the lamp icon points left. Rear button is on the right side and the icon faces right.)
2011 Mondeo MC Titanium TDCi wagon, Panther Black
- new Powershift sensor: Nov 2016
Originally Posted by rondeo View Post
Like 'Mondeo' is possibly Latin for gearbox anxiety.
Mondaveo is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2017, 03:48 PM   #6
yojabbajabba
So it turns out I have the REAR fog lights with a blank switch for where the front ones should be. Thanks for the tip!
What should I do next? Is it easy to find the switch for the front and a harness for the front? Would I be able to wire in the front fog lights using the same control as the rear ones?
Old 11-04-2017, 04:08 PM   #7
cobrin
Challenge Accepted!
cobrin's Avatar
for my foglights to work i press the button on the headlight light level knob, its a rotary knob with inner button. Which i see in your pic, is the right side for the rears? (dash brightness)
Old 11-04-2017, 04:29 PM   #8
Mondaveo
Mondaveo's Avatar
Originally Posted by cobrin View Post
for my foglights to work i press the button on the headlight light level knob, its a rotary knob with inner button. is yours like that?
Yes, the other way I could have described it is the front fog lamps are controlled by the inner button of the rotary headlight level knob, and the rear fog lamps are the inner button in the rotary dashboard brightness knob.
Cobrin, your MB has front fog lamps only?
At a pinch, I'd guess you could hook it up to the existing button to have front fog lamps instead of/in addition to the rears, but I have no idea about wiring.
Personally, I'd look on ebay or find a wrecker with a whole vehicle to see if you can get the parts cheap. Also sites like partsplus.com.au. The switchgear shouldn't be too hard but I think the wiring might be problematic if it requires anything special (hard to extract from a complete vehicle and harnesses tend to be expensive to buy new...).
Here's a listing I found for the switches on ebay, but I'd hold off buying until you know what you need for wiring the lights up too: http://www.ebay.com.au/itm/252827965123
Old 11-04-2017, 04:30 PM   #9
yojabbajabba
Yep the switch on the right is for the REAR fog lights, the blank switch on the left (which has the rotary selector for the headlight dip) is supposedly for the FRONT fog lights.
Old 11-04-2017, 04:36 PM   #10
yojabbajabba
Thanks for the advice - will go and see if the wreckers nearby have a full Mondeo lying around. I think I'll go find which relay is controlling the rear fog-lights and piggy-back that signal to my new front fog lights - that way only one button controls both F+R and I won't have to purchase that second-hand switch.
When you turn on the front and rear fog lights are there two separate indicator lights on the instrument panel that light up?
Old 11-04-2017, 04:56 PM   #11
Mondaveo
Mondaveo's Avatar
Yes there are; pg79-80 of the manual.
From memory the indicator for the front fog lights is green and for the rear is amber, but be mindful my cluster is a totally different layout to yours!
Old 11-04-2017, 05:04 PM   #12
whitelion65
whitelion65's Avatar
Please don't wire them both on the same switch. Front fog lamps can be annoying, especially when used in the wrong conditions.
Rear fog lamps are diabolical in the wrong conditions. Only to be used in heavy fog, or on tail-gaiters ;-)
Steve
Current rides
2012 Mondeo Titanium wagon (TDCI)
Moondust silver
2016 Focus Trend, 1.5ecoboost, 6sp manual.
Frozen white
Previous
2004 Berlina Wagon (LS1) Vespers Blue
1995 Camry 2.2, white
1971 Ford Fairmont wagon 302w, C4 Polar white
1971 TC Cortina, 2L 4sp, Ermine white
whitelion65 is offline   Reply With Quote Multi-Quote with this Post
Old 11-04-2017, 05:15 PM   #13
yojabbajabba
Haha.... I won't be using the fog-lights unless it's actually foggy outside. Would it not make sense that when the front fog-lights are utilised the rear ones are on as standard? It doesn't make any sense why you'd only have the REAR or FRONT fog lights on only.
To be clear, I am also installing the LED DRLs that will be auto-on during ignition and auto-dim when the low/high beams are on. The fog lights are being installed for two reasons; for foggy days going up the Macedon Ranges (VIC), and to fill in those ugly black plastic panels in the LX's bumper.
Old 11-04-2017, 08:46 PM   #14
Mondaveo
Mondaveo's Avatar
Front fog lights are to help you see.
Rear fog lights are to help you be seen.
Different purposes are probably the justification for manufacturers providing independent operation, or conditions may make one less suitable over the other.
Earlier this year I drove through a torrential downpour with visibility down to the taillights of the vehicle in front. I put my rear foggies on to make my vehicle more conspicuous against being rear-ended, but left the front ones off while they gave me no benefit.
Most cases though, if used sensibly, front+rear should be just as acceptable as independent front/rear?
Old 11-04-2017, 09:29 PM   #15
cobrin
Challenge Accepted!
cobrin's Avatar
both, fronts level knob, rears dash brightness knob as you described. I guess that's the Zetec trim for ya.
Old 12-04-2017, 06:13 AM   #16
NZ XR6
I expect that the wiring to the switch is standard across all models, so you probably just need to change the switch. But you may need to add a fuse and relay to the assembly under the glovebox.
Sent from my SM-G9208 using Tapatalk
Old 12-04-2017, 06:50 AM   #17
bundybear75
Hey all,
A
You wouldn't be able to share a link to the lights you brought would you? I'm interested in attempting this myself.
2002 BMW R1150GS
