Old 25-06-2013, 07:11 PM   #1
Bob_Bobson
OzEcruies
Bob_Bobson's Avatar
Default can anyone weld my Sump?
can anyone weld my au Sump together so i can start putting the motor in my car or same where that can do it.
thinks
BOBSON
Bob_Bobson is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2013, 07:52 PM   #2
atec77
Default Re: can anyone weld my Sump?
thinks
BOBSON
Lots more information needed to get any sensible answer
Old 25-06-2013, 09:52 PM   #3
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
I assume he is fitting an au engine to his ef so he requires his au sump moded to fit
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Originally Posted by rednose View Post
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2013, 10:08 PM   #4
Bob_Bobson
OzEcruies
Bob_Bobson's Avatar
think you sorted that is rite i am fitting an au engine to his ef and need my sump moded
Old 27-06-2013, 12:26 AM   #5
ILLaViTaR
ILLaViTaR's Avatar
most auto and exhaust shops should have the ability to weld you just want to make sure the dimensions are correct. Best to ring around until you find a shop who's familiar with the conversion and then it's just a matter of asking for the sump modified for an EF and they'll do the rest. Otherwise get the dimensions and any welder should be able to do it (possibly cheaper too) I think I saw them on ebay a while ago too, shouldn't cost more than $100 to get it modifed but I could be wrong!
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come!
ILLaViTaR is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2013, 09:20 PM   #6
BlueprintedXR6T
Not many exhaust shops will weld alloy..... not many mechanics do tig welding....
You have to cut the sump and replace it with peice of alloy plate
I have cars that is all
BlueprintedXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2013, 01:01 AM   #7
trick_xd
I build your wish list...
trick_xd's Avatar
or
grind back the fins and you will get a few mm gap .. thats fine as the motor does not move back and forth .
If it weren’t for physics and the law enforcement, I’d be unstoppable.
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2013, 01:50 PM   #8
Sorted
Sorted's Avatar
I was told that to grind down the front of the sump is correct on EA - ED series where it has the square tube across the front of the frame or the tube can be cut and altered relatively easy.
BUT on the EF - EL the pressed K-frame has to be cut and a section taken out or else cut and weld the sump.
Tuned by DYNOMOTIVE
Old 28-06-2013, 09:25 PM   #9
BlueprintedXR6T
Ea ed yes just grind fins. Ef el cut sump, illegal to cut up subframe
Old 29-06-2013, 01:10 AM   #10
trick_xd
trick_xd's Avatar
Bend the flat lip on the K frame and grind the fins .
