16-08-2005, 11:33 PM | #1 | ||
My EA fairmont ghia's heaters have stopped working. Its got climate control, but when you crank the heat up nothing happens. HOWEVER one thing i did notice was that even when the temp was turned up to 32 or whatever it is it sounded like the air con compressor was still kicking in.
Perhaps the heaters are working but the air con is cooling the air? Stupid little problems like these normally cost lots to fix so im leaving it up to you guys to help me out. |
17-08-2005, 12:07 AM | #2 | ||
I had the same sort of problem, not entirely sorted yet either. My heater box was filled up with leaves and all sorts of shrubbery, so with a bit of a clean out, started working a hell of a lot better. Could be your blend door motor too though...
You can disconect the a/c compressor, follow the wiring and there should be a plug. See if that helps? |
17-08-2005, 01:29 AM | #3 | ||
Parts bin special
Gotta love those EA Ghia heaters. I had a blocked heater core. It was putting out plenty of air, just not warm air... and a heater tap that only partially opened.... and to top it off a dodgy ambient temperature sensor (still need to go and check the wreckers). Hopefully that is the last of my heater troubles. Good luck with yours.
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2010 FG XR50T ute - Lightning Strike 6 speed manual, XR8 bonnet, hardlid, Streetfighter airbox Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior |
17-08-2005, 12:47 PM | #4 | ||
sounds like the A/C isn't Disingadgeing
17-08-2005, 05:59 PM | #5 | ||
PM me if you want
igntion on, press the floor and off button at the same time, tell me what error codes you get, if any.
17-08-2005, 10:09 PM | #6 | ||
The Guy You Love To Hate
Where do i find the heaterbox and where could leaves n crap be coming in? I get a really stron smell of burning leaves and grey smoke starts shooting out sometimes when i get hte heater on full.
18-08-2005, 06:36 PM | #7 | ||
ok dellboy999 ill give it a try.
18-08-2005, 07:35 PM | #8 | ||
ok code E2 came up, does that help?
18-08-2005, 09:06 PM | #9 | ||
Custom User Title
Blend Door Motor failure
18-08-2005, 10:06 PM | #10 | ||
Knuckle Head
T Terror, you're issue is likely build up of leaves on the Resistor coil. Up underneath the glove box(remove glovebox and its easy to sort out)
Couple of philips head screws later and you can hook all the leaves and crap out. |
22-04-2013, 04:34 PM | #11 | ||
Old post I know know but in case someone trawls this up looking for a solution for a similar problem note that Climate control does not have resistor pack fan speed controllers but has a computer controlled fan speed controller that is transistorised. But the leaves behind the controller do corode the transistors casing and cause fan speed issues.
regards Blue |
02-08-2013, 07:47 PM | #12 | ||
Reviving an old thread I know but it reflects the problem with my EA with climate control. I have replaced the climate control unit several times - the latest unit at least does seem to work ... but ...
I am having a similar problem to the OP in that when heating the AC compressor cycles on and off even when set to 32. There are no error codes when I run the diagnostic test. Last edited by Guess_who; 02-08-2013 at 07:48 PM. Reason: Altered post to thread. |
