Old 07-03-2019, 01:01 AM   #1
waimser
Default Im surprised Im still alive.
I picked up my car, a BA wagon, really cheap, paid like $100 for the car itself.
I was told it had been eating ball joints. I figured it wasnt really a problem at that price, even if I needed to replace the whole corner of the car id still be ahead. The front left bearing badly needed replacing but it drove fine, so I didnt think much of it.
Got into replacing the front left hub tonight and found this.
(large files so you can see it in all its glory)
https://i.imgur.com/IEJ7C4K.jpg
https://i.imgur.com/LjrDZt5.jpg
I very much doubt this setup is holding the specified 300Nm.
waimser is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2019, 01:33 AM   #2
Junkyard-Dog
*barks incessantly
Junkyard-Dog's Avatar
Default Re: Im surprised Im still alive.
You worry too much. That would've been fine for another 200,000kms
Junkyard-Dog is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2019, 02:34 AM   #3
waimser
Haha, youre probably right since the hub was rusted to the spindle a bit
Bearing is toast though and wouldnt have made it much further.
Old 07-03-2019, 11:13 AM   #4
Vesper Martini
Vesper Martini's Avatar
Are we looking at the twisted wire?
it would still do the same job as the split pin that's supposed to be there, provided the wire wasn't too soft
not the best - but not life threatening.
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2019, 11:46 AM   #5
Are they sheet metal nuts, stacked four high?
Old 07-03-2019, 12:19 PM   #6
Vesper Martini
I see, then not good enough. you can get wheel bearings with proper nuts & pins for around $100.
cost of the car!!
Old 07-03-2019, 12:48 PM   #7
GasoLane
Former BTIKD
GasoLane's Avatar
I'd say the real worry is if the PO has done that to a wheel bearing what has he done elsewhere
Old 07-03-2019, 12:52 PM   #8
Yes, I’ve owned one car and one truck with that sort of risk profile. Found an undamaged, un-bodged taillight and felt like sending it back “You missed a bit”...
Old 07-03-2019, 12:59 PM   #9
BFIIGhiaZF6
George
BFIIGhiaZF6's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: The experience, information and willingness to help and share data in regards to the ZF cooling system options has probably cleared a lot of doubt about air/oil coolers and the ZF transmission.
And what has he not done that should have been done
I wouldn't be driving it
BFWSMhttps://fordforums.com.au/vbportal/v...articleid=1708
ZF:http://fordforums.com.au/wsmpub/bf/307-01B.html
2007 BFII Fairmont Ghia I6 4L, ZF6 Auto, Ego Charcoal, Warm Charcoal.
R/Up 2019:Winner 2023:, Best BA-BF Geelong AFD.
PWR Air/Oil Cooler, K&N, Egas elbow, V8 upper F6 lower CAI.
1997 Fairmont EL Ghia Tickford 4L Auto
1985 Falcon XF GL 4.1L Auto.
1979 Fairmont XD Ghia 4.1L Auto.
1971 Cortina GL Estate 1200cc Manual.
BFIIGhiaZF6 is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2019, 07:24 PM   #10
Put this on your car and triple the value!
Old 07-03-2019, 07:55 PM   #11
Junkyard-Dog
*barks incessantly
I would still do burnouts in it.
Old 08-03-2019, 12:57 PM   #12
Mechan1k
Mechan1k's Avatar
That's what it looks like inside the shielding ... but these are not aligned though.
They are normally called a PAC nut .... and it was is used from factory over the hub anyway. Should always get a replacement PAC Nut when replacing a hub really.
Old 08-03-2019, 02:17 PM   #13
Junkyard-Dog
*barks incessantly
I need to replace my wheel bearings and I might give this a crack to save a few cents.
Old 08-03-2019, 02:20 PM   #14
FTE217
T3/Sprint8
FTE217's Avatar
pics or it didn't happen
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
Old 08-03-2019, 02:27 PM   #15
Gotcha, ta. Is that to equalise clamping force over the engaged thread, rather than at the fastener root?
Old 08-03-2019, 02:30 PM   #16
Charliewool
Bolt Nerd
Charliewool's Avatar
Don’t see an issue..
Engineering excellence where I live.
Current vehicles.. Yamaha Rhino UTV, SWB 4L TJ Jeep, and boring Lhd RAV4
Bionic BF F6... UPDATE: Replaced by Shiro White 370z 7A Roadster. SOLD
Workhack: FG Silhouette XR50 Turbo ute (11.63@127.44mph) SOLD
2 wheels.. 2015 103ci HD Wideglide.. SOLD
SOLD THE LOT, Voted with our feet and relocated to COSTA RICA for some Pura Vida!
(Ex Blood Orange #023 FPV Pursuit owner : )
Charliewool is online now   Reply With Quote Multi-Quote with this Post
6 users like this post:
Old 08-03-2019, 02:35 PM   #17
Itsme
Experienced Member
Itsme's Avatar
Hahahaha you got to love bush mechanics, It done the job!!!
Itsme is online now   Reply With Quote Multi-Quote with this Post
Old 09-03-2019, 07:55 AM   #18
foxtrot3
foxtrot3's Avatar
cost of the car!!
Hi. The BA (and the AU and falcons after the BA) did not use a split pin to stop the nut from coming loose. Instead the use a pac nut or caged nut made from multiple thin nuts in a pressed metal cage. As the bearing clearance is preset by a spacer between the bearing races the nut is done up to a very high torque value and becomes a self locking nut. Cheers MD
HI
I'M MICHAEL
Old 09-03-2019, 11:29 PM   #19
janddbone
B1 - J & D Services
janddbone's Avatar
Isn't this what Falcon ownership is all about?
Mr. Brett Johnstone.
2007 Honda Odyssey
2002 Ford Laser
2000 Ford Falcon Wagon Egas
1999 Subaru Imprezza Sportwagon
1998 Holden Suburban 2500
1995 Land Rover Discovery TDI
1994 XG XR6 Longreach
1983 Holden Rodeo
1982 ZK Fairlane 302 six seater
1975 Datsun 120Y wagon
1970 MG Midget
1967 Rover 2000TC
Soon: Model T.
janddbone is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2019, 08:21 AM   #20
mr_xlr8
GT-P Whitey
Who buys a car for 100 dollars?
On the 7th day, god created a FG MKI GT-P 5.0L S/C - Silhouette Gold Decals...
Current ride:
FG MKI 5.0L S/C 6SP Auto = 9.5/10
Previous Rides:
FG MKII GT-P 5.0L S/C 6SP MANUAL = 9/10
AU III 5 SPEED BLUEPRINT XR8 220KW= 8/10
BA XR8 BOSS 260 BLUEPRINT = 3/10
EB FAIRMONT WINDSOR 302 BURGUNDY = 6/10
mr_xlr8 is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2019, 08:26 AM   #21
There’s probably a topic in “What’s the least you’ve paid for a Ford?”
(My claim, bottle of JW Red Label for an XC Falcon - complete less starter, alternator and battery; fitted these from my stash and drove it home...)
Old 10-03-2019, 08:46 AM   #22
janddbone
B1 - J & D Services
janddbone's Avatar
Mine was a $300 EB on dual fuel. That copped a set of retreads, two oil changes and an alternator belt.... Sold it three years later for $350. Was faultless and to this day had the best LPG/petrol switch ever....
2007 Honda Odyssey
2002 Ford Laser
1983 Holden Rodeo
1970 MG Midget
1967 Rover 2000TC
Soon: Model T.
Old 10-03-2019, 04:10 PM   #23
Junkyard-Dog
*barks incessantly
My magna cost me a grand with 12 months rego. 130ks, 1 owner from new and he even threw in some turtle wax.
What a car.
Old 15-03-2019, 10:29 PM   #24
Sabantien
They don't come like that from factory?
Sabantien is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2019, 09:44 PM   #25
aussie muscle
aussie muscle's Avatar
anyone looking for a bargain or a parts car
My ride: 2007 Falcon Ute BF XR8 Orange, MTO.
aussie muscle is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2019, 12:54 AM   #26
waimser
It was just timing. An old mate saw me drive past in my beaten to hell AU. Someone in his family was trying to get rid of the BA that had been purchassed from a backpacker at the end of their stay. Basically they CBF getting it to a decent condition to sell after someone drove it into the towball of their 4x4.
Next day I get a call to please come get this thing out of the driveway.
Yea, im a bit worried honestly. Ive already found a couple doosies. The bolt that holds the exhaust heat shield on must have been going in cross threaded. That thing must have taken everything they had to turn it more, but they managed to get it all the way in. Im actually quite impressed. Luckilly it has no other function.
One of the bolts connecting the two halves of the intake manifold had some locktite caked halfway along it. That bolt was obviously put in by feel, and they stopped when that locktite contacted the thread.
The thing that worries me about those two items... is that they most likely happened at the mechanics when the welch plugs were done... You bet your behind im keeping a close eye on those plugs :P
I have done burnouts in it, semi accidentally. Pretty sure thats what sped up the demise of the rear axle seal
