Old 30-06-2007, 08:48 PM   #1
20focus05
I wanna XR5
20focus05's Avatar
Default LSD for Focus?
Is there a LSD for the manual LS focus?
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2007, 02:54 PM   #2
eXtremist
2007 Ford Focus Zetec
eXtremist's Avatar
I don't see why not, but I haven't seen any around.
You could use the phantom grip LSD kit, but they are known of blowing the gearbox casing.
eXtremist is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2007, 09:42 PM   #3
BlackLS
I've often thought this myself. Though LSD and FWD aren't the best things to mix, unless you like lauching in straight lines a lot.
There isn't one from the factory, but i think the Mazdaspeed 6speed box could have it? Otherwise what extremist said
Old 01-07-2007, 10:25 PM   #4
photn
AFF Post NAZI
photn's Avatar
what gearbox are you guys running?
cause i know there is a Quaife one for the IB5.....just not sure what you guys use. they also assist in cornering....
Old 01-07-2007, 10:59 PM   #5
FOCUSonTHIS
FOCUSonTHIS's Avatar
Quaife make LSD for the LR Focus so I'm sure that they would make a LSD for the LS Focus....should do a search on the Quaife website
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 02-07-2007, 12:33 PM   #6
BlackLS
We use the MTX75 I think. Same as the LR
Old 02-07-2007, 03:13 PM   #7
melbzetec
Old enough to know better
melbzetec's Avatar
If that's the case, you have the choice of the Quaife, or the Torsen
