Well i had a look at the heat shield material at the shop but it looked gay, so i walked out of the store thinking i will try again to fit it in the airbox.
1)Anyway i just used a cut down piece of 45 degree alloy 3in pipe, attached it to the pod, removed the airbox 4 bolt adaptor. 2) Then I cut a square hole in the front of the airbox tray. Dropped the pod in ,secured the lid with the 5 airbox clips. 3) And then attach to factory piping with rubber sleeve. The pod sits in the airbox quite well consider it's size. It easily has more than 1inch clearance around the entire pod as no sides are touching the airbox. pics........ Last edited by jjj; 19-07-2007 at 11:11 PM. |
Aspiring mr efxr
looks good mate. nice job! will have to consider this one very seriously
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
I gave the car a bit of a strap tonight and the cold air from the snorkel does help a fair bit in throttle response and acceleration when compared to when the pod was exposed too engine bay heat. Ambient temp on the clim ctrl screen was 10degrees.
Here is a pic of the K&N pod compared to a standard size pod that you find at autobarn/supercheap for $30. |
![]() Join Date: Dec 2004
![]() Any more of this and I'll have to contact PETA |
XD197
Those 30 buck aircleaners are good to flow roughly 300hp and i think they outclass most upper pricerange aircleaners,i saw a test done in a magazine.The one i put in my eb 6 made a noticeable difference cept i took out the bottom half of the airbox and riveted ally plate to the frame rail to keep out the hot air and left the top of the box to direct cool air onto the pod, it was connected to the standard intake pipe with 3 inch exh pipe.
#6 | |||
XD197
All im saying is that the cheap pods do the same job and not to overlook them i didnt say they outflowed the k+n filter in question but it wouldnt surprise me if they did etc etc My setup cost 30 bucks and probably made around the same power.Twenty times cheaper is good enough for me
#8 | |||
Was really noticable on the highway when over taking 3 trailer road trains, normally overtake them at a starting speed of 90km/hr and by the time i get around them and move back into the lane, i am doing about 125-135km/hr. But i could feel the engine struggling up at the high revs. Since fitting the big berther K&N pod and overtaking these trucks the car doesn't get starved of air under full throttle. I am getting a speed of about 150km/hr while passing them and merging back into the lane. . The K&N pod was about $70 bucks from american autos, although Supercheap and autobarn wanted $160-$180. Cheers..
EL FAIRMONT Pacemaker 4499's Megaflow 2.5in Cat X-Force 2.5in Sports Exhaust Champion STEEL igntion leads K&N panel filter, EL GT Snorkel, modified airbox 16in Speedy Holotype-R mags on 225 tyres |
So your filter gave you a 25kph increase in overtaking speed? You do realise that's more than a 1-2rwkw increase that your pod is giving you
XD197
My cheapy filter was a tfi or sumthin like that,why did you have to get up to 125-150 overtaking isnt that a bit excessive?Most trucks should only be doing 100 and if they were speeding why did you have to overtake?
#11 | |||
I have seen tests, graphs etc proving this and even some expensive filters such as HKS have poor filtration. The Apexi pods were the best in terms of filtration and flow. |
