View Poll Results: How you use your tiptronic auto?
I use it all the time! 72 62.07%
I never use it. 8 6.90%
I've tried it once, but haven't used it since. 16 13.79%
I haven't tried it yet, but I will. 2 1.72%
Other (Please Specify) 18 15.52%
Voters: 116. You may not vote on this poll
Old 21-08-2007, 02:14 PM   #61
james22
With da Warlords
james22's Avatar
I found that in my fathers ute, SSS actually is slower than perf auto mode.
If you use SSS it revs past its useful power range till it hits the limiter, then you change and there is that 'lag' where it thinks about it for a second. Where as if its in perf auto it shifts at max power rather than redline. Does this sound right?
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2007, 02:19 PM   #62
DOC
DOC's Avatar
It would depend on what you were doing, if you were nearing a corner it may be better to hold the gear and revs rather than have it shift up then back again, the manual option is just that, you don't have to wait for it to redline before shifting up, practice will refine these manual changes.
DOC is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2007, 09:10 PM   #63
DDXR6T
DDXR6T's Avatar
I use it all the time, really livens the car up and makes the exhaust sound a bit better getting a few more RPM on board until shifting.
DDXR6T is offline   Reply With Quote Multi-Quote with this Post
