Old 17-10-2007, 11:30 PM   #1
mwaltham
Default New Ford Focus CL Auto - Running in
The Ford user manual is fairly vague regarding the running in of the engine. Do I even need to? If so does anyone have any suggestions such as max engine revs, speed etc. Thanks
mwaltham is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2007, 01:01 AM   #2
4dlvr
4dlvr
the engines are allready run in,
that dosent mean you can go off thrashing the car. but take it easy until you do a decent amount of km in
ild say dont exeed a max of 4000rpm for the time being
96 EF FAIRMONT
Garrett gt40 turbo , iceman plenum, head ported, polished and balanced, wade turbo cam, wade double valve springs, bosch 023 fuel pump, 36lb injectors high flow cat, 4' dump and 2.5' redback exhaust.
215rwkw @7psi
4dlvr is offline   Reply With Quote Multi-Quote with this Post
Old 18-10-2007, 01:38 AM   #3
phoonfan
^^^^ good advice!
Enjoy your new car!
phoonfan is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2007, 08:47 PM   #4
Ma-N-Pa
We recently bought a new Focus CL and were told to vary the speed for the first 1,500ks and not exceed 100kmph. In the user manual it says very similar and also mentions to avoid heavy use of the brakes for the first 150km in town and for the first 1,500 km on open roads. The manual also says to gradually increase the speed after 1,500ks.
Ma-N-Pa is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2007, 09:31 PM   #5
jweb
radio off =save petrol :P
Running in of a car is very similar to anything else with a motor.The valve seats etc are new and need time to bed in,as they wear in they will stretch etc.
Over reving an engine before it has properly been broken in,can cause these materials longetivity to be significantly reduced,and in grim cases the parts can reach their elastic limit/point of plastic deformation and be permantley and damaged or even,fracture.
Take it easy,do not over rev the engine,that said the engine needs to be under load to efficiently be broken in.So pulling a higher gear at low revs can be benifitial,but i recommend this procedure after the car has done a few K's,as the Load can cause problems in itself.
Just putting around will not allow the Engine and other parts of the car to be broken in,the car needs to be driven at a moderate speed and revs,and try not to keep the same velocity and Revs for a long preiod of time.
Better roads,and better planned infrastructure=higher speed limit :
jweb is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2007, 05:11 AM   #6
BlackLS
yum
1 Stop guide: http://www.mototuneusa.com/break_in_secrets.htm
2005 LS Focus LX
250,000kms.
Old 20-10-2007, 11:41 AM   #7
photn
AFF Post NAZI
photn's Avatar
love these kind of threads
best of both worlds =
1st redline straight into 5th
Old 21-10-2007, 05:14 PM   #8
jweb
Old 21-10-2007, 05:15 PM   #9
jweb
Originally Posted by BlackLS
Dont realy agree with that article,Go easy to begin with,then after a few K's Torque the engine in higher gears,which creates load on the engine etc,dont need to rev the engine to redline .Its got some good points tho.
Old 22-10-2007, 12:43 AM   #10
BlackLS
yum
What exactly is disagreeable about it?
I took it easy initially with the brakes, clutch and gearbox etc, But the engine had varying load from day one from 2000rpm to about 5000rpm, after the first tank it was driven hard as it is today. Now with 95,000kms.
2005 LS Focus LX
250,000kms.
