10-03-2008, 11:22 PM | #61 | ||
I build your wish list...
Blahhhh
Cut a Hole I did and since then the car goes a lot better ... and great on a cold night |
10-03-2008, 11:34 PM | #62 | |||
Smile
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
11-03-2008, 12:06 AM | #63 | |||
Red bull gives you wings?: nahhh.... we got our wings from TICKFORD |
11-03-2008, 09:25 AM | #64 | ||
B-Series Moderator
Stav, why don't you build yourself an airbox around your pod? Have a search for DYI Airbox in The B-series section. Build it out of sheetmetal and then insulate it. Better than a bonnet scoop as it will keep the volume of your piping intact.
BF MKII XR6 Turbo 2007 (Flare) ZF Auto 380rwkw - 11.68 @ 120.94mph 60ft=1.97 Custom Tune, Exhaust. injectors.1.2K Plazmaman 1.2K Plenum kit Now with bigger turbo and 426rwkw. |
11-03-2008, 02:52 PM | #65 | |||
JMM modded EF
sorry stav i did not mean any disrespect. just got abit annoyed. i apoligize
"She goes like a zirtek" WANT A FAST FORD RING THIS BLOKE V V Abbott Engines for HeadWork 20 years experience PH Rob on (07) 5526 3883
11-03-2008, 02:53 PM | #66 | |||
JMM modded EF
good luck with the mod
11-03-2008, 06:08 PM | #67 | |||
Smile
11-03-2008, 10:53 PM | #68 | |||
11-03-2008, 11:11 PM | #69 | ||
Its good to see people think outside the square. You obviously havent run your times without doing a bit of research first and finding areas to improve on and coming up with an alternative.
Anyways here is a product that didnt really get off the ground over here in Aus, but is doing well in the states. http://www.designengineering.com/pro...asp?m=sc&cid=1 It says to keep intake temps down by up to 60%, saying that I dont know what effect it will have on your motor. Maybe in a boosted application it maybe noticible in the drivers seat, but being a keen drag racer like yourself, a few tenths is enough to deem it a good mod.
A philosopher is a person who finds a problem for every solution . :Reverend: 95 EF XR8, Advance headers, Vortech V2 t trim blower, Ported Cobra Manifold, Capa Switch Chip Eliminator. 307 rwhp 395 ft/lb 13.2 @ 105mph Now NA- AFR 165 heads, 1.6RR, Ported Cobra 269rwhp 14.2 ... needs stall and 4.11's 1977 CL Chrysler Panel Van, 360, 727 torqueflite auto soon to be restored. |
11-03-2008, 11:36 PM | #70 | ||
stav ,i remember seeing somewhere (not sure if it was here or fordmods) but they had a pod filter directly attached to the TB .it was all enclosed nice and neat and had a hole cut through the bonnet with a scoop of some sort attached (autobarn style)did the job.it looked good ..
i don't reckon there'd be any setup better than that ,but for the life of me i can't find the pic.
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
11-03-2008, 11:46 PM | #71 | ||
Hi Stav,
I've got another idea for you. It would mean fitting the original still air box though. Grab a block of dry ice and place it in the bottom of the still air box below the Air filter before you do your drag run. The air comes in over the dry and cools the charge. Best regards, SilverAU. |
12-03-2008, 12:19 AM | #72 | |||
12-03-2008, 12:32 AM | #73 | ||
Smile
Thanks guys. I have been thinking about the cryo for some time now. Jake.You are on the money mate. I have another idea..get down to my local exhaust lackey nd see if he can do something stealthy underbonnet. I am after all the cool air that I can stuff into the throttle body . I am making no secrets that I would like to get a better pb in the coming months.
14-03-2008, 03:03 AM | #74 | ||
14-03-2008, 06:41 PM | #75 | ||
Smile
niceeeeeeeeeee
14-03-2008, 09:08 PM | #76 | |||
Rob
14-03-2008, 10:15 PM | #77 | ||
one of the eseries boys has the same setup as rob, Trickxd has his airfilter out of the bonnet 24/7 lol, must make a difference from mid- high rpm
14-03-2008, 10:40 PM | #78 | ||
Why don't you just make up a heat shield for the pod your using. From what I have found there is plenty of air coming from behind the headlight. It also stops the engine bay radiant heat and hot air blowing out from the passenger side thermo fan from heat soaking the pod.
I just used a cardboard template than used some 6mm clear acrylic. Also used a big K&N pod. |
14-03-2008, 11:50 PM | #79 | |||
www.TUFFCARPARTS.com
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
15-03-2008, 01:09 PM | #80 | ||
Any good Hardware store should sell acrylic sheets:-private9 .
