Old 14-04-2008, 08:18 AM   #1
GS608
Default 351 in a triton
hey fellas just throwing some ideas around in my head, would a 351c fit into the tritons bay? also if i did end up putting it in what sort of things would need updating?
other ideas would be a evo engine, or rb30
GS608 is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2008, 12:30 PM   #2
Sonik
I think the 3.8L commo engine goes in the older model ( like 1998 )
http://www.ausfish.com.au/vforum/showthread.php?t=89003
http://www.v6conversions.com.au/Info...ishi%204x4.htm
Sonik is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2008, 01:33 PM   #3
GS608
thanks mate for the links i'll deff be checking it out, seems pretty reasonable as well, price wise, just gotta find a cheap 3.8 and T5
Old 14-04-2008, 02:02 PM   #4
SeXC
Pushrodosaurus Rex
SeXC's Avatar
cuy the clevo and give it a go, if it doesnt work, buy a cortina shell and drop it in that!
SeXC is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2008, 02:05 PM   #5
Cylinder Head
It sounds like a waste of a perfectly good 351 to me!
Cylinder Head is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2008, 03:48 PM   #6
GTLexus
GTLexus's Avatar
i think someone has posted 351 measurements on here before, can't seem to find them now though.
Just measure it all up and you will know.
The evo engine would fit straight in but would require mods due to spinning it around.
You could always go a 351 windsor?
GTLexus is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2008, 04:23 PM   #7
Woz
As in 'best there ever'
Woz's Avatar
My cousin's got a Triton (not sure what year, late 80's, early 90's) with a turbo RB20 in it. I know he went to a lot of effort getting it in, including making up a custom radiator and rebuilding half the front of the car to fit it all in, aswell as the smaller jobs like building new engine mounts and whatnot. He's a boiler maker/welder so he did it all himself, but if you were gonna pay someone to do the work, it all sounds somewhat costly.
"We swear by the Southern Cross to stand truly by each other, and to fight to defend our rights and liberties."
The Diggers Oath, 29 November 1854
My XB Fairmont Sedan Project
Woz is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2008, 04:37 PM   #8
XCSEDAN
i'm baaaack....
XCSEDAN's Avatar
why not put an injected 5.0 in it? that would be plenty man.... you can crack 200+rwkw out of them... quite easily!
XCSEDAN is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2008, 04:43 PM   #9
GS608
ive had a look around, might end up just putting a turbo on the 4G64, apparently its the same motor used in the US Spyder but mounted differently for FWD
Old 14-04-2008, 04:49 PM   #10
GreenMachine
Mopar/No Car
GreenMachine's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Sensational write up about drum brakes.
They'd be a body over chassis car, so with enough cutting and welding you'd be able to fit anything... Some of those turbo diesels are big units too, should be room for a clevo...
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
If you don't fight - You lose
GreenMachine is offline   Reply With Quote Multi-Quote with this Post
