Old 31-08-2009, 09:18 AM   #1
shaneo79
shaneo79's Avatar
Default What is that knocking?
Hi guys,
I have an 02 KQ Laser which the wife drives to and from the station every day with about 124,000 k's on the clock.
It has been mechanically fine and when we bought it about 14 months ago we spent about $700.00 fixing a few bits and pieces etc.
I had to drive it on the weekend and noticed that when turning left at around 30-40 k's an hour or so, there is a reasonably noticable knocking noise coming from the front right wheel or something in that area.
Any ideas? Has anyone else had a similar problem?
2007 SY TX RWD in EGO with factory tinted windows, heavy duty tow pack, Territory carpet mats, rubber cargo liner and rear sunshades
shaneo79 is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2009, 04:16 PM   #2
galaxy xr8
Giddy up.
galaxy xr8's Avatar
I've had two laser's both KJ hatchback's and both of them had this knock you mention, doesn't seem to affect it so I havn't worried about it to much but I know what you mean, it's annoying.
Old 01-09-2009, 01:02 PM   #3
shaneo79
shaneo79's Avatar
Thanks for that.
I will be taking it to the mechanic soon so will let you know what the noise ends up being....you might be curious to know.
It might be a suspension component as my wife now tells me that the steering wheel is becomming a little more "shakey".
Old 01-09-2009, 05:48 PM   #4
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Yeah I will be interested to know what it turn's out to be, thank's mate.
Old 10-09-2009, 12:08 AM   #5
Linz
*SILVER SERVICE PILOT*
Tech Writer: Recognition for the technical writers of AFF - Issue reason: For his technical submissions. Technical Contributor: For members who share their technical expertise. - Issue reason: Always willing to help out with good, solid advice.
Might be a CV joint on the way out.
BUILD THREAD
https://www.fordforums.com.au/showth...71#post6891271
2006 Lightning Strike BF Fairlane Ghia...HIS
2024 Titan Grey Hyundai Tucson Highlander...HERS
Linz is offline   Reply With Quote Multi-Quote with this Post
Old 10-09-2009, 02:10 PM   #6
shaneo79
shaneo79's Avatar
Ah...thanks for that Linz.
I had one at the rear recently replaced but still haven't gotten around to booking it in for this front issue.
Will certainly post a reply when I have the answer.
Old 11-09-2009, 08:20 PM   #7
wesso
Telstar TX/5 AX2
wesso's Avatar
Originally Posted by shaneo79
Hi guys,
I have experienced this problem first hand but it was with a 4X4. What happens is the CV joint has a rut wear into the main knuckle where the main race of balls run on it. After a while this rut wears deeper and when you turn the steering it means that the ball race has to then cross the rut which causes a clicking/knocking noise which gets louder the more it wears.
This problem seems to be worse in 4X4 vehicles that are continuously run with the front hubs locked. However I have also heard it in a few front wheel drive cars that have done a lot of kilometers.
Wayne
FORD Telstar V6 2.5 Litre TX/5 AX2 - 1993 Build
wesso is offline   Reply With Quote Multi-Quote with this Post
